Question DIY Pedals arduino leonardo + load cell.
Discussion in 'DIY peripherals' started by Alecont, Mar 17, 2021.
  1. Lebois
    Math teacher
    2,566Coins
    yes
  2. Lebois
    Math teacher
    2,566Coins
    i am testing with your code and it works until the calibration factor is too low and values goes above 326xx. Otherwise that's just already very good :)
  3. Gadget999
    12,066Coins
    ok try this
    int currentAcceleratorState = map(rawReadAccelerator,0,6000000,-32768,32767);
  4. Gadget999
    12,066Coins
    i also recommend a small delay in the main loop to stop overloading the joystick service
    delay(50) ;
  5. Lebois
    Math teacher
    2,566Coins
  6. Gadget999
    12,066Coins
    please you got it sorted - the map function can not work with big numbers !
  7. Harman singh
    Harman singh New Member
    120Coins
    I am making a racing sim using (Arduino Leonardo) adding potentiometer pedal, h shifter and ffb steering wheel,
    But now I also want to add a load cell(hx711) handbrake
    Can I integrate it in Leonardo or I need to use new Arduino board.
    Please give suggestions and way of doing this(adding load cell handbrake code to Leonardo ffb steering wheel code)
