Dirt Rally 2 Plugin v2.3
SimTools plugin for Codemasters Dirt Rally2
  1. michael münscher
    michael münscher New Member
    Germany Thüringen
    45Coins
    Geat work thank you
    154,675Coins
    +11,209 / 57 / -2
    Flagging this for @yobuddy to check out.
  3. Ciaoarturo
    Ciaoarturo New Member
    36Coins
    How did you get it to patch after loading the plugin? It keeps telling my it’s an invalid path. Do you have to run a single heat in a rally cross or a whole event? Thanks for any help!
    154,675Coins
    +11,209 / 57 / -2
  5. Ciaoarturo
    36Coins
    Thanks! Worked great to patch it.
    Any suggested setting for the profile? I have 4 actuators and set each to 50%, smoothing filter 4, game intensity 100%. During play the rig movement is very slight and feels delayed. Maybe my AASD crash filter setting is too sensitive?
    154,675Coins
    +11,209 / 57 / -2
    Here are some tips on how to refine a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    In particular it sounds like you need to capture the Max/Min values in the Tuning Center then tweak from there.
    Smoothing and other filters are not a good idea until you first have a solid base profile sorted.
  7. wacjpp
    wacjpp New Member
    39Coins
    Thanks.I think the effect of dirt rally 2 is really good. I need to adjust the data slowly.
  8. paulopsx2
    paulopsx2 Active Member
    brasil
    649Coins
    i just play this game now. my tips is: put your axis under 50%. Strong movements related in this game !
  9. the2jakes
    the2jakes Member Gold Contributor
    137Coins
    DC motor, Arduino, 4DOF
    does this pluggin work with Dirt Rally VR on Playstation 4 ?
    I have a PSVR+PS4, and would love to make my motion sim work with some PSVR games.
    154,675Coins
    +11,209 / 57 / -2
    No this is for PC, you need UDP plugins for PS4, @vthinsel has made a bunch of UDP plugins that will work with the PS4 for other sim titles, but not for DR2, see his comment here lamenting the lack of UDP support in DR2: https://www.xsimulator.net/community/threads/dirt-rally-2-0-ps4-udp-and-vr.13080/#post-173541
  11. the2jakes
    137Coins
    Thanx for the info Noorbeast. Is their a subject on PS4 & PSVR compatible games for Simtools ?
  12. noorbeast
    154,675Coins
    +11,209 / 57 / -2
    There is this overview in the FAQs: https://www.xsimulator.net/community/faq/consoles.27/category
    And if you look at the Downloads tab of @vthinsel's profile you can easily find his UDP plugins: https://www.xsimulator.net/community/members/vthinsel.15888/
    Once you have had a poke around you can start a thread here for any particular related topics or questions you may have: https://www.xsimulator.net/community/forums/new-users-start-here-faq.62/
  13. yobuddy
    51,739Coins
  14. The Iron Wolf
    The Iron Wolf Active Member
    Bellevue, WA
    375Coins
    3DOF, SCN6
    First of all, big thanks for the plugin :)
    I am struggling making SimTools to work with DR2. SimHub works fine. What port does Game Manager use? 4123 or 20777? I tried all combinations, but my rig moves briefly at stage start and stops.
    <motion_platform>
    <dbox enabled="true" />
    <udp enabled="true" extradata="3" ip="127.0.0.1" port="20777" delay="1" />
    <fanatec enabled="true" pedalVibrationScale="0.0" wheelVibrationScale="1.0" ledTrueForGearsFalseForSpeed="true" />
    </motion_platform>
    I did my homework, searched and reviewed FAQ and this thread - tried entering multiple UDP entries with different ports, even rebooted PC - no luck. As requested, single race completed. Thanks in advance and Happy Holidays!
  15. Kranky Pantz
    Kranky Pantz Active Member
    Canada, Eh!
    1,288Coins
    I believe that you can only have a single UDP entry in the game's config/xml file.
    Try to use one where the app (SimHub) can forward UDP to another app.
    That's what I've done to make it work.
    Sometimes it can be a "relay race" in getting all of your apps to work together.
    So in short, allow SimHub to patch the game, then in the SimHub game config tab you should see an area to forward the Port/UDP info to your motion rig (SimTools).
    Hope that helps!
  16. The Iron Wolf
    Bellevue, WA
    375Coins
    3DOF, SCN6
    Thanks a lot but I think I fixed it. This was missing (thanks @HardyG)
    <custom_udp enabled="true" filename="SimToolsCustomUDP.xml" ip="yourOwnIP" port="4123" delay="1" />
    I think patching fails to write those lines correctly. Both simhub and simtools work now, wooot!
  17. paulopsx2
    brasil
    649Coins
    works in the same ports?
  18. The Iron Wolf
    Bellevue, WA
    375Coins
    3DOF, SCN6
    no, that's not how UDP streams work, sorry for being confusing:
    <custom_udp enabled="true" filename="SimToolsCustomUDP.xml" ip="127.0.0.1" port="4123" delay="1" />
    You have to specify both, or use SimHub forwarding (did not test, not needed with DR2).
  19. LucasJJJohnson
    LucasJJJohnson New Member
    Minnesota
    - 29Coins
    How many coins do you need for this download? It says that I can't download the file and I don't have permission
  20. noorbeast
    154,675Coins
    +11,209 / 57 / -2
