Showroom DIY force feedback steering wheel, using DC motor. based on MMOS
Discussion in 'DIY peripherals' started by ahoenksiluman, Feb 7, 2019.
  1. ahoenksiluman
    ahoenksiluman Member
    indonesia
    89Coins
    never try that...
    but very interesting...
  2. Sieben
    Sieben Active Member
    2,241Coins
    Hi there. What's the way to make the MMOs work correctly in rFactor2? The thing is that the FFb is kind of inverted over there. Does anybody know it?
    Only've got only an idea to swap the motor, and get rid of soft lock then in MMOS. Otherwise don't know, will be great to hear other way to do it)
  3. mrbeginner
    mrbeginner Active Member Gold Contributor
    What ever come in my way
    Finland Niinisalo
    - 40Coins
    Looking good!
    I think i have to try this kind of wheel setting someday.
  4. khientjhia
    khientjhia New Member
    Service
    Indonesia
    41Coins
    2DOF, 3DOF, Arduino
  5. khientjhia
    Service
    Indonesia
    41Coins
    2DOF, 3DOF, Arduino
    I have resolved it ...
  6. Manuel12593
    Manuel12593 New Member
    57Coins
    Hola buenas a todos estoy haciendo un volante con arduino leonardo, bts7960b, encoder omron. Y ahora viene mi duda lo tengo todo conectado como en el tutorial emc lite y cuando hago el test de iracing el volante empieza a girar sin parar hasta que no desconecto la alimentación del motor. Si alguien me puede ayudar ? No paro de darle vueltas y no consigo que haga el test bien y no se quede girando todo el rato. Gracias de antemano
    Aquí mis conexiones.
  7. Sieben
    2,241Coins
    Why not talk in English?
  8. Manuel12593
    57Coins
    Sorry. My English level is a little low.
    Hello good everyone I am making a steering wheel with arduino leonardo, bts7960b, encoder omron. And now comes my doubt I have everything connected as in the tutorial emc lite and when I do the iracing test the steering wheel starts to turn non-stop until I turn off the engine power. If anyone can help me? I keep circling it and I can't get him to do the test well and he won't just sit around all the time. Thank you in advance
  9. Gadget999
    12,331Coins
    good job on your wheel
    does it have enough power to be direct drive ?
  10. Manuel12593
    57Coins
    [QUOTE = "Gadget999, publicación: 194422, miembro: 20168"] buen trabajo en su rueda
    ¿Tiene suficiente potencia para ser de accionamiento directo? [/ QUOTE]
    I have a motor my1020 with 500w
  11. Sieben
    2,241Coins
    swap the motor's polarity, or pwm pins. What do you prefere. Look for the right connections of pwm pins according to the EMC versions.
  12. MarcoMade
    MarcoMade Active Member
    italy
    157Coins
    nice job congratulations!
    I also tried this type of engine, both with the whole steering gearbox (opel corsa B) and direct.
    reduced it has a monstrous force I think it exceeds 50nm, (it has the problem that when you steer fast it generates current and hardens the steering) direct does not have much force. has the big problem of overheating a lot, I tried to drill everywhere but without solution .... it heats up a lot.
    these motors complete with steering reducer are perfect for moving a dynamic station with incredible force.
    your project with reduction is better compromise
  13. Manuel12593
    57Coins
    [QUOTE = "Sieben, post: 194434, member: 31607"] intercambie la polaridad del motor, o pwm pins. ¿Qué prefieres? Busque las conexiones correctas de pwm pines de acuerdo con las versiones de EMC. [/ QUOTE]
    Thanks I try it now
  14. Manuel12593
    57Coins
    What engine do you recommend?
  15. Gadget999
    12,331Coins
    that motor should be ok
  16. Manuel12593
    57Coins
    I have changed the polarity of the motor and the bts has burned
  17. Sieben
    2,241Coins
    Due to the polarity change, the bts do not and can't burn. You have done smth wrong.
  18. MarcoMade
    italy
    157Coins
    [QUOTE = "Manuel12593, post: 194446, membro: 36574"] What engine do you recommend? [/ QUOTE]
    usually most use the my1020.
    I use a large recovery engine from an industrial floor washer, it weighs 13kg. after many tests I find that the engine must be very robust in order not to overheat and offer strong torques.
    traction motors are ideal, see 1kw treadmill motors and more
    https://photos.app.goo.gl/bk2egQkDwqEfEA9Z7
    if you need to get some ideas, the engine plate is unfortunately erased by time
    https://photos.app.goo.gl/iXd5VqDvbejoMbGB6
  19. Gadget999
    12,331Coins
    wow that thing is huge - have you measured the torque ?
  20. Sieben
    2,241Coins
