Dirt Rally 2 Plugin v2.3
SimTools plugin for Codemasters Dirt Rally2
  1. Y K Sim
    Y K Sim New Member Gold Contributor
    - 156Coins
  2. cover4x4
    cover4x4 I love simracing
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    Today I had a while to tinker and as they had commented some foreros, the problem was in the configuration of the ports, since when I connected with SimHub I stopped working the movement of the simulator. It has been renaming the ports and everything works perfectly, both the movement with Simtools, and the vibration and Dashboard with SimHub. Now I will need to refine and put it to my liking.
    A greeting and thank you all for your help.
    Hoy he tenido un rato para trastear y tal y como habían comentado algunos foreros, el problema estaba en la configuración de los puertos, ya que al conectarme con SimHub me dejaba de funcionar el movimiento del simulador. Ha sido renombrar los puertos y funcionar todo perfectamente, tanto el movimiento con Simtools, como la vibración y Dashboard con SimHub. Ahora me faltará afinar y ponerlo a mi gusto.
    Un saludo y gracias a todos por vuestra ayuda.
  3. MPG
    MPG New Member Gold Contributor
    Netherlands
    57Coins
    Thank you very much it works perfect!!!!!!!!!!!
    hug:
  4. De Baas
    De Baas New Member
    Alkmaar
    302Coins
    3DOF, Motion platform
    Thanks, for the fast plugin, for me works perfect with my dofreallity p3.
    I did refine my motionprofile to my likings and changed direction box for pitch tough.
    But feels amazing.:)
  5. Doctor Kruntz
    Doctor Kruntz Active Member
    400Coins
    3DOF, SCN6
    Hello... after 2.4 SimTools update I have a problem with DiRT Rally 2.0.
    When I launch the game and normally start, driving any car, everything works perfectly and the 3 DOF dynamic actuators of my driving station move perfectly, but once the first test is completed if I try to re-enter the game again on a new track only the rear actuator (designed for loss of grip) works, while the other two (the front ones) stop working!
    Leaving the game, in the desktop the Game Engine icon flashes intermittently, turning blue, and if I enter directly in the SimTools Game Engine the Axis Assignments and Interface settings options flash blue also.
    Closing the SimTools Game Engine and then restarting it all returns to normal but only for the first track... if I continue for a second track, the problem reappears.
    This happens only on DiRT Rally 2.0 while on all other driving games this problem is not present.
    Before the last update DiRT Rally 2.0 did not present this problem.
    How could I solve this situation?
  6. yobuddy
    51,781Coins
    This is the new soft centering, this is normal.
    If you don't want it to do this, you can turn it off in the Tools section.
    It is confusing that only the back one works again.
    So it makes me wounder if you are using a USB hub?
    Or if the back actuator is plunged into a different bank of USB connections?
  7. Doctor Kruntz
    400Coins
    3DOF, SCN6
    yobuddy, no hub device, all 3 actuators are plugged directly back to the pc with their usb cables...
    Sorry, what should I disable to turn off the new soft centering?
    And why this problem only happens with DiRT Rally 2.0?
    But, at the same time, if this option is important to maintain for better operation of the actuators, how can I prevent the repetition of the problem in DiRT Rally 2.0 without disabling it?
  8. yobuddy
    51,781Coins
    first, swap plugs with the actuator that keeps working with one that does not.
    And then try your test again and let me know which one, if any, keep working?
  9. Grizus
    Grizus Member Gold Contributor
    Warsaw PL
    349Coins
    Hi after upgrade to simtools 2.4 I have the same problem. When I start first stage everything is good, simulator works but when I choose restart stage, moves just cut off, nothing happens with my simulator...
    I also noticed that after restart stage in Dirt 2, centering flashing into infinity in simtools, does not return to game mode
  10. yobuddy
    51,781Coins
    I'll take a peek buddy!
  11. Grizus
    Warsaw PL
    349Coins
    Thanks @yobuddy ! now I can not play dirt, please fix it as soon as possible :)
  12. yobuddy
    51,781Coins
    @Grizus
    Turn of soft centering and you should be fine.
    Take care,
  13. Grizus
    Warsaw PL
    349Coins
    @yobuddy
    I will try, but I use it for other games. This way maybe I avoiding the problem... I hope it is not a permanent solution ?
  14. yobuddy
    51,781Coins
    No, but if you want to play right now, it should work.
    May I see your axis assignments for Dirt please buddy?
  15. Grizus
    Warsaw PL
    349Coins
    thanks for the quick response, I'll be next to my simulator in 12 h so I will check this solution and I will do a screenshot of my settings
  16. Grizus
    Warsaw PL
    349Coins
    @yobuddy unfortunately, switching off soft centering does not help :(
  17. yobuddy
    51,781Coins
    Please turn of switching off soft centering and switching off soft startup.
    And give it a try.
    Take care,
  18. Grizus
    Warsaw PL
    349Coins
    @yobuddy
    unfortunately it also does not help
    turned off startup&resume
    turned off shutdown&centering
    and still during the first drive on stage there is motion on the simulator and when I take restart stage the motion disapired, regardless of whether it is enabled or not
  19. yobuddy
    51,781Coins
    Then it sounds like a plugin error.
    I'll take a look this weekend buddy. :thumbs
  20. yobuddy
    51,781Coins
    Is this happening to anyone else?
