Showroom DIY 3dof Dbox Style Rig with 4 x 750 Watt Linear Actuators 100 mm
Discussion in 'DIY Motion Simulator Projects' started by Ringorumble, May 10, 2018.
  1. Ringorumble
    Ringorumble Active Member
    190Coins
    Dont know, i was standing on one actuator and it was lifting me plus the quarter of the rig .. A friend with hyperaxis did the same, they stalled :) Check the parts , i think you can calculate this ..
  2. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    how maximum angle(degrees) have your platform 10-15?
  3. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Thank you very much! The best contribution to the forum of 2018!
    Do you know how much speed you got? and also rpm of the servos?
    Thanks anyway!
  4. Ringorumble
    190Coins
    Degrees depends on the placement of the actuators ... didnt measure mine
    The Servos go up to 3000 rpm, the Ball Screw is a 5 mm per round ...
  5. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    you will also have arduino code for public?
    thanks
  6. Ringorumble
    190Coins
    Did you Check github, Documemtation is done There ..
  7. misoswan
    1,032Coins
    3DOF, Arduino, JRK
  8. Ringorumble
    190Coins
    Yeah, will be ready soon, start printing Guys ..
  9. AussieSim
    AussieSim Member
    Australia
    1,452Coins
    The servo motors' nomenclature makes me think they are MiGE servos, as used with OSW direct drive FFB.
    If they are MiGE, then they can be custom ordered with a BiSS absolute encoder.
    @Ringorumble @saxxon66 would the BiSS encoder be supported and would it be superior ? (no phasing to index)
  10. Ringorumble
    190Coins
    @saxxon66 Maybe saxxon can tell, i dont know. The motors incl the encoder works fine, the centering method we use works fine so maybe no need for an absolute encoder ?!?
    The goal is and was that people can build it cheap, reliable, easy to fix.At the moment the software let you only write your own telemetry Providers (e.g. game plugins in Simtools) maybe saxxon implements also a way to create your own code driving your custom motors
  11. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    hello
    how much maximum elevator 8-15cm?or?
    thanks
  12. Ringorumble
    190Coins
    Little Bit more than 10
  13. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    I can adjust the length linear actuator?( normal length 25cm change for 35cm )possible after change setting in software?
  14. saxxon66
    saxxon66 New Member
    323Coins
    No, you can not change it.
    Goal of this project is to build the actuator based on our instructions.
    So everyone will have the same experience and we can work togethere on the same basis.
    The Software is specialized for this setup.
    Encoder has 10000 CPR resolution, so do the math. Slope is 5 mm.
    It is more than you will ever need for a motion sim.
    Absolute encoder would be nice, but that was not an option.
    Maybe later we will support other configurations and motors.
  15. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    I asked because loved flight .on flight need more degrees 12-15 .i am not sure , what your platform to do the same degrees.
    what you think?
    thanks
  16. HoiHman
    HoiHman Active Member
    Mechanic
    The Netherlands
    331Coins
    Great project,
    After seeing the 2 hour tutorial video in German, i immediately ordered the Servos on Aliexpress.
    Today i finished the rest of the shopping list, so things are set in "motion" :D
    A couple of things:
    -Join amazon prime, even if it's just for one month, to get free shipping on almost everything.
    -Don't get fooled by the ending discounted prices of the servos on ali express, they have a new sale every day / week
    - It seems like with every seller you pay per servo for shipping, negotiations have little to no use.
    If you buy 4 servos, you almost pay 4 times the shipping cost. They did ask me if it's ok to lower the total amount for customs, so i pay lower import taxes.
    In the meanwhile the MK3 is doing it's thing
  17. Edwin
    Edwin New Member
    Netherlands
    220Coins
    Motion platform
    3D printing ordered. going thru the rest of the shopping list now :)
    One question, i'm almost only running rFactor2 is this game on your todo list for the software development? Asking because i suck at coding......better said can't code at all :(
    Thanks for sharing this wonderful project
  18. yobuddy
    51,351Coins
    We could make an interface plugin for these, so they could be used in SimTools also, if the control protocol is posted somewhere?
    Does anyone know if the control protocol is detailed anywhere?
    • Optimistic Optimistic x 1
  19. HoiHman
    Mechanic
    The Netherlands
    331Coins
    I made a mistake with that, those bearings are not the same as the ones you need even though they have the same name "LMEK30UU"
  20. AussieSim
    AussieSim Member
    Australia
    1,452Coins
