DIRT3 compatible?
Discussion in 'DIRT 1 - 3' started by aikuo60, May 24, 2011.
  1. bleco
    bleco Member Gold Contributor
    IT Problem Coordinator
    Montréal, Canada
    258Coins
    Same thing here ...
    Dirt 3 Steam
    2.0.8.9
    Win 7 64
    I did not test earlier X-Sim releases ...
    Bleco
  2. bsft
    I have windows 7 64 bit, and have run dirt 3 with 2089 and 21013 beta versions of x-sim. Runs fine. Now if I can figure out why GRID crashes randomly!
  3. bleco
    Montréal, Canada
    258Coins
    @bsft, you already mentioned that you did not install the lattest dirt 3 updates... It seems to be related... Maybe the combinaison of lattest x-sim releases and lattest dirt 3 patch...
    Bleco
  4. bsft
    Bleco, thats correct, i did not install any dirt3 patches. The game works do I am not going to mess with it.
    It is GRID I am having trouble with to get to run properly.
  5. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    875Coins
    2DOF, SCN5
    So can anyone else run dirt 3 with all the latest updates? If so, please list what download version of x-sim your using. Thank you!
  6. rafael_design
    rafael_design Member
    CGI Architectural Visualizations with Blender 3D
    Brasil
    329Coins
    Hi, I found that it's true that the problem of having the game freezing at finish line is caused by extradata 1 + DIRT 3 patched. Extradata 0 game works but I have no motion with new versions of x-sim...
    I have steam version of the game but I backed up the original files before any updates so it's almost like if I had one boxed version (unpatched) :yes: but the problem is that if I do not update the game I cant save my progress and play online...
    How can I get the x-sim release 2070 or any older than the latest to try? I tryed to download older versions at download section but all links are broken...
    :cheers:
  7. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    Just wait for another game update. It usually mess something new and fix the older one.
  8. rafael_design
    Brasil
    329Coins
    It means that I can use Live4speed plugin to play Dirt3 with Extradata 0 ?
    Well I tryed that but did not work... Maybe I should wait for new patch or new game :rofl:
    Thanks anyway sirnoname.
    :cheers:
  9. misiek3510
    misiek3510 New Member
    Hello all, I bought 2 days ago full retail box version of Dirt3. Is there any way to not update this game but use save function in game? Now when I start game it tries automatically download updates but I don't want them because then motion chair is not working anymore. When I press no then I just cannot log to my Live account. Is there any solution for this?
  10. bsft
    Try to have the net disconnected as a start when you start the game.
    Also are you using a GFWL offline account?
  11. edengoldyon
    edengoldyon New Member
  12. misiek3510
    How can I use GFWL offline ?
  13. bsft
    You need to create an offline account, follow this http://www.youtube.com/watch?v=ulVRWweWbp0
  14. misiek3510
    Thx bfst. I can create offline account but I cannot start Dirt 3 with onffline account it says that only online account can make save to my profile.
  15. bsft
    Thats weird, I use an offline account, I start the game, press the home button and select the account to save the games. Unless you have to start all over again with new games with an offline account. :?
  16. misiek3510
    Yeah its weird but finally I managed to run it offline without update and with working save option in other way :)
  17. bsft
    Good stuff... :thbup:
  18. xtech007
    xtech007 Member
    29Coins
    DIRT3 & Sender not communicating
    After few hours of trying different settings and forum search, I turn to the Wise ones!
    I Can Not make Force sender communicate with dirt3.
    Using Dirt2 plugin and change extradata to 1 and still no luck.
    this is what my config file looks like:
    <motion enabled=true ip=127.0.0.1 port=20777 delay=1 extradata=1 />
    </hardware_settings_config>
    on the outsim the ck mark for game pause never goes away even if I'm actually playing the game.
    Can not get any speed,RpM , or any data.
    I'm Running sender, Profiler, and game on same pc.
    Also changed extradata to 0 and no luck.
    is there anywhere I can change the Port?
    How would I know what port to use?
    Can someone guide me the right direction Please!!! :sos:
  19. bsft
    Try 20777 to 20778.
    Everything else should be fine.
  20. xtech007
    xtech007 Member
    29Coins
    Thank you for the reply!
    Will try when I get home. Will post my findings!
