Dirt Rally 2 Plugin v2.3
SimTools plugin for Codemasters Dirt Rally2
  1. noorbeast
    154,382Coins
    +11,179 / 57 / -2
    Are you using the latest version of SimTools and the latest version of the plugin?
    Did you unpatch and then repatch the game after installing the latest plugin?
  2. Tim Palmgren
    Tim Palmgren Maker / Motion Fanatic
    IT Recruiter
    Auckland, New Zealand
    82Coins
    3DOF, Motion platform, 4DOF
    Unpatched, repatched, latest simtools, latest dirt rally (reinstalled) just like everyone else in the thread we are all losing motion on pause, or changing stages.
    This is the only game where I get an 'NA' value on heave. This is also the only game where I have this issue.
  3. cover4x4
    cover4x4 I love simracing
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    Hi @noorbeast, I use Simtools version 2.4, but I am using the old Dirt Rally 2.0 plugin since I don't have enough credit to buy the new plugin and I'm not sure the new plugin fixes the problem. At first I got it to work a few times, but now the movement never works for me. If anyone could lend me credit to buy the missing plugin, I would appreciate it. (I use google translator)
    Hola @noorbeast, utilizo la versión 2.4 de Simtools, pero estoy usando el complemento antiguo de Dirt Rally 2.0 ya que no tengo suficiente crédito para comprar el complemento nuevo y no estoy seguro que el complemento nuevo solucione el problema. Al principio conseguí que funcionara unas veces, pero ahora ya no me funciona nunca el movimiento. Si alguién pudiera prestarme crédito para poder comprar el plugin que me falta, se lo agradecería. (Utilizo el traductor de Google)
    154,382Coins
    +11,179 / 57 / -2
    I have sent some coins so you can update and test.
  5. jakanana
    jakanana New Member
    - 77Coins
    Bonjour à tous, j'ai réussi à installer le plugin et ça fonctionne, mais il n'y a que sway et surge qui marchent , pour pitch, roll et heave : aucun mouvement .. est ce normal ? Tous mes axis sont bien paramétrés , et ça fonctionne sur d'autres jeux ...
    Merci
    Hello everyone, I managed to install the plugin and it works, but it's only sway and surge wich work, for pitch roll and heave: no movement .. is this normal? All my axes are well set, and it works on other games ...
    Thank you
  6. JZargo
    JZargo New Member
    business owner
    morciano di romagna
    83Coins
    3DOF, Arduino
    yes all done i try all the basic .... when i press esc immediatly stuck
  7. pmvcda
    pmvcda aka FlyPT
    Portugal
    15,794Coins
  8. yobuddy
    51,656Coins
    Hi Guy's,
    I have seen people having problems with this title.
    It's strange how some people do not have these errors thou.
    If its not working for you, can you post if your using VR or Monitor.
    And maybe what actuators or sim type your using.
    Maybe we can narrow down where the error is a bit.
    BTW, I should have internet up at my new place on the 26th.
    For now i just jump on when at a friends house.
    So responses may be slow for a couple of days.
    Take care!
  9. JZargo
    JZargo New Member
    business owner
    morciano di romagna
    83Coins
    3DOF, Arduino
    Hi and thak you for the attention...:)
    just installed a fresh copy of win 10 home.
    last geforce drivers
    arduino installed version and 1.05
    without oculusVR and without SteamVr installed to figure out if it was the problem
    tried dirt 2.0 steam version, but also oculus home version (I also have
    that) does equal.
    patch and repatch as obvious
    use analog actuators ( a friend of mine have similar and all go well)
  10. JZargo
    JZargo New Member
    business owner
    morciano di romagna
    83Coins
    3DOF, Arduino
    Guys I found a solution, at least for me ...
    I downgrade to the v2.3.1 version of ST ...
    I noticed that the re-centering options are missing in Output Testing in this version ... Perhaps the problem to do with this? in fact I was going to blink and had to restart ST manually, and my actuators re-entered when they stopped at the menu entry, and now they stay where they are, but everything flows
  11. Martyn
    Martyn Member
    Europe
    29Coins
    2DOF, SCN6
    I again have same problem like rest of guys here (and which i used to have before).
    Well my rig (scn6 seat mover, latest simtool, latest plugin, using vr - pimax) did the same trouble - motion working only until pausing the game THEN ONLY EXTRA 1 works..
    Then i reinstalled the computer completly and voila all works fine..
    Just UNTIL NOW:( i ´m trying to fine tune graphics for pimax so i downloaded hadrwaresetting_vr.ini with recommended graphic setting for pimax, updated with line for simtools and problem is back - motion only works fine until pausing the game, then again only extra1 works... i tried restoring my old hadrwaresetting_vr.ini, tried unpatch and repatching game, noooo help:(
  12. JZargo
    JZargo New Member
    business owner
    morciano di romagna
    83Coins
    3DOF, Arduino
    *i say Output Testing I mean Tool option sry mistake
    I dont use translator
  13. JZargo
    JZargo New Member
    business owner
    morciano di romagna
    83Coins
    3DOF, Arduino
    Are you on last version of Simtools... try 3.1 version, work for me
  14. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    Thank you very much @noorbeast, unfortunately I am now away from home for two weeks, on the way back I will test how it is, if the new plugin solves the problem with the movement, because in Assetto Corsa and in Dirt Rally 2.0 it is where everything worked best. I'll tell you ... (I use Google translator)
    Muchas gracias @noorbeast, por desgracia ahora estoy fuera de casa dos semanas, a la vuelta probaré qué tal, si el nuevo plugin soluciona el problema con el movimiento, porque en Assetto Corsa y en Dirt Rally 2.0 es donde mejor funcionaba todo. Ya os contaré... (Uso traductor Google)
  15. paulopsx2
    paulopsx2 Active Member
    brasil
    648Coins
    is anyone test with new windows store version ( xbox game pass )??
    i just download game ( 82 gb ) works with vive pro, t500rs but no telemetry. its impossible to patch winapp folder !
  16. Martyn
    Martyn Member
    Europe
    29Coins
    2DOF, SCN6
    I have 2.4 which i ´m overall VERY happy with, only DR2 causing troubles, otherwise 2.4 is big step forward for me..
    Would like to avoid downgrading to 2.3 again:(
  17. paulopsx2
    brasil
    648Coins
    well, i just delete DR2 from windows 10 store and buy a steam version. Put game offline, and no savegame created. How can i do it?
  18. paulopsx2
    brasil
    648Coins
    please... how can i patch this game? nothing appears on "my documents, my games, dirt rally 2.0, savegame" its empty ! steam version, i try to play and some progress in career, then put offline, play some other things but no local savegame appears ! patch on game manager says: " the select patch is not valid to patch "
    try some BWW data file in C:\Program Files (x86)\Steam\userdata\135213117\690790\remote
    the same message on game manager.
  19. noorbeast
    154,382Coins
    +11,179 / 57 / -2
    Have you run a race before trying to patch it?
  20. paulopsx2
    brasil
    648Coins
    Yes.. i try Career, single, some historic Seasons... Its weird, game dont put any files on local save ! ( By The way, i uncheck steam cloud save on client to ). Maybe If someone upload a savegame , and confirms the way to patch...
