Dirt Rally 2 Plugin v2.3
SimTools plugin for Codemasters Dirt Rally2
  1. Bangkok Aerospace
    Bangkok Aerospace New Member
    - 49Coins
    So do I, Roll continue up, only pitch, and sway are correct
  2. Jean Paul Andrade
    Jean Paul Andrade Member
    272Coins
    at least now I know I don't have a Hardware issue, it must be something with the plugin. but nobody else is posting anything about it, I also noticed that TL data numbers are extremely low, not the same as Roll but never is higher that 0.00xxxx
  3. Sam MAHENDRA
    Sam MAHENDRA mahentheman
    Electrical Engineer
    Sydney Australia
    395Coins
    Hi, Could I use your Dirt Rally 2 - SimTools plugin for Codemasters Dirt Rally2 on my Steam versions of Dirt, DirtRally and DirtRally2?
  4. yobuddy
    51,741Coins
    @Sam MAHENDRA,
    This plugin is just for Dirt Rally 2 buddy.
    You would need the proper plugins for Dirt and Dirt Rally to get those working.
    Take care,
    yobuddy.
  5. Sam MAHENDRA
    Electrical Engineer
    Sydney Australia
    395Coins
    Thanks mate. Now I will download the Dirt Rally Plugin v2.3 and try it on my Steam version of DR2.
  6. Jean Paul Andrade
    272Coins
    hi @yobuddy can you please give me a hand with the issue I have with the Dirt Rally 2 plugin, I've posting about this in the tread, but nobody seems to know hoy to fix this, I have tried everything I could come up with, and the things noorbeast told me to do. but still no solution, I installed Drit Rally and works perfect, the problem is with 2.0 my Sim is based in arduino and SMC3 code, thanks in advaced
  7. yobuddy
    51,741Coins
    @Jean Paul Andrade,
    Sure buddy Private Message me!
    Its 3:24 am here now, so I'll answer when i get up tomorrow.
    Take care!
  8. Sam MAHENDRA
    Electrical Engineer
    Sydney Australia
    395Coins
    Hi @yobuddy, your DR2 plugin v2.3 is fantastic. I am really happy with it on my new 2DOF+TC Sim. Thanks mate.
  9. EvoSergio
    EvoSergio New Member Gold Contributor
    Las Palmas
    78Coins
    AYUDA por favor, cuando instalo esta nueva actualización, empiezo a correr y después de un corto tiempo el sistema de movimiento se detiene, ¿qué puede ser? Gracias.
    154,693Coins
    +11,210 / 57 / -2
  11. Arianus One
    Arianus One Tony Rom
    empleado
    Capilla del Monte,Cordoba, Argentina
    16Coins
    Can i send money to a specific simtools owners account of a bank or at administrator of the website, giving me details of your account so I can deposit dollars and give me enough coins in exchange to buy some plugins?
  12. noorbeast
    154,693Coins
    +11,210 / 57 / -2
    I have donated some coins so you can access plugins: https://www.xsimulator.net/community/shop/
    It is up to @RaceRay to consider how payment issues can be resolved.
  13. Arianus One
    empleado
    16Coins
    thank you very much noorbeast, eternally grateful for your good action, I hope that when quarantine ends I can contact my bank and fix the paypal issue.
  14. Arianus One
    empleado
    16Coins
    Noorbeast, I wrote to raceway on the paypal topic asking if there was another form of payment, but I still haven't answered.
  15. EvoSergio
    Las Palmas
    78Coins
    HELP, when installing this patch update, when I start running, it takes a while and the movement system stops. What can it be?
  16. Sam MAHENDRA
    Electrical Engineer
    Sydney Australia
    395Coins
    Mate, I had the same problem, till I used the correct path for patching. It's under patch in the "my games" folder , usually in documents.
  17. noorbeast
    154,693Coins
    +11,210 / 57 / -2
    The patch path differs depending on Windows being 32 or 64bit: https://www.xsimulator.net/communit...-32-bit-install-path-for-motion-patching.260/
  18. EvoSergio
    Las Palmas
    78Coins
  19. EvoSergio
    Las Palmas
    78Coins
    Hello partner, thanks for answering, tell you that I patch it on that route.
  20. EvoSergio
    Las Palmas
    78Coins
