DIY 2 DOF on a budget
Discussion in 'DIY Motion Simulator Projects' started by Denis Mowberry, Aug 21, 2023.
  1. Denis Mowberry
    Denis Mowberry Member
    New Zealand
    89Coins
    Help please I have replaced my 12v wiper motors and power supply with 250watt 24v gear motors and new 24v power supply . When I go to SMC3 I have no control over the motors . If I select motor 1 it just runs continuously at full speed motor 2 at half speed. Selecting sine makes the motors turn back and forward but not at all matching the sine wave 3 or 4 full turns in either direction .Just don't know where to start .
    153,788Coins
    +11,150 / 57 / -2
    Are the pots connected and functioning correctly?
    Did you redo the SMC3 setting from scratch:
    1. Disconnect the motor power supply
    2. Make sure Simtools is not running – we’re not ready for that yet!
    3. Wire up the Arduino (with SMC3 installed) to your H-Bridges and connect to your computer via USB
    4. Run the Windows SMC3 Utility software and make sure it communicates with the Arduino (There is no need to set baud rates, they are not configurable)
    5. Set the Kp, Ki, Kd, PWMmin, PWMmax, PWMrev to 0 for ALL motors (This will make sure the motors don’t move)
    6. Set Clip to 255 (you need to do this first) and Limit to 255 (This will give you plenty of margin if something goes wrong while setting up)
    7. Turn on the power to your motors – nothing should move at this stage!
    8. Set Kp to about 400
    9. Now slowly, increase PWMmax… at some point the motor should start to move. When it does check the “Green” feedback line is moving toward the “Blue” target position.
      • If it is then that motor and feedback is wired correctly - proceed to test other motors.
      • If it is moving away turn off motor power immediately (or quickly reduce PWMmax again). In this case you need to either reverse the wires to the motor being tested –OR– reverse the +5V and GND wires to your feedback pot for the motor being tested (do not do both). Restart the test from the beginning.
    10. Do the above for each motor
  3. Denis Mowberry
    New Zealand
    89Coins
    I had an issue with my rig in that one of the three motors stopped working so I assumed it was the IBT2 and replaced it . At the same time I decided to rebuild my electronics box to make it more tidy and accessible . My problem now is when I put power on using SMC3 software the motors just spin until they exceed the limits and then turn off. I have checked the wiring numerous time and I believe it is correct any suggestions please.
    153,788Coins
    +11,150 / 57 / -2
    Poor grounding and/or isolation are potential causes, as is possible hardware faults of control boards, pots or wiring.
    If you moved USB around check that the ports are still correct.
    Take a systematic approach to eliminate possibilities one by one.
