DOF Reality platforms presets, profiles and tips
Discussion in 'Commercial Simulators and Peripherie' started by Mpmo, Dec 9, 2017.
  1. marco balletta
    marco balletta Member
    1,445Coins
    What would you suggest, a buttciker or transducers?
    Which of the 2 make less noise?
    153,788Coins
    +11,150 / 57 / -2
    A Buttkicker is a brand of transducer.
    The more powerful a transducer is the nosier it is.
  3. marco balletta
    1,445Coins
    How is the power of a transducer measured and how do you compare that value among transducers? Are there multiple parameters /characteristic to compare for the power of different transducers or the difference in power depends only from 1 value?
    Also, is there any example of noise that we can hear of transducers ?
    To feel the gear switch from 6 to 1, to what parameter in the software should the transducer be assigned ?
  4. dododge
    dododge Active Member Gold Contributor
    854Coins
    As a general rule, a heavier transducer will provide more force. But a heavier transducer will also add more weight that your rig's motors will have to move around, and it will probably require more power to run it, and its best frequency range may be lower than a smaller/lighter transducer so it may perform some effects better than others.
    For example just looking at Buttkicker's own products you can compare the "mini LFE" to the LFE.
    The "mini" version is popular with simulators because it's not too expensive or large, and only needs 50-250 watts of power so it's not too hard to find a compatible amplifier.
    The full-sized LFE is 3 times the price but also much bigger and heavier. The piston that actually moves inside it is heavier than the entire mini transducer. It also really wants about 1kW of power, so you typically need to use expensive amplifiers that probably have noisy cooling fans and require special cabling.
    On the other hand the LFE can shake very hard and I've usually gotten the strongest motion way down at 5-10Hz where some other transducers can't reach. Here's my old rig with four LFEs operated by two 3kW amplifiers. I put it on springs, and at the right frequency the transducers alone could make the entire thing bounce up and down:
    I considered mounting them on my newer motion rig, but after getting them attached I decided I didn't really want to make the actuators have to deal with another 50 lbs, so I took them back off and will be trying mini LFEs instead.
    Hard/sharp thump effects are probably best at lower Hz, while continuous effects such as engine RPM may need higher Hz. In one rig I had really large transducers on the corners and a SubPac seat cushion which has smaller transducers. I configured it so that low RPM engine rumble would go to the big transducers, but as the engine RPMs (and the vibration frequency) went higher it would switch over to the SubPac.
    Noise might come directly from high frequency vibration as you get into the hundreds of Hz, or from rattling parts in the rig if the transducer vibrates at a resonant frequency, and sometimes from parts inside the transducer colliding with one another when it reaches its operating limit.
    The Earthquake Q10B is about the same wattage as a ButtKicker LFE but costs yet again twice as much. I think its big advantage is a much longer throw on the piston, so it can produce stronger motion without the piston running into the housing (which makes a loud bang in the LFE). I don't recall if I've ever seen someone actually use them on a driving rig, though.
  5. David s wan
    David s wan New Member
    154Coins
    does anyone have preset for IL-2 battle of stalingrad that was release last month?
  6. marco balletta
    1,445Coins
    Thank you so much for all these info!
  7. Mpmo
    Mpmo Member
    United Arab Emirates
    1,289Coins
    Has no one made an upgrade from H3/P3 to an H6/P6 yet...? i'm still waiting for someone to confirm/deny that it's a worthwhile upgrade ffs....
  8. David s wan
    154Coins
    I don't know if anyone can help me on this, but I notice on aerofly FS 2 the game data output on "roll" is putting out -90 more than what the data should be reading....so the seat is always leaning to the left....is there a way to adjust that so the output read 0 instead of -90?
    thanks
  9. DOFreality
    DOFreality Member
    Montreal
    344Coins
    2DOF, 3DOF, DC motor, Arduino, Motion platform, 6DOF
    the best option if you are noise/ neighbors /wife concern is
    SRS ShakeKit
    153,788Coins
    +11,150 / 57 / -2
    Objectively SimTools offers far more individual configuration and game support, at a competitive price point, and also supports a huge array of both DIY and commercial motion simulators. But the great thing is it can be tweaked to play nice with other software, if people prefer to use those.
  11. marco balletta
    1,445Coins
    How about the feeling of switching the gear from high gear to low gear ?
    Do you have videos please ?
  12. noorbeast
    153,788Coins
    +11,150 / 57 / -2
  13. marco balletta
    1,445Coins
    That works only when switching gears up, from 1 to 6. When switching down from 6 to 1, there is no snappy gear change motion whatsoever, no matter the vales set for surge
  14. marco balletta
    1,445Coins
    I have a P6 from DOFReality. Would it be possible to enroll in beta testing for you?
    I am dying waiting for a solution that is plug and play and works for as many games as possible.
    I am not getting that with simtools at all
  15. marco balletta
    1,445Coins
    The question that I have is if your software needs hardware add on to give all the effects , like the switch down gear, that I am not getting with simtools.
    Could you please explain us what the software would give us and how the hardware come in place in conjunction with your software ?
    thanks!
  16. Mpmo
    Mpmo Member
    1,289Coins
    Do you have any videos of your program working on motion simulators? like the dofreality motion rigs..?
  17. marco balletta
    1,445Coins
    Thank you!
    Will the beta version compatible with the 6 dof be also available in 4 weeks?
    I am asking that because you just mentioned the 2/3dof as example
  18. marco balletta
    1,445Coins
    Great! I have the p6 (6dof) of dofreality, so I have got what it is needed :)
    Thank you so much for working on this!
  19. rsbell
    rsbell Member
    334Coins
    Same here. Can’t wait!
  20. Grease
    Grease New Member
    Indonesia
    188Coins
    hi
    cannot find update plugins for assetto corsa competizione and dirt rally 2.0 . can you fix it?
