do-it-yourself static 2dof dynamic conversion
Discussion in 'DIY Motion Simulator Projects' started by pfm21, Jun 17, 2020.
  1. pfm21
    pfm21 pfm21 build 3dof dinamic
    374Coins
    Hello to all. I have a problem. many times if i switch from SMC3 to "on" on simtools i have no movement in the ring. sometimes it is enough to close and reopen simtools, others are forced to restart the PC even though the com port is recognized. what it can depend on. I use arduino and 3 IBT2 and each motor has its own power supply
    Thabks
    154,849Coins
    +11,228 / 57 / -2
    You can't run SMC3 and SimTools at the same time, if that is what you mean, as it will cause a Port conflict.
  3. pfm21
    374Coins
    I run first SMC3 and after close it i put simtool "on", not at same time
    154,849Coins
    +11,228 / 57 / -2
    Once SMC3 is properly configured you should not need to run it at all.
    From a fresh boot, without SMC3 having been run, do you still get the same issue with SimTools? If so try different USB cable and port.
  5. pfm21
    374Coins
    yes i know.
    i use usb cable 5mt, can possible that is the problem?
    154,849Coins
    +11,228 / 57 / -2
    Yes it could be, as even a momentary USB disruption will cause a disconnect in SimTools.
    Try a different port before trying a different cable, you can also check what is connected to which internal USB hub, as most USB ports are shared, see the FAQs here for details: https://www.xsimulator.net/community/faq/simtools-usb-issues-can-cause-crashes.313/
  7. pfm21
    374Coins
  8. pfm21
    374Coins
    hello everyone. I've got a problem that I can't solve: the third engine of my dynamic rig (traction loss) works only when moving to one side. I tried changing engine, the IBT2, the power supply but the problem is still there. I'll leave a video showing how all three engines behave (obviosuly, engine number 2 is the Traction Loss).
    Could the problem be the Arduino? The one I use in my rig is the R3, along an IBT2 for each engine and a power supply for each engine.
    Thanks in advance
  9. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    For me bad ibt2
  10. pfm21
    374Coins
    I have try with another new, but problem is the same
  11. Krzysztof Dej
    Poland
    1,100Coins
    With some experience u will know that ibt can be good one of tree:) in video u see the up signal is broken
  12. pfm21
    374Coins
    You think that is Ibt2 fault? I try two of it
