Showroom DIY 2DOF simulator
Discussion in 'DIY Motion Simulator Projects' started by Erwan960, Sep 27, 2013.
  1. Meawto
    Meawto Sorry for bad English ;'(
    Thailand
    - 336Coins
    what do you use for hold all your system ? wood or metal ?
  2. Jewly
    Jewly New Member
    Korea, Republic
    222Coins
    Wood?? metal?
    I am making using wiper motors.
  3. Meawto
    Thailand
    - 336Coins
    black plate on the floor
  4. Jewly
    Jewly New Member
    Korea, Republic
    222Coins
    바닥 [/ QUOTE]에 검은 접시 [QUOTE = "18270 게시물 Meawto, : 118,768, 회원"]
    I'm making metal.
    I'm thinking about welding too.
    Will Wood be weak?
  5. sujianping
    sujianping New Member
    fuzhou
    181Coins
    On the sim can learn a lot.
  6. Rtorni
    Rtorni New Member
    Argentina
    187Coins
    Great Work!!!
    Thanks for sharing
  7. gigi
    gigi Active Member
    920Coins
    2DOF, JRK, 4DOF
    Hallo,
    Can you please explain your jrk setting to avoid exceed peak current of 30A? I have 4similar motors that have 23A nominal and 40A peak like yours, but I would like control them using jrk12v12
    Gigi
  8. gigi
    gigi Active Member
    920Coins
    2DOF, JRK, 4DOF
    Hallo,
    Gigi
  9. eaorobbie
    20,508Coins
    I run this setting at 0 , if your communication (usb) is a little poor having the pid period too low will cause an error too.
    I set pid period at 20 and unlimited on amps (0) , no errors.
  10. Blame73
    Blame73 Well-Known Member
    8,316Coins
    Have you got pictures of your settings? I don't understand what values are you running at 0.
  11. gigi
    gigi Active Member
    920Coins
    2DOF, JRK, 4DOF
    Hi Earobby!
    you're always in my thoughts, every time I start my simulator. Memories was the summer of 2014 You passed 4/5 hours with me in helping me to Skype configure my You are and remain my hero!
  12. gigi
    gigi Active Member
    920Coins
    2DOF, JRK, 4DOF
    I open a new thread last day for my problem here https://www.xsimulator.net/community/threads/90zyt-155-12-mcp4-60-1-and-jrk-12v12.9662/.
    I love Jrk 12v12 and I would like to use them with my new motors ZYT90-155-12-MCP4 60:1 180W 23A continuos and 40A peak. Jrk 12V12 have a limit of 30A peak, if it is possible to control these motors also with jrk I'd be happy
  13. noorbeast
    154,837Coins
    +11,227 / 57 / -2
  14. Blame73
    8,316Coins
  15. Nick Moxley
    17,057Coins
    Motor Tab Blame. Max Current.
  16. Erwan960
    Erwan960 Active Member Gold Contributor
    3,832Coins
  17. gigi
    gigi Active Member
    920Coins
    2DOF, JRK, 4DOF
    Thanks Ervan , setting 2.997 my motors that have 40A current peak can be control from jrk 12v12 that have 30A peak....no error no jrk smoke?
  18. gigi
    gigi Active Member
    920Coins
    2DOF, JRK, 4DOF
    Another question....wich fuses did you use and were you put them?
  19. Blame73
    8,316Coins
    He was answering to me on where to put the 0 value
  20. Erwan960
    3,832Coins
    This is just a snapshot showing the location of the setting. Just put 30 as you can see there : https://www.xsimulator.net/community/threads/diy-2dof-simulator.4793/#post-45606
    I put 33A fuses between the power supply and the JRKs. They are only there to protect the JRKs.
