DIRT3 compatible?
Discussion in 'DIRT 1 - 3' started by aikuo60, May 24, 2011.
  1. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    810Coins
    Hi Guys,
    Same problem here... Steam version. I now will test the boxed version, and will not update it. too bad, in the latest patch they fixed some major bugs, such as the controller save setup.
    If anyone has a solution, please share ;-)
  2. bsft
    Face it , Steam sucks!
  3. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    It`s not because of Steam - this patch cause the trouble. I`ve checked boxed version with update (1.2) and still have the same problem. :thbd:
  4. bsft
    True, I managed to get version 1.0 and did not install any patched, all good here.
  5. japdos
    japdos New Member
    The problem is extradata=1
    dbox use extradata=0
    I'm an frex system user converted to a xsim.
    -With xsim (extradata=1) and the 1.2 patched version of dirt 3 the game freeze at finish line.
    (solution-->downgrade to 1.1 patched version)
    -With simconbase and simconmotion (extradata=0)and dirt 3 1.2 patched, the game DON'T freez at finish line.
    I prefer xsim system so I would like a 1.3 patch soon...
    Are there any profile to using with extradata = 0?
  6. prosimu
    prosimu Member Gold Contributor
    - 900Coins
    Hi all,
    It could be interresting to know if the patch 1.02 worked with the freeplug version?
    Patrick
  7. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    We need extradata=1 to get this game running with X-Sim Profiler.
    This one is different then Grid and Dirt 2. Game doesn`t stop when value is set to 0 but it also doesn`t work with Simulator.
  8. splendiddd
    CCTV security
    Netherlands
    810Coins
    Ok so I've changed from steam to a boxed version without updating, now it works great again, apart from the controller mapping bug and the frame drop in gymkhana.... :)
    Friend of mine driving:
    http://www.youtube.com/watch?v=UpQVu7rhfVE&f
    Cheers :cheers:
  9. bsft
    woohoo!!!! I gotta buy some projectors! Granted I am only running 2 cards sli, but Vaaarooommmm!!!!!
  10. splendiddd
    CCTV security
    Netherlands
    810Coins
    Yeah, i will never go back, triple pj are the best for inmersion ;-) BTW: quad-sli means 2xGTX295 dual pcb ;-)
    Anyway i really hope the solve this issue with another patch...also really hope this bug is not in F1 2011 that's comming in a few weeks time.
    Regards
  11. bsft
    The GTX 295 is a good dual gpu card and having two of those in SLI is even better. I only have 2 x GXT 560ti SLI. They should do the job though.
    Anyway, lets hope the problem gets sorted. We are a minority group with motion sims and codemasters would probably put our issue on the bottom of the to be fixedlist.
    Back to racing!
  12. Shadoogie
    Shadoogie New Member
    Hi japdos can you tell me where or what simconbase and simconmotion are /
  13. bleco
    bleco Member Gold Contributor
    IT Problem Coordinator
    Montréal, Canada
    258Coins
    Hi Splendiddd,
    I did not have any problems running F1 2011 with X-Sim and Dirt 2 plugin ... no errors like in Dirt3
    Regards
    Bleco
  14. bsft
    do you mean F1 2010?
  15. bleco
    Montréal, Canada
    258Coins
    ... no 2011 ... We could download it earlier in Canada and US ...
    it's working fine ...
    Bleco
  16. bsft
    well codemasters have been busy writing games, now perhaps they could write a GRID2.
  17. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    815Coins
    2DOF, SCN5
    NO problems here, update 1.02, steam version, x-sim 2070, extra data 0 :yes:
  18. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    It use to be port=20777. Did you change it ? Because if - then it might be that. For me it didn`t work with extradata set as 0.
  19. Hobbs77
    Connecticut, USA
    815Coins
    2DOF, SCN5
    Dirt 3 runs great with x-sim release version 2070, there are different versions of x-sim. I haven't tried any other version like 2071 or newer. The game, hardware, motion settings are the same as Dirt 2 to get motion. I have not had any problems running Dirt 3 from day 1 or with any updates. So maybe someone can figure it out from there. Win 7 64
  20. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    I am on 2089beta so it might be it. Can someone confirm this issue on his version.
