Driving real gauges
Discussion in 'DIY peripherals' started by fastdruid, Jun 16, 2011.
  1. sarge351
    sarge351 New Member
    442Coins
    To: FastDruid
    Like you, I am interested in building a Real Car. Specifically, I am interested in building a Mazda RX-8. Furthermore, I want to do an LSX swap into the RX-8. After speaking with experts in the field, it sounds like the mechanical swap is fairly straightforward, but that the electronics is the difficult part. More specifically, the CAN bus and the gauges are the difficult part. After reading your thread, it sounds like you may be the World Expert in working with the RX-8 gauge cluster and the Mazda CAN bus.
    Would it be possible to get more help from you concerning an LSX conversion in a Mazda RX-8? I guess this would entail getting the GM E38 ECM for the LS3 motor to communicate with the Mazda Tachometer cluster through the CAN bus.
  2. fastdruid
    fastdruid New Member
    57Coins
    I may be able to sell you a board to do that as I'm getting a batch of boards made up for CANBUS comms and have a MOQ of 5....
    I don't know what the tacho output on the GM E38 is but it'll either be pulse (5v or 12v) or CAN so should be pretty trivial.
    You're still going to lose the stability control etc though but you can at least stop the light from coming on.
    PM me your email address...
  3. tadythefish
    tadythefish Active Member
    Process automation engineer
    Slovenia
    679Coins
    does anyone have a arduino sketch for driving fiat or BMW gauges?
  4. Sigma
    Sigma New Member
    146Coins
    Im building a cluster with the arduino and the canbus shield. hoping to run Assetto Corsa. could anyone help with this??
    154,729Coins
    +11,213 / 57 / -2
  6. Sigma
    Sigma New Member
    146Coins
    Awesome thank you for your help! but I dont see anything with canbus.
    I have few programs and cant figure out which one i can use to (ACorsaArduinoConnector, ACTI, and x-sims) but i cant figure out how to send the info to my shield. Im running Assetto Corsa
    I would like to make it as simple as possible. by using my arduino and my can-bus shield and communicate with a OBD2 cluster. If anyone can help me or give me pointer. is anyone else working on this?
  7. Helium
    Helium New Member
    Earth
    380Coins
    Why didn't I read this earlier? I already bought some old BMW E36 dashboard without CAN bus :(.
    I even chose it because it has no CAN bus.
    But driving the gauges shouldn't be that hard to do (I guess you just need some square waves and maybe analogue signals for temperature and gas). But I'm not sure if it's possible to drive the display so I planned on replacing it.
  8. BigMetalFan
    BigMetalFan New Member
    Russia
    214Coins
    Sorry for bumping old thread, but have anyone got the trip meter to work?
    Byte [1] at ID 420h seems to do nothing to it, any thoughts?
  9. dahfl
    dahfl New Member
    Administrator
    Mülheim Ruhr
    485Coins
    3DOF, DC motor, Arduino, 6DOF
    for my project i have now 3 questions.
    1) someone has an idea how i can turn off seat belt?
    2) the fuelgauge can connect with a poti. But which pins?
    Or can i also control this with the arduino? (this work with my e36 tacho)
    3) control of the tripmeteter would be nice
    regards Andreas
  10. fastdruid
    57Coins
    It's been a long time since I looked at this...
    ) I don't have the wiring diagram to hand but I seem to recall that it's another set of pins which connects to the seatbelt module.
    2) See the diagram on page two, last three, pins 27.28 and 29.
    3) IIRC Trip meter is incremented in something like 0.025m increments, you flip the byte between the different values 0x10, 0x11, 0x17 which increments the trip by 0.1m per cycle and then that in turn increments the odometer every mile.
  11. BigMetalFan
    Russia
    214Coins
    Thank you for the reply!
    I was in doubt regarding the byte
    I see now that it isn't sort of counter, but instead only defined set of exactly 3 values can be observed
  12. dahfl
    dahfl New Member
    Administrator
    Mülheim Ruhr
    485Coins
    3)
    ok a short test with trip work fine. Thank you.
    but it must be dependent on the speed ? how can calculate the real trip in a game ? any ideas ?
    PHP:
    byte trip[3] = {0x10,0x11,0x17};
    int x=0;
    for (
    x=0;x<2;x++){
    CanSend(message_id_420,0x98,trip[x],0x00,0x00,0x01,0x00,0x00,0x00);
    2)
    for the gauge i think you mean 2T, 2R and 2P ?
    1)
    is it possible to switch off the signal seat belt? I read the signal comes from another k-bus .
  13. BigMetalFan
    Russia
    214Coins
    distance is speed integrated over time
    finite differences method will do
  14. fastdruid
    57Coins
    The original signal comes from the ABS HU/CM which monitors the 4 wheels and then gives the speed signal as well as works out the distance to trigger the trip. It's reasonably trivial to work out distance from the speed and time elapsed and trigger the trip that way.
  15. fastdruid
    57Coins
    K-line is theoretically possible, it's a one wire 12v bus which is relatively trivial to write to from TTL voltages but I don't have a clue what it needs in terms of data....
    Plus I don't know if it would need two way communication which makes things much trickier.
    Easiest way truth be told would be to open it up and either de-solder, destroy or cover over the seat-belt warning led!
  16. pup
    pup New Member
    Russia
    200Coins
    There's seem to be some mistake? 0.025*3=0.075, not 0.1?
    Moreover, supposing, we're moving 120km/h. It is 33 m/s, right? Supposing, it requires 3 flips for 0.1m. Then, it means 990 can messages per second, right? that means, these can messages are sent almost once a ms? I've read that this dashboard expects can messages each 20-500ms. Which of these above statements is true?
    And one more question: is it possible to feed data to the dashboard from different devices? rpm from one board, speed - from another one?
  17. fastdruid
    57Coins
    It's a mistake, it's kilometres not metres! :)
    It's been a long time since I looked at this, I can't recall now if there was a fourth byte (which doesn't actually do anything) but or if it was just the three. Either way 0.033km or 0.025km increments.
    Yes, that's how it works in the car. Although you can't send different bytes under one ID with different devices. So for example you couldn't send speed and RPM from different devices as they are both under ID201.
  18. pup
    pup New Member
    Russia
    200Coins
    yep! thanks alot for clarification! This means, I can send speed/rpm from one device and trip increments - from another one!
    the last thing to learn, probably, is that fuel gauge. when investigating this issue, i've bumped into some pages, explaining that there are two different sender units, and the cluster needs readings from both of them. Probably, they don't need to be hi-watt resistors, since the arrow in the cluster is not bimetallic, but rather a stepper-driven. The questions are: for a certain level, both resistors should be of the value? are they linear? how do I control the arrow, say, from arduino?
  19. pup
    pup New Member
    Russia
    200Coins
    could you guys (@dahfl, @fastdruid) please look through this logfile of can messages. I am trying to sort out the trip meter, but no luck.
    is it okay that I am sending several messages with the same second byte, after changing its value to the next one?
    If no, how do I change the other values (lamps, coolant temp) wihout incrementing the odo then?
    • 1.txt
      File size:
      146.1 KB
      1,125
  20. donovan
    donovan New Member
    169Coins
    2DOF, 3DOF, Arduino
    I god an audi a4 dash ill if i can do something with it.. btw nice job
