Showroom DIY 2DOF simulator
Discussion in 'DIY Motion Simulator Projects' started by Erwan960, Sep 27, 2013.
  1. Mo165
    Mo165 Member
    Austria
    103Coins
    Very cool Sim!
    Your work inspired me;)
  2. MiNeM
    MiNeM ..........
    Self Employed
    Johannesburg
    333Coins
    Very nice...
  3. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    @Erwan960 - Would you be able to post / mind sharing the dimensions of your simulator? I like the middle ground between ultra compact and full frame and I have the chance to get some T-Slot Alu Profile and want to check I will have enough to make a similar frame...
    Just Length and Width will be fine as I will likely change the heights to suit, but if you do have all the dimensions, even better.
    Also, what profile sizes did you use 30x30? 20x40?
    Thank you.
  4. hunter03
    hunter03 New Member
    472Coins
    join previous message.
    20x20?
    30x30 or 40x40?
  5. Erwan960
    Erwan960 Active Member Gold Contributor
    3,832Coins
    I used 40x40 and 80x40 for the Wheel and speakers support.
    It is really strong !
    The global dimensions are : 78 cm x 140 cm
    The dimensions of the rig only are : 78cm x 120 cm
  6. Archie
    Wollongong, NSW, AU
    3,797Coins
    Thank you :thumbs
  7. hunter03
    hunter03 New Member
    472Coins
    thank you so much. helped define.
  8. Dusko Dogandzic
    Dusko Dogandzic New Member
    456Coins
    amazing project
  9. ho123
    ho123 New Member
    belgium
    198Coins
    Arduino, 6DOF
    nice work!!!
  10. michto35
    michto35 Member
    france
    92Coins
    Salut Erwan,
    Félicitations pour ton simu il déchire :thumbs
    Je voulais demandé des renseignements sur le prix des moteurs que tu as acheté, plus précisément du réducteur.
    Donc je voudrais contacter le site ou tu t'es fourni, mais sur le PDF des réducteurs je peux voir quand on commande il y a des options 5 au totales.
    Je te parle de la ligne qui site comme exemple ZYT80 147 24 MCP4 25:1 AD DR MRB EC CS##
    Pour la config de tes moteurs je pense que ça devrait ressembler ZYT90 155 24 MCP4 60:1.
    Mon problème est que je ne comprend pas ce que veulent dire les initiales en fonction des options, lequel à tu choisi?
    Merci à toi des renseignements
  11. Erwan960
    3,832Coins
    Pour les moteurs, ce sont des ZYT90-155 (90 mm de diamètre et 155 mm en longueur).
    Ensuite ce sont des moteurs 12 V (qui peuvent aussi tourner en 24V) équipés d'un réducteur de type MCP4 avec un rapport de réduction de 60:1.
    J'ai testé les réducteurs de 60:1, 50:1 et 25:1. Les deux premiers sont irréversibles, ce qui permet de stabiliser ton châssis lorsque les moteurs ne sont pas alimentés (tu peux monter dessus, rien ne bouge).
    Par contre avec des réducteurs de 25:1, la plateforme n'est pas stable à l'arrêt. Et selon la position des moteurs, le châssis peut s'affaisser lorsque tu prends place dans le siège.
    Si ça t'intéresse, il me reste 2 réducteurs MCP4 50:1 (avec roue dentée métallique, gage de qualité) et 2 excentreurs découpés au laser. Il suffit d'ajouter une clavette pour les assembler (je n'en ai plus, il faut donc les faire ou les acheter).
    Au niveau des moteurs, il ne me reste que des ZYT90-199, trop puissants pour être pilotés par des JRK12V12.
  12. Erwan960
    3,832Coins
    This morning, one of my motors stopped working. I first thought it was a failure of the power supply. But I changed it without success.
    After a few seconds, white smoke came out of the main chip of JRK. The JRK is still recognized by USB but when powered it burns !
    The JRK was equipped with a heat sink and was well ventilated. A blistering is visible on the chip.
    I contacted Pololu support to know what they advised me to do. The JRK is still under warranty ... I am waiting for their answer.
    The coming days may be long without cockpit ! :-(
  13. noorbeast
    154,693Coins
    +11,210 / 57 / -2
    Prior to changing the PSU were there any error messages that would indicate something going wrong?
    Do you have fuses as part of your wiring circuit?
  14. Erwan960
    3,832Coins
    No error message and no fuse burnt (no short-circuited).
    I also set a maximum current level (30 A) and it has not been exceeded (No "max current exceed" error when I had the problem).
    The motor works fine when I power it directly.
    I really don't understand why the JRK burnt (only one of the two).
  15. noorbeast
    154,693Coins
    +11,210 / 57 / -2
    It is highly unusual. I could understand it if there was no cooling fan but it is odd for a JRK to just give up the ghost with no contributing factors.
  16. Erwan960
    3,832Coins
    That's the reason why I contacted Pololu to try to see more clearly... Anyway thank you for your advice.
    This is how the JRK and the power supplies are cooled : one 120 mm fan per JRK and one 140 mm fan for the power supplies.
  17. noorbeast
    154,693Coins
    +11,210 / 57 / -2
    Plenty of cooling there...I have a single 120mm fan cooling 3 JRKs and even that works fine.
  18. michto35
    michto35 Member
    france
    92Coins
    Merci de tes renseignement.
    Je voudrais créer l'effet yaw, vend tu tes moteurs à l unité?
    Quelle serais ton prix?
    A bientot
    Thank you for your information.
    I would create the yaw effect, you sell your motor to unity?
    What would be your price?
    See you soon
  19. Erwan960
    3,832Coins
    Voici le moteur en question. J'en ai 2 à disposition, neufs.
    Référence
    - 90ZYT-199-12
    Principales caractéristiques
    - 1.2 Nm en sortie d'axe
    - 1500 tours/min sous 12V
    - 3000 tours/min sous 24V
    - Format IEC 63B14
    - Arbre de sortie diamètre 11m à clavette
    Je les ai payés 100 € pièce et je peux les revendre à l'unité sans problème. Fais moi une offre par MP. Si elle est raisonnable, le moteur est à toi.
  20. aboodix5
    aboodix5 New Member
    Baghdad-Iraq
    328Coins
    design and size of platform? motor location and chaire center diagram
