value1
Digital Combat Simulator – DCS Plugin 2.0.0.0
  1. gianlu320
    gianlu320 Member
    Crawley
    542Coins
    @BrassEm
    Thanks a lot for your answer
    You clarified things to me more than you might think
    See I thought the (--) before the sentences where actually activating the commands and not deactivating them.
    I will have to go back and retry all your suggestions since the beginning
    I will let you know how that goes and also what surge values I have in the game engine.
    It will be in 15 days or so as I’m now outside home for work
    Thanks a lot for your help
  2. hugso
    hugso Active Member
    Glos UK
    611Coins
    Arduino, Motion platform, 4DOF
    Please excuse me for butting in, but I see you have the line "localTAS=LoGetTrueAirSpeed() " ... etc. I would like to use airspeed. Is it possible to export airspeed to either Extra 1 or 2 or 3? If so how would I do this? I am very stupid in the IT department, so I would be grateful for any advice. (I have only just twigged that I could disable the "reduce forces on the ground" - much better now, no jump in heave motion as I take off and more surge motion as I accelerate along the runway.)
  3. nosimula
    nosimula New Member Gold Contributor
    Brasil
    - 20Coins
    2DOF, 3DOF, DC motor
    Personally, I'm having problems with the YAW plugin for DCS World and also NoLimits2. In both cases the axis does not start in the center. What causes in gross movements and interferes with the experience. Does anyone know how to solve it?
  4. BrassEm
    BrassEm G-Seat + SFX100 Builder Gold Contributor
    NE of YMML
    1,102Coins
    DC motor, AC motor, 4DOF
    @hugso, Apologies for not replying sooner, my PC has been waiting on a replacement motherboard so I am not able to visit regularly. If Extra1, 2 or 3 is being accepted by the Game Engine DCS driver for output then it is possible. I.e. For Extra1, In the DCS export.lua code make Extra1 = localTAS. A fan hooked up to the Extra1 output will receive the values that fall within the Extra1 MIN / MAX values.
    The values would be;
    DCS localTAS = 0 to 700 (kph as an example.)
    Extra1 MIN / MAX = 0 / 700 (After manually editing the Game Engine DCS MinMax.cfg file)
    You could set Extra1 MIN / MAX to 0 /100, Your fan will be maxed out at any TAS over 100 kph
    I don't know if there is a canopy open/closed function/value in DCS so that it could be used to turn the fan on/off? It would be ideal if it were a value such as between 0 and 1. Where 1 being fully opened.
    For the export.lua code edit would add in something like this;
    Breezy = CanopyOpen()
    Extra1 = localTAS * Breezy
    EDIT: It looks like no EXTRA's output in this version. Will need to ask the Value1 nicely and wait for next version of the driver to have these enabled for the above to work. Sorry :(
    EDIT: OR use the localTAS on an unused existing channel i.e. yaw = LocalTAS (Thanks for the heads up Hugso.)
    @nosimula, What are you Game Engine settings?
  5. Bacasable
    Bacasable New Member Gold Contributor
    Retraité
    NIMES FRANCE
    249Coins
    Hello
    I installed the plugin, patched the games but I have no dialogue when the games is launched. When I look at the tuning center it has no dialogue. I am with the basic games with only the two planes SU 25T and TF-51D and I play with headphones windows mixed reality. Can you help me to make it work?
    My simulator works well with other games. I attach screenshots of my setup
    154,849Coins
    +11,229 / 57 / -2
    As you seem to be having issues with multiple plugins can I first check that your sim has proper motion with LFS.
  7. Bacasable
    Retraité
    NIMES FRANCE
    249Coins
    I'm ready to check anything you want. ;-)
    I would like to point out that my simulator works well with plugins from Asseto Corsa, Assetto Corsa Competizione, Dirt Rally, Race Room, Project car2, RF2, X-Plane11.
    Thank you for your help
  8. BrassEm
    NE of YMML
    1,102Coins
    @Bacasable
    GameManager connects with GameEngine? GameManager indicates that DCS is running when DCS is started? Eagle Dynamics or Steam version? There are no Export.lua errors in the DCS.log file?
    EDIT: Correct log file reference.
  9. FoxONe42
    FoxONe42 6DOF newbie
    Flight simulator engineer
    Nantes France
    102Coins
    Arduino, 6DOF
    @BrassEm
    Just to let you know, I am also experiencing the same issues. No data going from DCS to Simtools V2.2.5
    Other games work just fine (X plane, FSX. LSF) and to answer your questions:
    GameManager connects with GameEngine? YES
    GameManager indicates that DCS is running when DCS is started? YES
    Eagle Dynamics or Steam version? EAGLE DYNAMICS
    There are no Export.lua errors in the DCS error log file? Do you know the path for such a file ? I can't seem to find it. I have got a failed.ofsh file however, not sure whether or not it is related. I cannot not read it anyway.
  10. Bacasable
    Retraité
    NIMES FRANCE
    249Coins
    Here are the answers to your questions:
    Eagle Dynamics or Steam version? Steam Interface API v018 package:1541819448
    In the log directory I have a DCS file in which there is indeed an error on export. Lua (2018-11-16 09:48:43.344 Error LUA:: Config: Call error LuaExportAfterNextFrame: [string "D:UsersThierrySaved GamesDCSScriptsExport.lua"]: 48: Attempt to Index Upvalue ' Accel ' (a nil value)) but I am unable to interpret it. Can you help me?
    Thank you
    I attach the log file
  11. FoxONe42
    Nantes France
    102Coins
    Arduino, 6DOF
    Hi
    I have got pretty much the same type of error message in my case:
    2018-11-19 00:07:16.221 ERROR Lua::Config: Call error LuaExportAfterNextFrame:[string "C:\Users\Jérôme\Saved Games\DCS\Scripts\Export.lua"]:48: attempt to index upvalue 'accel' (a nil value)
    stack traceback:
    [C]: ?
    [C]: in function 'my_send'
    [string "C:\Users\Jérôme\Saved Games\DCS\Scripts\Export.lua"]:52: in function 'AfterNextFrame'
    [string "C:\Users\Jérôme\Saved Games\DCS\Scripts\Export.lua"]:87: in function 'SimLuaExportAfterNextFrame'
    [string "C:\Users\Jérôme\Saved Games\DCS\Scripts/SimShaker.lua"]:575: in function 'LuaExportAfterNextFrame'
    [string "C:\Users\Jérôme\Saved Games\DCS\Scripts\SimShaker-export-core\ExportCore.lua"]:62: in function <[string "C:\Users\Jérôme\Saved Games\DCS\Scripts\SimShaker-export-core\ExportCore.lua"]:56>.
    Same here, unable to understand what it is suppose to mean: My version is ED build 2.5,3,23225
    Thanks for your help in advance
  12. FoxONe42
    Nantes France
    102Coins
    Arduino, 6DOF
    Hi Guys, I found where my issue was.
    Since I am using a French windows, decimal separator is a coma (,) but it has to be a dot (.) in order for DCS to work properly with Simtools. So if you are in the same situation as me, you 'll have to go to your regional settings and change the decimal separator from coma to dot, then restart you computer and then you can try again Simtools along with DCS,
  13. Bacasable
    Retraité
    NIMES FRANCE
    249Coins
    :)hug:
    Thank you very much this to settled also my problem.:thumbs
    I am also with a Windows 10 French... because I am French ;-)
  14. FoxONe42
    Nantes France
    102Coins
    Arduino, 6DOF
    :thumbs Glad that helped. Funny we had the same problem at the same time AND we are both French. F*cking French windows :grin
    I am only slightly disappointed by the plugin by the way. It doesn't provide roll/s, pitch/s and yaw/s as the X plane plugin does, and I believe those are useful information.
  15. T R Para
    T R Para i make stuff up
    Cincinnati, Oh
    2,447Coins
    AC motor, 6DOF
    I cannot get any motion out of DCS either. Running a dual PC system. Patched on both pc's. Game manager turns blue when I start DCS1.5 and the game engine indicates DCS when in the tune mode.
    However it never sees any data in the tune mode.
    Checked that I have a decimal point "." and not a comma in the region descriptor.
    Pcars2 runs fine no problems.
    Normally I can get this stuff working but I tried all day and read through this thread with no success.
    HELP!
    • dcs.txt
      File size:
      17.9 KB
      1,090
  16. BrassEm
    NE of YMML
    1,102Coins
    @T R Para,
    No errors in the log file which is good. It would appear that Game Manager is not talking with Game Engine. Do you get a "connected" indication after first starting Game Manager and then starting Game Engine on the other PC? If not then you may need to check what the IP and port settings are.
  17. T R Para
    Cincinnati, Oh
    2,447Coins
    AC motor, 6DOF
    Yes I get a connection (green background) and on the remote pc the engine has a blue light on in the upper right corner.
    I disconnected the remote pc and connected the Arduino to the main pc. I set the ip address in the game engine (now running on the main pc) and reset the ip address in the game manager. And it worked.
    As long as I am running a single pc DCS is working.
    I reconnected the 2nd pc and set the ip address back.
    No DCS..
    Without changing anything and still using the remote pc I can boot up Pcars2 and it works fine.
    I get out of pcars2 and boot DCS and nothing..
    One thing I did notice and it may be nothing, when booting DCS I get a pulse out of the wheelchair motors for just an instance then the tuning panel populates with a grayed-out set of default numbers.
    The axis settings and output configurer get the typical blue paled out color panel.
    I really like the ability to use the remote pc for tuning.
    I would hate to loose it but there is something blocking the data.
    I did turn off all firewalls on both pc's and no joy :(
  18. yobuddy
    51,779Coins
    Did you patch the game before or after you setup the dual PC setup?
    Maybe the game needs re-patched?
    I know DCS uses a lua script, maybe there is a local Ip address in it that is hard coded?
    (I have not played with this title, so I'm only guessing buddy)
    Take care,
  19. T R Para
    Cincinnati, Oh
    2,447Coins
    AC motor, 6DOF
    I will try repatching again.
    On the main pc it is easy to click on the patch remover and repatch.
    On the remote pc there is no such button on the game engine.
    So I ran the patch updater where you drag and drop the zip file.
    Is that correct??
    Mr Newbe here..
  20. yobuddy
    51,779Coins
    For a 2 PC setup, you need to install the plugin on both PC's.
    You only need to patch on the Game manger PC.
    Im not sure what you mean by patch updater?
