Question DIY 3DOF (actuator) with Traction loss
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Horseweed, Sep 1, 2022.
  1. Horseweed
    Horseweed New Member
    Student/ME
    Georgia, USA
    94Coins
    4DOF
  2. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,332Coins
    I looked through the thread you pointed out, and user Squarebob built a completely different type of platform than the one you want to build.
    Squarebob built a typical 2DOF in which the entire weight rests on the joint (red circle in the photo I am attaching) and the motors only have to balance the partial weight when the platform tilts.
    In your case, the motors have to lift the entire weight. Take my word for it, you can't build a working platform with three 200W motors. Maybe if you use very short arms, 2-4 cm, it will work, but then the range of motion will be very small.
  3. Horseweed
    Student/ME
    Georgia, USA
    94Coins
    4DOF
    That's fine with me if the range of motion is small, this is why I incorporated slots on my levers, so I am able to adjust base on what my motors are capable of. I am not an electrical engineer, so the electronics side I am struggling with. My goal is to get that side working, then upgrade where necessary. One thing I won't forfeit is I want 3DOF on this platform, Pitch/Roll/Heave, then I will add in the lower frame for traction loss.
  4. Horseweed
    Student/ME
    Georgia, USA
    94Coins
    4DOF
    Just as a test yesterday I found two issues; a) the potentiometers I had were causing the weird erratic behavior. I tested this by wiring in 10k contact pots I had and the issue was gone.
    b) I had another IBT go bad during initial testing, and then another during yesterdays testing. I did slide my links all the way down into my levers making them about 2.5” C-C and with two motors running it seems capable of holding my weight and running properly. The weak point in that test was the other IBT that died. It seems like one channel burned out because it would go one direction but not the opposite anymore.
    I also went ahead and moved the 3rd motor to a separate arduino and overall performance was much better. The only part that was difficult about that was figuring out how to assign the axis correctly to make the motion work right. (I set it like this A[<Axis3a>] or however it is formatted I changed 1-4,2-5,3-6, and it started working how I needed)
    is there an easier way to go between arduinos in smc3 utilities? Currently having to switch the COM port text when going between arduinos
    I appreciate everyone’s help and patience with this project.
    151,875Coins
    +11,061 / 56 / -2
  6. Horseweed
    Student/ME
    Georgia, USA
    94Coins
    4DOF
    Update, new motor drivers and pots installed and everything is working great, I was even able to run my links out on the arms some to get more travel with no issues. I had my friend come over and test it, and noticed the rear motor gets hot, I’d say 120F maybe 130F, I’m thinking of moving the seat forward some more to get some weight off of it. Next is the traction loss, and mounting the wheels and pedals to it. Thanks for all the continued help!
    another question I have, when the cranks are moving down, I get a lot of “jitter” but it’s smooth on the way up, I’m thinking this is gearbox slop, but any suggestions I am open to, currently I have pwm max at 100, pwm rev at 75. Kp at 500, and everything else at zero, adding Kd, Ks, does not change this behavior, it also shakes when I get down on the clip limit for the front two. Lowering pwm rev helps, but lower than 65 it can’t recover.
    151,875Coins
    +11,061 / 56 / -2
    Proper rig balance is incredibly important, and needs to be determined with yourself and all peripherals on-board.
    The other thing you can try is reducing the CTC distance of the levers, as that will help increase effective torque utilization.
  8. Horseweed
    Student/ME
    Georgia, USA
    94Coins
    4DOF
    How far forward would you suggest moving it? I guess center of mass is at my butt when I’m sitting? How does that change once the wheel and pedals are added? I can do a FBD on it, I’m just unsure where CG is for me.
    151,875Coins
    +11,061 / 56 / -2
    You need to grab a friend and find the balance point of the top frame, with yourself and all peripherals on-board, please see the FAQs here: https://www.xsimulator.net/communit...-of-gravity-to-balance-a-motion-simulator.55/
  10. Horseweed
    Student/ME
    Georgia, USA
    94Coins
    4DOF
  11. Horseweed
    Student/ME
    Georgia, USA
    94Coins
    4DOF
    After some tuning, I have been able to thoroughly enjoy my sim. It’s insane how much feedback these give you as a driver. One issue I have noticed recently that seems to be consistent, when playing Iracing, I launch sim tools, load in to the sim, and everything goes smooth. As the night progresses and multiple stop/start sequences in sim tools, I get a sudden violent jerking of all 3 motors when starting the sim tools plugin up again and the jerks get progressively worse and more randomly patterned. This only lasts for a few seconds and then stops. Does anyone have any ideas as to what could be causing this?
  12. noorbeast
    151,875Coins
    +11,061 / 56 / -2
    One for @yobuddy to ponder.
    With multiple restarts perhaps something does not shutdown cleanly.
