Diy 2dof wiper motor project
Discussion in 'DIY Motion Simulator Projects' started by Karolis, Dec 12, 2022.
  1. Karolis
    Karolis Pioneer
    Lithuania
    137Coins
    Ok, couple more things to understand. Does anybody know what motion controls acceleration and braking? I assume it is surge?
    153,764Coins
    +11,149 / 57 / -2
    Yes surge is the primary axis for acceleration and braking.
    Setting a differentiated Max and Min surge values in the Tuning Center can also be used for gear shift kicks: https://www.xsimulator.net/community/faq/snappy-gear-change-motion.121/
  3. Karolis
    Karolis Pioneer
    Lithuania
    137Coins
    Simtools v3, does not allow to change one of min max values, only changing both if i slide adjuster... But not a big deal, just when braking, nose dives down too much, but as i said it is not a problem.
  4. Karolis
    Karolis Pioneer
    Lithuania
    137Coins
    hi again, strange thing happened. I had to change my pc components(mb ram gpu cpu) basically all pc. And after replacement, my DIY license gone on Simtools v3. I can use simtools v2.6 but i can not find game plugins... Is there anything what i can do to reset my license(Simtools v3)?
    153,764Coins
    +11,149 / 57 / -2
    Did you reregister v3?
  6. Karolis
    Karolis Pioneer
    Lithuania
    137Coins
    I have contacted support, and they did something, and i can reregister once again. Problem solved.
  7. Beavis
    Beavis New Member
    Canada
    233Coins
    Congrats on getting your rig running, and thanks for sharing it with us!
  8. Karolis
    Karolis Pioneer
    Lithuania
    137Coins
    Yeah it is cool thing. What i already encountered is that suspensions are vital to this thing. One of shocks failed(gas came out) and after 1 hour of playing one of motors burned off. So if someone wants to use wiper motors, give them help with furniture's shocks. I used 300N, it holds 30kg. Just put in same distances from center of gravity.
