DIY H-Shifter by Willynovi - Working
Discussion in 'DIY peripherals' started by willynovi, Mar 15, 2010.
  1. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    I still dont understand how you attached the bearings to the block. Does the bolt go all the way through? is there a space for the bolt to go up and down or are there 2 bolts that dont go all the way through? Is the block threaded?
  2. Historiker
    Michigan USA
    9,208Coins
    There are threaded holes in the bearing block for the bolts, I used a lock nut (sliced thin on my lathe) to tighten the bearing bolt to the block.
  3. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    so its thing like a O or you mean thing like o as in only the threads?
  4. Schopfer
    Schopfer Member
    Thailand
    86Coins
    How to conect and control this shifter to Games ?
  5. Historiker
    Michigan USA
    9,208Coins
  6. Schopfer
    Schopfer Member
    Thailand
    86Coins
    Shifter in your link is control by Teensy++2.0 controller board (I can’t write a code)
    Can i use with joystick encoder ?
  7. Historiker
    Michigan USA
    9,208Coins
    Yes, you can disassemble an old joystick or better yet a game controller and rewire it. You could also use a teensy ++ 2.0 like I did using GenericHID (Google) drag and drop programer. There are also lots of other options; Leo Boadnar, U-HID, Arduino, etc. It is worth spending some time doing the research and choose what works best for you.
  8. Schopfer
    Schopfer Member
    Thailand
    86Coins
    I will try with arduino r3. I have not use 2 arduino.:thumbs
