DIY Arduino Buttonbox
Discussion in 'DIY peripherals' started by TOPMO3, Mar 28, 2016.
  1. PiaMan
    PiaMan Active Member
    Saskatchewan, CANADA
    607Coins
    3DOF, DC motor, SCN5, Arduino
    Thanks for the great project. I agree that less buttons and 3 pot inputs would be amazingly useful as well
  2. bruce stephen
    general contractor
    michigan
    9,115Coins
    is there a way to have it sense the button as long as its depressed so i can use a button for chat. as it is the buttons just flash and do not sense long presses.
    Thank you for sharing. This is an awesome pit tool.
  3. TOPMO3
    TOPMO3 Active Member
    Russia
    899Coins
    hi Bruce, i'll take a look, but very busy right now..
  4. bruce stephen
    general contractor
    michigan
    9,115Coins
    @TOPMO3 no problem it works great. Im using the joystick version. Don't worry about changing it I like it as is. Again Thank you for sharing.:thumbs
  5. Borja
    Borja New Member
    Loja
    133Coins
    Much that effort is appreciated. The truth is that as iRacing simulators, the option to tow, leave pressed a button. Again thank you very much and best regards
  6. TOPMO3
    Russia
    899Coins
    guys,
    can you try this new attached joystick version?
    virtual buttons should be pressed as long as you hold real buttons now
  7. Borja
    Borja New Member
    Loja
    133Coins
    Yes, right now the taste and comment. Thank you very much
  8. Borja
    Borja New Member
    Loja
    133Coins
    It works well as leaving pressed the button, but always on the same button number 1. Sorry for my bad English
  9. TOPMO3
    Russia
    899Coins
    ok, one moment
  10. TOPMO3
    Russia
    899Coins
    ok here is one more new version.
    sorry for mess, don't have enough hardware to test it ... :blush
  11. Borja
    Borja New Member
    Loja
    133Coins
    No problem, I try it. Thank you very much
  12. Borja
    Borja New Member
    Loja
    133Coins
    Works fine. Thanks
  13. TOPMO3
    Russia
    899Coins
    good, thanks for confirming @Borja.
    will add the new sketch in the first post also
  14. Borja
    Borja New Member
    Loja
    133Coins
    Now the problem I have with this change is that when entering iRacing, works for a period of time and then switched off and no longer recognizes the arduino. I was testing the long press of the buttons. It may be for this change in the scheme?
  15. TOPMO3
    Russia
    899Coins
    hmm, dont kown yet, I need to test it with iracing
  16. Borja
    Borja New Member
    Loja
    133Coins
    ok, I will continue doing more testing and I count. a greeting
  17. TOPMO3
    Russia
    899Coins
    Borja, I haven't any issues so far.
    here is slightly more optimized version, but i dont sure will it fix your problem or not
  18. Borja
    Borja New Member
    Loja
    133Coins
    It is perfect, it was my problem USB cable. Thank you so much
  19. TOPMO3
    Russia
    899Coins
    @Borja, glad to hear it works :)
  20. Diego Sun
    Diego Sun New Member
    Curitiba, Brazil
    110Coins
    Hey man, thanks for sharing the project!
    It is possible to use 6 encoders on the 1st version of your button box?
