value1
Digital Combat Simulator – DCS Plugin 2.0.0.0
  1. noorbeast
    154,849Coins
    +11,229 / 57 / -2
    My pleasure, though more importantly I am relieved that you did not inadvertently damage a Vive base station.
  2. Soma888
    Soma888 New Member
    Australia
    149Coins
    I have just bought a dofreality 3dof system and I’m using DCS and try to make it run smoothly. Has what you are talking about been implemented into the latest version of SimTools that you can download? It’s going to be good to not have that jerkiness when trying to do a roll. Looking forward to using SimTools more.
  3. Adrianstealth
    Adrianstealth Active Member
    director
    england
    160Coins
    SCN6, 4DOF
    Upgrading pc soon so will be able to use DCS again
    Previously simtools with this plug-in wouldn’t work with the spitfire
    Is this still the case ??
    Ps all other aircraft was ok
  4. Soma888
    Soma888 New Member
    Australia
    149Coins
    When replacing ‘roll’ In SimTools with Extra 1 and Extra 2(?) to smooth out the roll, besides the axis assignments where else do you need to update? Do I need to change anything in Export.lau or the plug-in?
  5. Happy Cat
    Happy Cat New Member
    Russia
    304Coins
    Tell me how can I use extra 2 in dcs?
  6. Moe Colontonio
    New Jersey USA
    827Coins
    I was never able to get Extra 1 or 2 to work. I'm still trying to figure out how to get YAW working! Someone mentioned using Heave, but for me, HEAVE tilts the rig forward/back? I found a solution to get rid of the "flip" when rolling, I'll try to find it and post it here.
  7. Moe Colontonio
    New Jersey USA
    827Coins
  8. Happy Cat
    Russia
    304Coins
  9. Moe Colontonio
    New Jersey USA
    827Coins
    Excellent, now if someone could help me get yaw to work?!!!
  10. Happy Cat
    Russia
    304Coins
    I think in DCS not is used yaw. Give it a try sway.
  11. hugso
    hugso Active Member
    Glos UK
    611Coins
    Arduino, Motion platform, 4DOF
    Finally got round to installing latest DCS world and all working well with my 5 dof rig. I really really really would like to use airspeed. Any chance this could be added to the plugin?
  12. Historiker
    Michigan USA
    9,212Coins
    @hugso , which planes are you flying in DCS with Simtools? Some people are reporting that the newest planes (F/A-18c and Yak-52) are not functional with the plugin.
  13. hugso
    hugso Active Member
    Glos UK
    611Coins
    I have only flown the Spitfire so far. Works fine flying round Normandy. Needed a lot of tweaking when I swapped over from Cliffs of Dover. Pitch Roll and Sway all OK with minor adjustments in Tuning Center. Heave is a bit strange - a sudden leap of one g on take-off. Surge is how I would expect on the ground, but goes bonkers in flight - massive surges when zooming up and down and with changes in engine power. If I disconnect surge in flight things are pretty good. (It would be great if we had airspeed available with the plugin, I would not have to do this manually.)
  14. gianlu320
    gianlu320 Member
    Crawley
    542Coins
    I also have problems with surge in flight
    On the ground it's fine but inflight keeps my platform always pitched up when i accelerate and the problem is that i can't feel enough pitch in this way.
    How do you disconnect or deactivate surge in flight?
    Is there a way to make this happen via the export.lua?
  15. RiftFlyer
    RiftFlyer Active Member Gold Contributor
    1,711Coins
    DC motor
    Yes you can do it with a simple if statement and your altitude agl.
  16. BrassEm
    BrassEm G-Seat + SFX100 Builder Gold Contributor
    NE of YMML
    1,102Coins
    DC motor, AC motor, 4DOF
    @gianlu320,
    I've used altitude to scale certain outputs in the AfterNextFrame section of the export.lua Adjust your export.lua as required. (Make a backup first!!!!)
    To get aircraft datums;
    local altRad = LoGetAltitudeAboveGroundLevel()
    local TAS = LoGetTrueAirSpeed() -- (args - 0, results - 1 (m/s))
    local accel = LoGetAccelerationUnits() -- (args - 0, results - 1 (g)) The g-Force.
    Where the variable "surge" is output to GameEngine I believe;
    local surge = accel.x -- Surge
    Then add values in as needed;
    if altRad <= 2.5 then
    surge = surge -- this statement not really needed but for following logic
    else
    surge = surge*0.1 -- Reduces surge by 1/10th when aircraft above 2.5AGL
    end
  17. gianlu320
    gianlu320 Member
    Crawley
    542Coins
    @BrassEm
    Thanks a lot for trying to help...
    I'm a total noob in this thing, I've tried what you suggested but it doesn't work as expected.
    I still get full surge inflight as before and I loose also the reduction on the other forces when on ground.
    I'll copy paste what I modified in my export.lua
    AfterNextFrame=function(self)
    local pitch, roll, yaw = LoGetADIPitchBankYaw()
    -- reduce forces on ground
    -- if altRad < 3 then
    -- accel.y = accel.y * 0.25
    -- accel.z = accel.z * 0.25
    -- surge = surge
    -- else
    -- surge = surge * 0.1 -- Reduces surge by 1/10 when aircraft above 3AGL
    -- end
    What did I get wrong?
    thanks for the help
  18. BrassEm
    NE of YMML
    1,102Coins
    @gianlu320
    My bad, I've been looking at my own export.lua for too long. Not seeing all of your export.lua I am assuming a few things. It would be good if you could post your full export.lua. But...
    if altRad < 3 then
    accel.y = accel.y * 0.25 --<Reduces Heave to a 1/4 of its value while on the ground (Less than 3m/3ft)
    accel.z = accel.z * 0.25 --<Reduces Sway to a 1/4 of its value while on the ground (Less than 3m/3ft)
    accel.x= accel.x -- Surge remains the same
    else
    accel.x = accel.x* 0.1 -- Reduces surge by 1/10 when aircraft above 3AGL
    end
    EDIT: Apologies. The original code won't work as it is ignored by the lua interpreter because of the preceeding "--"'s. I've removed them to make it work as intended.
  19. gianlu320
    gianlu320 Member
    Crawley
    542Coins
    @BrassEm
    Thanks a lot for your answer
    I'll copy paste my export.lua as it is now without any of the changes you suggested.
    I just want to mention that this export.lua was not done by me ,it was done by steve2112 and was posted in his building thread.
    The link to his building thread and to his export.lua can be found in this page, page 15 of this thread, post287.
    I just wanted to give credit to him before going any further.
    So this is the export.lua I'm currently using and it works very well apart from the surge inflight that is a bit to much and it impedes my pitch...
    -- convert to degrees to make the math easier
    pitch = pitch * 57.295779;
    roll = roll * 57.295779;
    --dbg_file:write(string.format( "p=%.1f r=%.1f ", pitch, roll))
    -- STEVE reduce roll by when pitch > 45deg
    if pitch > 45 then
    local multiplier = 1- (pitch-45)/30
    if multiplier < 0 then
    multiplier = 0;
    end
    roll = roll*multiplier
    --dbg_file:write(string.format("PITCH>45: p=%.1f r=%.1f m=%.3f ", pitch, roll, multiplier))
    end
    -- STEVE returns roll back to zero as it passes +/- 90 degrees to avoiding the -179 to 179 flip that occurs in a full roll
    if roll > 90 then
    roll = 180 - roll
    --dbg_file:write(string.format("ROLL>90: p=%.1f r=%.1f ", pitch, roll))
    elseif roll < -90 then
    roll = -(180 + roll)
    --dbg_file:write(string.format("ROLL<-90: p=%.1f r=%.1f ", pitch, roll))
    end
    --dbg_file:write(string.format("\n"))
    -- accel.x = accel.x * 0.25
    -- end
    my_send = socket.protect(function()
    if c then
    -- socket.try(c1:send(string.format("%.3f; %.3f; %.3f; %.3f; %.3f; %.3f;\n", pitch*1000.0, bank*1000.0, yaw*1000.0, accel.x*1000.0, accel.y*1000.0, accel.z*1000.0)))
    socket.try(c:send(string.format("%.4f; %.4f; %.4f; %.4f; %.4f; %.4f;\n", pitch/57.295779, roll/57.295779, yaw, accel.x, accel.y, accel.z)))
    end
    end)
    my_send()
    end,
    So what do you think?
    Should I just modify it as you suggested in your previous post?
    Like this?
    -- accel.y = accel.y * 0.25 --<Reduces Heave to a 1/4 of its value while on the ground (Less than 3m/3ft)
    -- accel.z = accel.z * 0.25 --<Reduces Sway to a 1/4 of its value while on the ground (Less than 3m/3ft)
    -- accel.x= accel.x -- Surge remains the same
    -- else
    -- accel.x = accel.x* 0.1 -- Reduces surge by 1/10 when aircraft above 3AGL
    -- end
    Also the first time you answered me you wrote me this...
    Do I need those lines as well?
    Sorry for the many questions and really thank you for looking in to this and hopefully it can be useful for others as well
  20. BrassEm
    NE of YMML
    1,102Coins
    @gianlu320,
    No problems. I hope I am not confusing things too much as I goofed with the last code post. Working from the bottom up;
    Steve's .lua already has this in so leave it as is. It assigns the g values obtained by the LoGetAccelerationUnits() funtion to the variable "accel".
    I threw this statement in for reference as I use the TAS value in calculations to scale how much force is felt depending on airspeed where needed. Up to you if you want to add this in for your calculations. I can elaborate further if it will help.
    You mention that the statements below work okay on the ground but not in the air. These statements have a preceeding "--" in front of them which tells the .lua processing to ignore anything after that in that line. So they dont have any effect unless you remove the "--"'s. This part of the code needs to be modified for the in air effects. I left them (the --'s) in when I cut and pasted for the previous post. They have preceding "--"'s so it wasn't going to work anyways as it was being ignored. Sorry about that. Now for the "working" code this time...
    WAS...
    -- end
    REPLACED WITH...
    -- reduce surge in the air
    if altRad > 3 then
    accel.x = accel.x * 0.5
    end
    The 0.5 scale factor value will reduce the Surge accel.x variable by half. In the previous example I've used 0.1 scale factor or one tenth. Unfortunately you will need to experiment until you find the value that works best for your setup.
    Let us know how you go. I am also curious to what the MIN/MAX values in GAME ENGINE is for Surge.
