Showroom DIY 2DOF simulator
Discussion in 'DIY Motion Simulator Projects' started by Erwan960, Sep 27, 2013.
  1. Erwan960
    Erwan960 Active Member Gold Contributor
    3,832Coins
    It is not perfectly aligned, but the gap is minimal compared to the schema.
  2. MotoGatto
    MotoGatto New Member
    Torino
    450Coins
    It means for the first design ??
    the second is the angle to keep and what ?
    Thanks again !
  3. Erwan960
    3,832Coins
    Yes for the first design.
    The second one is perfectly done.
    The vertical red line has to cut the blue segment in its center.
  4. MotoGatto
    Torino
    450Coins
    They had noticed it !!
    Meanwhile, I thank you because I have provided some good answers and you've been very kind !!
    thank you
  5. Erwan960
    3,832Coins
    You are welcome. ;)
  6. cruzebabuze
    cruzebabuze Active Member
    135Coins
    wooh that looks real good,
  7. skano ca
    skano ca tH3 bR1igHt3st star 1n the c0nst3llat10n HydRa
    engineer
    Malaysia
    102Coins
    very nice rig. looks neat
  8. Jamburglar
    Jamburglar Member Gold Contributor
    Controls Engineer / Software Engineer
    Michigan
    186Coins
    Awesome job. I think this rig may have saved me some headache. I was thinking of doing a 6dof for my first rig and watching your videos showed me I can get the effects I want with two dof. Thanks a lot!
  9. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Lavoro semplicemente superbo! Leggendo il post ho notato che sui monitor è presente una telecamera per Oculus Rift DK 2. Qual'è la tua impressione d'uso dell'Oculus al posto dei monitor con il simulatore? Grazie.
    Simply superb job! Reading the post I view the positional camera for the Oculus Rift DK2. What is your impression of dell'Oculus use instead of a monitor with your sim? Thank you.
  10. ilbiga
    Network Engineer
    103Coins
    Un'altra domanda: se non ho capito male, alla fine hai installato:
    2 x 90ZYT-199-12-1500-F90-D11
    2 x Worm Drive Gearbox to Suit Industrial motors 60:1
    E' corretto? Potresti gentilmente postare il link per acquistarli?
    Grazie.
    Another question : If I understand it , in the end you have installed :
    It's correct? Could you please post the link to buy them ? Thank you.
  11. Erwan960
    3,832Coins
  12. ilbiga
    Network Engineer
    103Coins
    Grazie per l'informazione!
    Modello n° 11, giusto? 64 RPM and 30 nM? E' corretto?
    Se non ho capito male, su questo modello è possibile scegliere direttamente il motoriduttore 60:1.
    Grazie ancora
    Thanks for the information!
    Model n° 11, right? 64 RPM and 30 nM? It's correct?
    If I understand it, on this model you can directly choose the gearbox 60:1 .
    Thanks again
  13. Erwan960
    3,832Coins
    I'm using #15 3200 rpm / 60:1 but #11 3200 rpm / 50:1 works fine to.
  14. ilbiga
    Network Engineer
    103Coins
    Grande notizia (e prezzo :'( ...). :D
    Un'ultima domanda: perché hai utilizzato 12v e non 24V? Le correnti non sono troppo alte?
    Great news (and price :'( ... ). :D
    One last question: why did you use 12V and not 24V? The currents are not too high?
  15. Erwan960
    3,832Coins
    Because I owned two of them and I wanted to use JRK 12V12.
    I set the JRK not to exceed a peak current of 30A.
  16. ilbiga
    Network Engineer
    103Coins
    Perfetto!
    Io uso Sabertooth 2x25A. Credo che prenderò il modello n° 16 a 24V.
    Grazie ed ancora complimenti per il tuo fantastico lavoro! :grin
    Perfect!
    I use Sabertooth 2x25A. I think I'll take the model n° 16 at 24V .
    Thank you and congratulations again for your great work! :grin
  17. Casey Pareni
    Casey Pareni MasterP
    Firefighter
    Arizona
    350Coins
    This was the project that got my friend and I excited about doing our first simulator. Of all the awesome and over the top sims Ive seen here this one is still my favorite. I really love all of your sims.
  18. ilbiga
    Network Engineer
    103Coins
    Ciao Erwan960, una domanda: i motori che utilizzi (modello #15 3200 rpm / 60:1) sono isolati o sono necessarie modifiche per scollegare la massa dal case esterno?
    Grazie
    Hello Erwan960, a question: the engines you are using (model #15 3200 rpm / 60:1) are isolated or changes are necessary to remove the mass from the external case?
    Thank you
  19. Erwan960
    3,832Coins
    No change is needed. They are ready to be used :)
  20. ilbiga
    Network Engineer
    103Coins
    Ottimo! Grazie! ;)
    Great! Thanks! ;)
