Showroom DIY 2DOF simulator
Discussion in 'DIY Motion Simulator Projects' started by Erwan960, Sep 27, 2013.
  1. bsft
    @Deijan5 , you need to have 12v12, 21v3 not powerful enough.
  2. bsft
    @Erwan960 , @eaorobbie , I fitted 60:1 boxes today to my mates sim, they are near impossible to move with no power on them, they should keep the sim stable when its off.
  3. Erwan960
    Erwan960 Active Member Gold Contributor
    3,832Coins
    So you use now model #11 ?
    12V / 3200 RPM / 60:1
  4. bsft
  5. Erwan960
    3,832Coins
    Shane made me the shipping cost 70$ less than before. It's a little bit better !
    When I ask him how to reverse the shaft side :
    "you can convert them from right to left by pulling the gearboxes apart (you need to pop the rivets out with a punch) then by tapping the main shaft out of the main worm gear with a soft hammer and turning it around and reinserting it into the main worm gear and then reassembling it."
    It only remains for me to order!
  6. bsft
    yep, thats how I did it, a lot of swearing here though, as I only have a concrete garage floor,a vice and a block of wood and 3 pound hammer, I just bought some bolts from the hardware store to hold it together again.
  7. Erwan960
    3,832Coins
    Your order has been completed.
    Parcel sent :)
    2x model #7 12v 3200 rpm 50:1
  8. eaorobbie
    20,508Coins
    Sweet let us know difference, I'm sure you will be happy.
  9. Albertus
    Albertus New Member
    Manager
    Standerton Mpumalanga South Africa
    131Coins
    WOW! Nice simulator. I wish i had enough money to build the same simulator!
    Just a question: Can XSimulator being used for public use or only for personal use?
    Thank You
    Albertus Geyser
  10. eaorobbie
    20,508Coins
    SimTools is made for private use but by contacting the creator @yobuddy he can arrange a public licence for you, please if you want to use it publicly support the person behind the fine creation.
  11. Erwan960
    3,832Coins
    Slight change on my rig : triple screen !
    • Like Like x 5
  12. bsft
    looks great man! did you get the 50:1 gearboxes yet?
  13. Erwan960
    3,832Coins
    Yes I received. It only remains for me to find a little time to adapt to my system! :)
  14. eaorobbie
    20,508Coins
    Me jealous , wow looks cool, nice small bevals too
  15. Vassago
    Vassago New Member
    441Coins
    WOW...the work on this project is fantastic. How many amps at load do those dc motors pull.
  16. Erwan960
    3,832Coins
    I'm using two 12V - 50 A power supplies and my JRK are set to deliver 38 A max.
  17. eaorobbie
    20,508Coins
    We have recorded 45-48amp draw through the Jrks on motor stall to change direction, but thats only for a split second with simular motors.
    Jrks with cooling dont have a problem punching those numbers out all day.
  18. Nath Older
    Nath Older Member
    Laboratory Supervisor
    United Kingdom
    271Coins
    Wow this all looks so good. well done, plenty of inspiration here!
  19. Erwan960
    3,832Coins
    Test with triple screen config. Not easy to drive just woke up ;)
  20. bsft
    Thats got some kick! Is that with the 50:1 boxes?
