Resolved DIY SIMULATOR: .net crash GMer, reinstall now not connected.
Discussion in 'SimTools Pro & Entertainment Version' started by SBDESIGN, Jul 9, 2017.
  1. Mpmo
    Mpmo Member
    United Arab Emirates
    1,289Coins
    yeah i have no idea.. maybe i should uninstall 3.5 and install the link you sent?
    but it's also not letting me uncheck the box :/
  2. yobuddy
    51,529Coins
  3. Wilson Rios
    Wilson Rios New Member
    473Coins
    Man, I am having the same issue. Spent hours trying to solve it for days and nothing.
    I can't believe the whole thing would be a such pain.
    It seems that SimTool has some compatibility issues and needs proper revision.
    Windows warns me went trying to install .NET framework 4, saying it's already part of my OS system.
    Are the SimTools developer part of this forum?
    153,788Coins
    +11,150 / 57 / -2
    Yes @yobuddy the SimTools dev is active here, and gave the advice just prior to your post:
  5. Wilson Rios
    473Coins
    Thanks yobuddy and noorbeast for so promptly jump in with some directions.
    Sadly it did not solve the issue with zero Game Data Output. LFS has been patched twice, min and max numbers are present. Oh well, it's pass time for me to hit the mattress. I will wipe everything and start from all fresh from scratch tomorrow again. Too many steps and apps to get this thing rolling, following priorities of this and that with more intuitive and not so raw GUI.
    I wish everything was more integrated in one single app, such as manager, engine and tuning. But at least we have something.
    153,788Coins
    +11,150 / 57 / -2
    Is this a .NET issue, as per this thread, or something else?
    LFS needs to be run for a race in first person mode before being patched for motion, as that generates some required files.
  7. Wilson Rios
    473Coins
    I did all that at least 6 times, rebooted my PC each time, but no success.
    Removed .NET Framework, reinstalled it, ran ST apps as ADMIN, and nothing.
    I do work with electronics, and consider myself not a decent troubleshooter, but this is driving me insane for the lack of right information.
    These issues might be more familiar to old long term users. But to a new user, this can be a nightmare and turning point to quit pursuing the motion project.
    I lost the enthusiasm for my motion project, but I am not a quitter.
    Is there a complete list of troubleshooting SimTool interface?
    I already mentioned that there is zero, nothing, nada in the Game Data Output fields when running it. That leads me to suspect that there is a major problem between my ST and LFS patch settings.
    If that's is true, then ST has problems patching the game properly.
    Could anyone share a copy of the LFS cfg settings?
    153,788Coins
    +11,150 / 57 / -2
    I am still not clear if you get a .NET error message or not, can you please confirm.
    If not start your own thread and post pictures of all of your settings.
    Third party things like firewall and anti-virus can mess with the proper installation and use of plugins.
  9. Wilson Rios
    473Coins
    I haven't notice the warning yet.
  10. yobuddy
    51,529Coins
    @Wilson Rios
    Create a tread and we can get you up and running there buddy.
  11. Wilson Rios
    473Coins
    I will do it.
    Thanks bud!
  12. Javo5
    Javo5 Active Member
    Buenos Aires, Argentina
    300Coins
    Hi, I have this error, worked fine yesterday: unchecked and Checked 3.5 and 4.7. Try repair .net, nothing. Thanks in advance.
    Consulte el final de este mensaje para obtener más detalles sobre cómo invocar a la depuración
    Just-In-Time (JIT) en lugar de a este cuadro de diálogo.
    ************** Texto de la excepción **************
    System.ArgumentException: La ruta de acceso no tiene un formato válido.
    en System.IO.Path.LegacyNormalizePath(String path, Boolean fullCheck, Int32 maxPathLength, Boolean expandShortPaths)
    en System.IO.Path.NormalizePath(String path, Boolean fullCheck, Int32 maxPathLength, Boolean expandShortPaths)
    en System.IO.Path.GetFullPathInternal(String path)
    en System.IO.DirectoryInfo.Init(String path, Boolean checkHost)
    en System.IO.DirectoryInfo..ctor(String path)
    en SimTools_GameEngine.frm_GameEngine.StartWithWindows_Checked()
    en SimTools_GameEngine.frm_GameEngine.frmMain_Load(Object sender, EventArgs e)
    en System.EventHandler.Invoke(Object sender, EventArgs e)
    en System.Windows.Forms.Form.OnLoad(EventArgs e)
    en System.Windows.Forms.Form.OnCreateControl()
    en System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    en System.Windows.Forms.Control.CreateControl()
    en System.Windows.Forms.Control.WmShowWindow(Message& m)
    en System.Windows.Forms.Control.WndProc(Message& m)
    en System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    en System.Windows.Forms.Form.WmShowWindow(Message& m)
    en System.Windows.Forms.Form.WndProc(Message& m)
    en System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    en System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    en System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Ensamblados cargados **************
    mscorlib
    Versión del ensamblado: 4.0.0.0
    Versión Win32: 4.7.3362.0 built by: NET472REL1LAST_C
    Código base: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
    SimTools_GameEngine
    Versión del ensamblado: 0.2.3.1
    Versión Win32: 0.2.3.1
    Código base: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameEngine.exe
    IzhdJmljrkghshbeNaMfqHfjdHul
    Versión del ensamblado: 0.0.0.0
    Microsoft.VisualBasic
    Versión del ensamblado: 10.0.0.0
    Versión Win32: 14.7.3190.0 built by: NET472REL1LAST_C
    Código base: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Código base: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    Código base: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Versión Win32: 4.7.3324.0 built by: NET472REL1LAST_C
    Código base: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    Versión Win32: 4.7.3190.0 built by: NET472REL1LAST_C
    Código base: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    Código base: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    Código base: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
    Código base: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    mscorlib.resources
    Código base: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_es_b77a5c561934e089/mscorlib.resources.dll
    System.Windows.Forms.resources
    Código base: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_es_b77a5c561934e089/System.Windows.Forms.resources.dll
    ************** Depuración JIT **************
    Para habilitar la depuración Just In Time (JIT), el archivo de configuración de esta
    aplicación o equipo (machine.config) debe tener el
    valor jitDebugging establecido en la sección system.windows.forms.
    La aplicación también se debe compilar con la depuración
    habilitada
    Por ejemplo:
    <configuration>
    </configuration>
    Cuando esté habilitada la depuración JIT, cualquier excepción no controlada
    se enviará al depurador JIT registrado en el equipo
    en lugar de controlarlo mediante el cuadro de diálogo.
  13. yobuddy
    51,529Coins
