Dirt Rally 2 Plugin v2.3
SimTools plugin for Codemasters Dirt Rally2
  1. yobuddy
    51,743Coins
    @Outatime,
    Hi Buddy,
    Looks like @value1 has some math in there a bit above my head. lol
    I bet we could add raw heave output to one of the extra un-used slot if needed thou.
    Take care,
  2. Tim Palmgren
    Tim Palmgren Maker / Motion Fanatic
    IT Recruiter
    Auckland, New Zealand
    82Coins
    3DOF, Motion platform, 4DOF
    If it would be possible to do that without throwing the 'nan' value it would be awesome as that seems to be what is causing all the problems with the smoothing filter.
  3. value1
    14,294Coins
    There is a "Custom UDP" mode for newer Codemasters games (e.g. DiRT 4 and newer). It let's you specify not only gforce lateral and gforce longitudinal but also gforce vertical.
    Maybe this could resolve the issue? @yobuddy: More details here.
  4. vin100lorant
    vin100lorant New Member Gold Contributor
    Professeur Electrotechnique
    Beynes
    191Coins
    For my part, I still have the problem with the game engine that stops after pausing the Dirt game even if i set the smooth parameter of the heave to OFF.
    On the other hand the game vibe always turns...
    I have to stop the game engine, wait about 5 seconds, and restart when dirt is in action.
    This is not practical, especially in VR where you have to lift the helmet in full play to restart the machine!
    I hope this will be elucidated.
    Again, how can I help save everyone's time?
  5. Tim Palmgren
    IT Recruiter
    82Coins
    Are you running Intensity on 100% if you are not then that filters the heave, so make sure smoothing is off on heave axis and make sure intensity is at 100%
  6. vin100lorant
    Beynes
    191Coins
    I had check that, but the problem is always here.
    If i finish a stage, game engine work fine without to stop and start it.
    but it's not the case if i make a pause and resume the game, here i ha ve to stop/wait/restart the game engine after resume the game.
    thanks anyway for your help.
  7. Tim Palmgren
    IT Recruiter
    82Coins
    I only had that behaviour if there was some sort of filtering on the heave, but it happens both if you lower intensity and if you specifically add the smoothing to the heave axis... Not sure what is going on in your case then...
  8. value1
    14,294Coins
    Hi all
    Can you try this plugin? This plugin should fix the heave issue.
    • Unpatch the game.
    • Load the plugin new with the Plugin Updater.
    • Patch the game with this plugin.
    • Check, if there is only one entry "port="4123" in the <motion_platform> paragraph of the file C:\Users\"User"\Documents\My Games\DiRT Rally 2.0\hardwaresettings\hardware_settings_config.xml.
    Thank you for your feedback!
  9. DotComRich
    DotComRich Member
    546Coins
    @value1 Thanks man it seems to have fixed it for me!
  10. Tim Palmgren
    IT Recruiter
    82Coins
    Also fixed for me, had to rework my profile from scratch but all is good now
  11. kastiel
    kastiel New Member Gold Contributor
    - 250Coins
    hello, thanks for the patch. I tested your patch, it works on normal screen, but not in VR.
  12. value1
    14,294Coins
    Thank you for your feedback @kastiel. Good to hear it's working fine in normal mode. The VP thing will be fixed in a second step soon :)
  13. kastiel
    - 250Coins
    I replaced the line that starts with "custom", that of the file not vr, it works now, thank you
    j'ai remplacé la ligne qui commence par "custom", par celle du fichier non vr, sa fonctionne maintenant, merci
  14. yobuddy
    51,743Coins
    Whats up everyone,
    This plugin should have VR patching added to @value1 fixed heave plugin above. (2.0.2.0)
    Could someone with a VR setup please test out the patching and report if it works?
    Just like the new plugin above, you will need too...
    • Unpatch the game.
    • Load the new plugin with the Plugin Updater.
    Take care,
  15. Outatime
    Outatime New Member
    205Coins
    I have tried the new patch but movements were all wrong now.
    Can you post a screenshot of your axis assignment in GameEngine please ?
    I have tried to set different axis order but I gave up and returned to the previous plugin.
    Thanks.
  16. DotComRich
    DotComRich Member
    546Coins
    I actually had to reverse my pitch and roll.
  17. vin100lorant
    Beynes
    191Coins
    Hi, I have enough tested the new plugin proposed by value1 to say that it works perfectly with VR.
    I still had to review the direction of my axes that were being reversed.
    Now, I do not need to struggle between my VR helmet, the game in progress and the restart of the "game engine"!
    TOP thanks
    (Ps: i have not tested yet the 2.0.3.0 version...but i guess it will be ok)
  18. vin100lorant
    Beynes
    191Coins
    Version 2.0.3.0 works perfectly in VR (oculus).
    I tested with and without the "smooth" on the "heave" and it's all good!
    Thanks again!
  19. Marcocer
    Marcocer Member Gold Contributor
    France Allier Sussat
    - 262Coins
    good job ! and neccessary for Finland (new in France at 5 november )
    hug:
  20. yobuddy
    51,743Coins
