Showroom DIY 2DOF simulator
Discussion in 'DIY Motion Simulator Projects' started by Erwan960, Sep 27, 2013.
  1. Erwan960
    Erwan960 Active Member Gold Contributor
    3,832Coins
    I used profile of 40x40 for the rig, 80x40 for the Wheel support and speakers.
    The rig is 78x120 cm.
  2. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    Thank you! :D
  3. razzta02
    razzta02 New Member
    Sales
    Spain, Canary Islands
    378Coins
    4DOF
    Hi Erwan,
    I like your sim, really nice looking!
    I am reading and trying to make up my mind about what sim to build. Could you mind and share with me the measures of the alu structure? I only need the alu tubes dimensions (length) so that I can ask for a quote to an overseas alu maker. I live far away from him so I need to check for shipping and customs costs before I even think about building it.
    Are your alu tubes the standard model or the re-inforced one?
    Also, I don´t know if you still keep any sketches from your project?
    Thx in advance.
    Rgds.
  4. Javier Diez
    Javier Diez New Member
    Student
    Leon, Spain
    120Coins
    2DOF, Arduino, JRK
    Awesome project!
    May you show us how is the electronic circuit?
  5. engenharia
    engenharia New Member
    Brasil
    231Coins
    thanks for sharing...
  6. Mo165
    Mo165 Member
    Austria
    103Coins
    Hy, where did you find the path for patching pcars?
    I installed the game normally.
  7. Erwan960
    3,832Coins
    YOURSTEAMFOLDER\steamapps\common\pcars\ ?
  8. Mo165
    Mo165 Member
    Austria
    103Coins
    Thank you very much!
  9. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Hello Erwan960, I have almost completed my work, but I have a new problem: when the engines change direction my power supply (24V , 480W ) goes into protection for about two seconds due to motor current peaks.
    What kind of power supply you used for your fantastic work? Thank you!!! ;)
    Ciao Erwan960, ho quasi completato il mio lavoro, ma ho un nuovo problema: quando i motori cambiano direzione il mio alimentatore (24V, 480W) va in protezione per circa due secondi a causa dei picchi di corrente dei motori. Che tipo di alimentatore hai usato per il tuo fantastico lavoro?
    Grazie!!! ;)
  10. lcturkey
    lcturkey Member
    163Coins
    Did you use Oculus Version of Project Cars ? I cant get movement from Project Cars Plugin ?
    Thank you.
  11. amir farid abdul gani
    amir farid abdul gani New Member
    malaysia
    335Coins
    Your motion rig design is always be my dream..i will gather all the parts and make this
  12. moecia
    moecia New Member
    93Coins
    Arduino, JRK, Motion platform, 4DOF
    nice work!
  13. moecia
    moecia New Member
    93Coins
    Great work!
  14. Erwan960
    3,832Coins
    When the engines change direction, the current can rise to 30 A. My power supplies can deliver 50A. So the limit is on the Pololu JRK which can support about 30A peak during a very short time. That's the reason why I put some fuses to protect it.
  15. razzta02
    razzta02 New Member
    Sales
    378Coins
    4DOF
    Hi Erwan, have you ever thought about adding traction loss? do you have a design in mind?
    Rgds.
  16. smoukn
    smoukn New Member
    Developer
    Maribor
    261Coins
    Hi Erwan960!
    I just want to say awesome work! Your sim is great, and I want to build one like yours. I am just reading everything first, to get the feeling what will I need for the build.
  17. Erwan960
    3,832Coins
    Thank you.
    @razzta02: no traction loss expected for the moment
    @smoukn: take your time now to do things you based on the experiences on the forum, you will gain so much time after ! To get to this version, it took me over 3 years !
  18. STEPHANIE
    STEPHANIE Member
    HOYMILLE
    414Coins
    VERY GOOD PROJECT
  19. smoukn
    smoukn New Member
    Developer
    Maribor
    261Coins
    @Erwan960: ok, so it's time to start reading, learning and thinking. I just hope, I will have the sim ready before 3 year time :)
    • Funny Funny x 2
  20. Jewly
    Jewly New Member
    Korea, Republic
    222Coins
    Good!
