DIY Arduino Buttonbox
Discussion in 'DIY peripherals' started by TOPMO3, Mar 28, 2016.
  1. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    2DOF, DC motor, SimforceGT
    Thanks noorbeast, you're right, thanks for the help, I also found the error because I didn't have the correct joystick library.
  2. JustJay
    JustJay New Member
    16Coins
    Hey everyone, new here just looking at the hydraulic pedal projects and saw this post. In no way am I saying there's anything wrong with this method, just saying you can save that Arduino for a way cooler project or any of the other millions of ways to use it. You can build a button box with a ton of buttons and no coding period, not even the copy and paste Arduino studio examples. They sell these on eBay and Amazon, they're called USB encoders and they're about 5$ with the leads and cable. They're made for restoring or remaking arcade games I think. Anyways I just built one about 2 months ago and it turned out awesome for roughly 20-30 Total. I even cut out a spot for an old tablet inside the box loaded with SimHub. You can even get by cheaper than that if you have some parts laying around. Most expensive thing for me was a plastic electrical junction box that was the perfect size and really strong and it was about $18. The encoder is plug and play via USB cable. Just plug the leads onto the board and use whatever buttons switches or whatever else you can't think of the find a new or donor box that will suffice and you're set. I have a couple 3d printers so I did a little extra and printed button ID bezels like you would see in a race car then mounted it to my rig and it's been great every since. I have a charge cable for the tablet and the USB encoders cord running out of the back and even the old micro USB cable that ALWAYS manages to fail still works. I use simple 3 pole, momentary, and toggle switches same as you would find in a race car. Even worked in an emergency shutoff and push button ignition that are functional all on a 5$ USB encoders board. I saved my Arduino for some that would make better use of its capabilities, hope this helps someone out there.
