value1
Digital Combat Simulator – DCS Plugin 2.0.0.0
  1. gorzasty
    gorzasty Active Member
    photographer, IT specialist
    Poland, Wrocław
    1,060Coins
    Changing the region in Windows was the key. Now it works!
    154,849Coins
    +11,229 / 57 / -2
    Have you obtained and activated a license, plus configured your Interface Settings to match the new convention for SimTools 2.0: https://www.xsimulator.net/community/faq/request-a-free-diy-simtools-2-0-license.262/
  3. gorzasty
    Poland, Wrocław
    1,060Coins
  4. BrassEm
    BrassEm G-Seat + SFX100 Builder Gold Contributor
    NE of YMML
    1,102Coins
    DC motor, AC motor, 4DOF
    Well after a loooooooong build, I am now at the final stage of tuning my G-Seat in to actually start flying it. Fortunately version 2.1 is out to get the ball rolling again. Unfortunately I have hit a snag straight off. Using the DCS plugin DCS_GamePlugin.2.0.0.0.zip, the telemetry looks good. All readouts correspond to the axis in motion. I've started by using just my seat base flaps, Axis1a (right seat flap), Axis2a (left seat flap) as [A<Axis1a>][B<Axis2a>] for just the heave axis (accel.y). When flying in DCS the seat base flaps correspond directly to the roll axis. No matter what DOF position I put it in? Anyone have trouble with the DCS plugin assignments??
    UPDATE: 18/02/2017
    With what little time I have now for the seat, I drew up a truth table and the results show that the plugin works as it should. Not what I thought the axis assignments would be - obviously.
  5. Allerweill
    Allerweill New Member Gold Contributor
    Erlangen Bavaria Germany
    217Coins
    3DOF, SCN6, Motion platform
    Hallo DCS user´s,
    i understood how to Setup all by 3 axis (3x SCN6 150mm) happy. I love to fly the Huey Heli but iám somehow overwhelmed with all setup stuff like filters and so on. starting with the roll axis at the beginning helped me a Little bit. But maybe one of you can helpe me out with a Setup for testing or wher can i find it in this Forum. I would be very pleased.
    154,849Coins
    +11,229 / 57 / -2
  7. Allerweill
    217Coins
    Thank you for the link norbeast.
    What i found out with the roll axis that the reaction time is slow.it feels like there is a deadzone.but in the filter , the deadzone is 0. is there some more helping adjustment for my problem.
    154,849Coins
    +11,229 / 57 / -2
    Sounds like your tuning center value needs to be lower, as that sharpens motion responses.
    Leave filters until you have the basics sorted.
    It would help if you start your own thread and post pictures of all of your settings. A video that shows the rig and screen at the same time is also useful for troubleshooting advice.
  9. apointner
    apointner Siddhartha
    N 48° 9'0.88" E 12° 5'45.84"
    764Coins
    Heads Up Pilots,
    ED has build in a new table which could possible solve the pitch Bug (goas inverted at pitch up 90°) and bank flip (goas -180° at pitch up 90°)
    I've filed a bug with our internal bug trucking system, requesting to have the DCS matrix exported along with Euler angles.
    Chances are you will get the DCS matrix with one of the upcoming updates.
    Wait for it.
    Best regards,
    Andrey Filin
    Eagle Dynamics IT Team
    Lua export script with lua Matrix class sample added
    in that matrix class mathematics rotation is matched with DCS internal code:
    local data = LoGetSelfData()
    local yaw = 2.0 * math.pi - data.Heading -- because heading returned opposite for navigation use
    local pitch = data.Pitch
    local roll = data.Bank
    local m = Matrix33()
    m:RotateY(yaw);
    m:RotateZ(pitch);
    m:RotateX(roll);
    print("-------------------------------------")
    print(m.x.x,m.x.y,m.x.z)
    print(m.y.x,m.y.y,m.y.z)
    print(m.z.x,m.z.y,m.z.z)
    May someone could try this out?
    Cheers André ak Siddharta
  10. BrassEm
    NE of YMML
    1,102Coins
    Will definitely be looking at this code on the weekend and report back.
    Update 22/04/2017: I am having some issues with the Matrix33() function. Errors and returns nil.
  11. Giantruck1
    Giantruck1 New Member
    italia
    288Coins
    DC motor
    Hi with last update dcs does not work you can help me thank you
  12. misoswan
    misoswan Active Member
    1,038Coins
    3DOF, Arduino, JRK
    helo
    i have 3 dof patform ....
    How to reach the vibrations and what axis set for this. Roll, heaven,pitch ? watch please video
    2:18
    thanks
  13. noorbeast
    154,849Coins
    +11,229 / 57 / -2
    That looks to be predominantly heave @misoswan.
  14. Giantruck1
    italia
    288Coins
    DC motor
    Do not work plugins with dcs and x-plane 11 do anyone know how to do it?
  15. noorbeast
    154,849Coins
    +11,229 / 57 / -2
  16. spyderwash
    spyderwash genesy sim
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    You can check if the plugin works with the latest updates I do not get data
    thank you
  17. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    Ok problem solved was the fault of an update of my PC
  18. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    35/5000
    With dcs update I had data
  19. Giantruck1
    italia
    288Coins
    DC motor
  20. reko19
    reko19 Active Member
    electrical engineer
    usa
    38Coins
    Is there a way to prevent jumping from one motion axis extreme to the other at the point of inversion for a roll or loop?
