DIY MOSFET H-Bridge Driver
Discussion in 'DIY peripherals' started by Sieben, Apr 5, 2019.
  1. Sieben
    Sieben Active Member
    2,241Coins
    I believe You can avoid adding it to bts /btn drivers. But i did not removed my own.) Don't want to experiment of destroying btn. It will never be odd anyway.
    It all depends from motor. I stated what diodes are used. Ultrafast switching diodes. Kind of - F30u60dn etc.
  2. Arta Yasa
    Arta Yasa Member
    878Coins
    If i used wiper motor bus/truck(big wiper motor) sir. Because sometime bts7960 cannot respond sir, i think bts shutdown, but no sir.
  3. Sieben
    2,241Coins
    Then use 2ibt in parallel, or, what is even better, 12-and may be 18volts and smth like 20-40 amps psu with only one ibt driver. Or, put the lowest pwm frequency for 24v psu.
  4. Arta Yasa
    Arta Yasa Member
    878Coins
    How to set lowest pwm frequency on PSU sir?? Iam used psu 24v 13A, i set telhe voltage to 22v sir. Justul
    How to set lowest pwm frequency on PSU sir?? Iam used psu 24v 13A, i set the voltage to 22v sir. Just used 1psu to handle 2 wiper motor sir.
  5. Sieben
    2,241Coins
    Not in psu, in the ffb software.
  6. Arta Yasa
    Arta Yasa Member
    878Coins
    Yes sir, but this for my 2DOF, iwill tryit sir
