value1
Digital Combat Simulator – DCS Plugin 2.0.0.0
  1. RobsonSwiss
    RobsonSwiss Active Member
    Preotria, South Africa
    35Coins
    Hi
    We've seen that data coming to the sim is at a really low rate with DCS, 10-20hz, it changes a little depending on what you do in the game. Does anyone know why it's so low, if it's a problem with DCS or a problem with the plugin?
  2. RobsonSwiss
    35Coins
    Btw some other people have noticed the same thing, the effect is it gives jerky motion. From what I can see so far it appears that the data coming into simtools is already running at a low rate.
  3. Historiker
    Michigan USA
    9,212Coins
    Huge thank you for this plugin @value1, it is a great way to waste a weekend! :D
    The A-10C really comes alive now.
  4. Otso
    Otso New Member Gold Contributor
    51Coins
    Can whoever has the rights to edit the download page for the DCS plugin (https://www.xsimulator.net/community/marketplace/digital-combat-simulator-–-dcs-plugin.16/) please add to the description that you must have the US locale in Windows for it to work. I just spent well over an hour trying to figure out why the plugin was not working. I'm quite sure many others have struggled with it as well, and it would be so easy to update the description on the download page.
    Ultimately, it would of course be nice if the bug in the plugin would be fixed.
  5. yobuddy
    51,779Coins
    The problem here is the game requires a LUA script to export the data.
    And this script is hard coded with periods.
    I believe there is a replacement LUA script somewhere in this tread thou.
    v2.4 will attempt to lock the whole app to usa mode and this problem should vanish if it works.
    We will have to see how well it works when i get around to testing it.
    Take care!
    154,849Coins
    +11,228 / 57 / -2
    Done: https://www.xsimulator.net/community/marketplace/digital-combat-simulator-–-dcs-plugin.16/
  7. Otso
    51Coins
    I don't want to nitpick, just correct the facts. The Lua export script uses string.format() to format decimal values in a local dependent way. The script is not hard coded with periods. However, it probably runs in the Lua default locale (US English), and does not adhere to the locale set in Windows.
    Ok, great, thanks!
  8. yobuddy
    51,779Coins
    There is a re-worked script in this thread somewhere, that does work without changing the PC to USA mode as I remember.
    As I remember the poster said it was a period vs comma dilemma.
    I was not suggesting that how its reading the data is the problem, just that there is a comm vs period problem somewhere in the script that a user has claimed to have fixed for non USA pc's.
    Since I live in the US thou, i never played with it, I just wanted to let you know it existed.
    Take care,
  9. Trip Rodriguez
    Trip Rodriguez VR Pilot
    Lake Ariel, Pennsylvania
    3,978Coins
    I'm seeing an "extra 1" in SimTools but it's not mentioned in the page. Anyone able to tell me what that is, or am I misconstruing the meaning of the value being available in the profile editor?
    Thanks!
  10. John458
    John458 Member
    Retail
    Brisbane
    393Coins
    Yes I see "extra1" as traction loss but no data flows through this in the tuning center, so I don't think its "connected to anything"
    154,849Coins
    +11,228 / 57 / -2
    Extra 1 is not listed in the DCS plugin overview, which normally means it is not implemented: https://www.xsimulator.net/community/marketplace/digital-combat-simulator-–-dcs-plugin.16/
    No data in the Tuning Center for Extra 1 will confirm it is not implemented.
  12. Trip Rodriguez
    3,978Coins
    @value1 I have been talking with Dirty and others about fixing the issues with rolls, loops, etc. by not using Euler Angles (only accelerations instead).
    This is particularly important in DCS as it is used heavily for dogfighting and aerobatics. I'm hoping you might contact Dirty about the subject. He's willing to do the work but from what I understood when we spoke, it would be much easier for him if he could discuss with you the way the plugin handles certain things.
    Thank you sir!
  13. Kaneda
    Kaneda New Member
    84Coins
    hi everybody
    i have problem with DCS plugin in simtools game dash
    i install DCS plugins and patched
    when i start dcs, Game manager recognize DCS (game is running)
    But in Game Dash nothing
    with others games is ok (assetto corsa, rfactor2, Pc2)
  14. noorbeast
    154,849Coins
    +11,228 / 57 / -2
    The DCS plugin download page states that:
    DashApp Data:
    Additional values for instruments are feasible, yet not implemented.
  15. Kaneda
    Kaneda New Member
    84Coins
    thanks !!
    Do you know if it's planned ?
    i have fanbox who manages wind turbines :)
  16. noorbeast
    154,849Coins
    +11,228 / 57 / -2
    It really depends on what time @value1 has, as he maintains this and many other plugins in his free time.
  17. Historiker
    Michigan USA
    9,212Coins
  18. Phaze11111
    Phaze11111 Member
    Central Indiana - USA
    - 41Coins
    3DOF, SCN5, Arduino
    Has anyone been able to get an Arduino based wind simulator to work in DCS? I have been using my wind sim now for the last couple of years with the games AC, pCars2, rfactor 2, Dirt Rally and recently xPlane11 using Sim Tools 2.0 and Game Dash. I do have motion in DCS working fine using Sim Tools 2.0.
    I'm thinking there may be an in-game setting of some sort I need to enable?
    Thanks for any thoughts or suggestions.
  19. noorbeast
    154,849Coins
    +11,228 / 57 / -2
    The plugin summary suggests the functionality is possible but not implemented: https://www.xsimulator.net/community/marketplace/digital-combat-simulator-–-dcs-plugin.16/
    DashApp Data:
  20. Historiker
    Michigan USA
    9,212Coins
