DIY - OSW Mige/Simucube/IoniPro
Discussion in 'Direct Drive Wheels' started by SilentChill, Jan 17, 2017.
  1. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    nice mate. well done. Ive sacked dirt off for now. for me it is an utter pain in the arse. @stevemontuno posted how to set it up and i did get it up and running. a few PC restarts later, the settings just vanished.
    I cant be bothered to go through the whole set up again
  2. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    i will add one point and that's assetto settings in mmos and granity were to powerful for dirt and vibrated my wheel horribly.
  3. SilentChill
    20,592Coins
    I've put Nicks dirt settings in so they should be pretty good he knows what hes doing :)
  4. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    I tried nicks last settings post and it worked pretty well but i did add a bit of power having the large mige. i need a handbrake though as its a bitch to play without one.
    Mine is crashing at the minute with the dreaded 100% disk usage. i had it before and wiped the PC, and all was fine but now its back. ive got nothing running that would cause it
  5. SilentChill
    20,592Coins
    Just had another try for 3/4 of an hour. Still cant get it to open up the FFB settings. Even worse its not recognizing my BlueHid buttons for the paddles, the bluehud is there in controllers in windows and I can see its working when I press the buttons but nothing happening when in Dirt settings.
    DIY why do I do it.................
    F'it im gonna go kill some dinosaurs now can't be arsed anymore tonight
  6. SilentChill
    20,592Coins
    Jeez thats not good never had that issue myself. Wasted about 5 hours tonight getting it up and running and not even been in a game yet lol
  7. stevemontuno
    stevemontuno Active Member
    1,461Coins
    You have to assign the wheel , pedals and up/down gears to open up the advanced ffb settings dude.
  8. SilentChill
    20,592Coins
    Ahhh ok cheers matey , only thing i was missing was gears then because my bluehid is not getting picked up in Dirt :(
  9. stevemontuno
    1,461Coins
    just assign them to your keyboard for now and use auto gears until youve sorted your paddle shifters :thumbs
  10. stevemontuno
    1,461Coins
    I wonder if its something to do with the codemasters proxy server why your bluehid isn't working ?
    if it's working on other games it will be the proxy server issue ,,,
  11. SilentChill
    20,592Coins
    only tried Dirt so far will try again tomorrow god knows why its not working
  12. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    you have some patience ill give you that lol. i would off give up on dirt as soon as i realised the wheel was working and played assetto as it easy to set up
  13. Nick Moxley
    17,057Coins
    I think your BT buttons aren't being registed due to the Overwriting the device type,
    Override device type to wheel
    Load Dirt Rally, and navigate to the Controller screen. Click on “Choose Preset”. Press F1 while you are highlighting your DirectInput device to override the controller type to wheel. If multiple DirectInput devices are shown on this screen, you might need to override all of them. This should make advanced wheel setup available on the controller screen. You also might need to assign the steering axis, after loading the preset, in order for the advanced wheel options become available."
    I had issues while i was trying to use my fanatec BMW wheel to get the Funky switch to work the menu's, I found i had to play around with this Overriding thing to get my SRW S1 and what not to work again once i got the wheel going. Im 99% sure they were joysticks before and it was defaulting to game pad or something.
    My Fanatec wheels are done through a Teensy, So i HIGHLY doubt its the proxy server at work here.
  14. stevemontuno
    1,461Coins
    @Nick Moxley Yep the proxy server is a telemetry based thing so i guess it does rule that out ,,,,, I reckon you've sussed it out with overriding the direct input devices though ,,that sounds bob on ,,,
    I didn't know you can use the funky switch to navigate the menu's with the Fanatec conversion ,, does it also give you buttons to access in & out of menues too? i've been using my mouse to navigate menu's with the bodnar board ,, might have to have a play about with those direct input settings and see if i can get my funky switch working too.
    My funky switch only works if i assign it in the configuration settings but doesn't work for scrolling through menue's.
  15. Nick Moxley
    17,057Coins
    I gave up on the BMW wheel, I couldn't seem to get it to work the way i wanted without screwing up the wheel. In the end i use a Rally wheel and Not the bmw, so it was a moot point in the end. I am currently in the works of getting a Alps switch working on A Teensy LC, If all goes well, I will likely add one to my Rally wheel for this type of menu surfing and it wont be seen as a Fanatec wheel still, so im sure the game menu wont freak out as it does,
    Im pretty sure your leo board is limited by something and it Cant use those functions.
  16. SilentChill
    20,592Coins
    FINALLY GOT IT ALL WORKING !!!!
    Got Dirt setup properly even found an old Teensy lying around so wired up my G27 shifter and I needed to as my handbrake is attached to it, although I could of just wired it into the simucube ;)
    Video to follow soon but the torque is way too much in DirtRally its not that hard to hold the steering wheel in real life :eek:o_O:confused:
    Deffo needs tweaking some
    First impressions are good tho only tried DirtRally so far, I can feel the same vibrations coming through the wheel as I can through rig. The slip and grip bumps and ditches you feel is so much better and the deadzone ????? what deadzone lol and the stupid oscillations are all gone :D
    • Winner Winner x 4
  17. SilentChill
    20,592Coins
    Help please !! :)
    How do you get rid of the horrendous constant humming in Dirt Rally ??
    You get more than 10% in wheel friction and tyre friction it's terrible humming but leave it low the humming goes and you can't feel a thing ???
  18. Nick Moxley
    17,057Coins
    Turn down the TBW,
  19. bruce stephen
    general contractor
    michigan
    9,115Coins
    I also had to turn up the filter in mmos. The main one on the left. And i turned mmos power down some for DR. Yes friction filter causes issues.. Mmos, granity and DR all have thier own friction filters. They all cause humm on my setup. So i keep them low or off.
  20. SilentChill
    20,592Coins
    Its already set to 680 hz.
    I will play around see whats what :)
