Showroom DIY 2DOF simulator
Discussion in 'DIY Motion Simulator Projects' started by Erwan960, Sep 27, 2013.
  1. Erwan960
    Erwan960 Active Member Gold Contributor
    3,832Coins
    Not yet. I am impatient to see what it will give with them !
  2. eaorobbie
    20,508Coins
    @Erwan960 profiles looking really nice now, triple screens ah..... I will get there one day, love it.
  3. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    This has just set a benchmark for me. If I can create anything close to this with even one screen I'll be more than pleased with myself.
  4. Michael Hensen
    Michael Hensen Active Member
    C# Software Engineer
    Almere, Netherlands
    748Coins
    Building/Planning the same kind of setup I am wondering how long is you lever ? center to center of bolt?!
    With kind regards,
    Michael
  5. Erwan960
    3,832Coins
    5 cm center to center.
  6. Raulmerlos
    Raulmerlos Member
    Mecanico maquinaria calzado
    Monóvar (Alicante) España
    138Coins
    3DOF, Arduino
    Hola soy Raúl, hace poco que me e metido en el mundo del simulador, en el que veo que sois unos verdaderos genios todos, gracias a merchan que es el que esta dándome toda la información que necesito, bueno quería presentaros mi prototipo claro lejos de lo vuestro pero poco a poco y quería daros las gracias por acogerme en vuestro foro, un saludo para todos.
  7. Martin van Hagen
    Martin van Hagen not trying brings you nothing! SimAxe Beta Tester Gold Contributor
    Instrument Engineer
    The Netherlands
    881Coins
    Cool rig!!! What have you used as balancing springs underneath the rig, they look like spring scales?
  8. bsft
    @Raulmerlos , nice build, but can you please start your own thread of it. This is someones elses and we appreciate the input , but have it on your own thread
    translation
    agradable build, pero puede usted por favor iniciar su propio hilo de la misma. Se trata de alguien vigilara y apreciamos la entrada, pero tenerlo en su propio hilo
  9. vulbas
    vulbas Active Member
    france
    1,103Coins
    AC motor, 6DOF
    very good job :)
  10. Raulmerlos
    Raulmerlos Member
    138Coins
    3DOF, Arduino
    Siento mucho la molestia, intentare no volver a molestar.
  11. pOmmi
    pOmmi New Member
    628Coins
    @Erwan960, nice sim ! Do you have a link for the 2x Potentiometer PPC27 10k ? Where did you buy them ?
    Edit : As they are 360° pot, does someone knows if they are ok for an Arduino controler ?
  12. Erwan960
    3,832Coins
  13. eaorobbie
    20,508Coins
    If they run on the Jrk they will run on the Ard. No worries.
  14. pOmmi
    pOmmi New Member
    628Coins
    Thank you for the link.
    I did write to them to know the price : "Le montant TTC s’élève pour 4 pièces avec frais de port à 144.48euros."
    ... meaning 144.48€ for 4 pot. So approximatly 37€/unit.
    Outch :think!
    Thx @eaorobbie, for the information.
    indeed, 27€/unit + 12.40€ frait
  15. Erwan960
    3,832Coins
    They are not cheap but are deadly accuracy!
  16. GoRacing
    GoRacing Member
    96Coins
    DC motor
    Great project.
    Should I build a simulator 2 motor type as yours and I wanted to inform me of such expenses according to the budget deal that ho.Mi can you say that you used hardware and software engines etc.. the total expenditure?...
  17. scalhoun
    scalhoun Active Member
    Software Engineer
    Pennsylvania
    968Coins
    Not sure if I missed this in the thread... What is the height of your ujoint or a recommended height to use on a setup like this. Are the springs required in this setup? What benefits do they have?
    Thanks in advance!
  18. Jacob
    Jacob New Member
    Columbus, OH
    339Coins
    2DOF, 3DOF, DC motor, Arduino, Joyrider, 4DOF
    great sim. lot of good information. I am reading up to build a 2DOF flight sim.
  19. Erwan960
    3,832Coins
    I finally found a little time to take care of my new engines. I was able to proceed with inversion of one of the axes.
    First good surprise: the system is in steel, much stronger than the first gear that I had which were all plastic. The system is very difficult to reverse. The cockpit should remain in position even when power is off.
    Second good surprise : the results obtained by adjusting the settings in the PID. The response time is very good and I did not overflow, even on big race (from 100 to 4000 for example).
    I hope to complete the installation today. More news soon!
  20. bsft
    Yes it should stay still. I fitted 60:1 boxes to a mates sim and its impossible to turn the levers, all 80mm of them.
