Showroom Driving simulator building tutorial 3DOF heave axis
Discussion in 'Commercial Simulators and Peripherie' started by momoclic, Oct 31, 2016.
  1. siemenson
    siemenson New Member
    Hangzhou Zhejiang China
    353Coins
    [QUOTE = "momoclic, Post: 116853, member: 12299"] Written in French I converted the text with "Google Translate" I hope this will be readable in English.
    Thanks for your understanding.
    Embodiments by different manufacturers:
    Examples by different builders:
    https://www.xsimulator.net/community/threads/simulateur-3-dof-heave-motor-350w-24v.8358/
    http://pcshm-simulateurs-homemade.clicforum.com/t932-Projet-3DOF-2-DOF-1-DOF-Wanegain.htm
    http://www.racingfr.com/forum/index.php?showtopic=51621
    http://pcshm-simulateurs-homemade.clicforum.com/t1010-Projet-3DOF-de-vince-129.htm
    [/QUOTE]
    good job!
  2. RJ Stausebach
    RJ Stausebach Member Gold Contributor
    Ireland
    315Coins
    Many thanks, this is extremely informative.
  3. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,773Coins
    DC motor, Arduino
    Thank you !
  4. mprofitt
    mprofitt Member
    230Coins
    Very nice post! Thank you momoclic. As you know, I am working through the math and this really helped me a lot!
    154,717Coins
    +11,213 / 57 / -2
  6. djboss001
    djboss001 Member
    Test engineer
    - 34Coins
    Thank you for this very complete tutorial, good job. ;)
  7. rob yan
    rob yan New Member
    China
    14Coins
    2DOF, 3DOF, SCN5, SCN6, Arduino, 4DOF, 6DOF
    good job,this is a good learning process.
  8. that_is
    that_is New Member
    China
    207Coins
    love it! what a rig!
  9. that_is
    that_is New Member
    China
    207Coins
  10. Tao
    Tao New Member
    United States
    94Coins
    Thank you for you tutorial! Do you mind telling me which code you used to control 3 motors using 2x Sabertooth and 1x Arduino combo? The code I found is only good for 2 motors.
    • Disagree Disagree x 1
  11. momoclic
    Retraité
    Nantes - France
    2,773Coins
    DC motor, Arduino
  12. arrakys
    arrakys New Member
    bordeaux
    56Coins
    2DOF, SCN5
    Excellent work, amazing tutorial.
    Vive la France ;)
  13. fourteenary
    fourteenary New Member
    299Coins
    2DOF, 3DOF, Arduino
    Very helpful tutorial. Good reference for my DIY.
  14. shaman
    shaman 2dof sim Gold Contributor
    Moscow
    - 984Coins
  15. momoclic
    Retraité
    Nantes - France
    2,773Coins
    DC motor, Arduino
    Désolé mais pour moi il fonctione parfaitement !
    Peut-être qu'il faut posez la question sur le forum PCSHM ?
    Sorry but for me it works perfectly!
    Maybe you should ask the question on the PCSHM forum?
  16. dominike
    dominike New Member
    462Coins
    Excellent work,very helpful tutorial
    thank you for sharing
  17. Andrei14
    Andrei14 New Member
    183Coins
    Very good tutorial. This inspires me a lot. There is any possibility to receive the 3D model?
    Thanks a lot!
  18. momoclic
    Retraité
    Nantes - France
    2,773Coins
    DC motor, Arduino
    Thank you all and make good use of it ;)
  19. Metaverum
    Metaverum Member Gold Contributor
    146Coins
    2DOF, 3DOF
    Amazing work! It's very well documented and every detail laid out, love it. Just one question, you are using 2 2x32 Sabertooths, and said that this is good in case we want to add a 4th motor later. Is it possible to use a different type of card to cut the cost even more? I believe Syren has 1x25 cards, and 3 of those would be cheaper than 2 2x32 cards. I am quite a newbie, so I don't understand what the difference in 7 ampers would cause here. It's cheaper by 25 dollars though.
    https://www.dimensionengineering.com/products/syren25
    https://www.dimensionengineering.com/products/sabertooth2x32
  20. momoclic
    Retraité
    Nantes - France
    2,773Coins
    DC motor, Arduino
    Thank you, :)
    Yes, the 4th port of the Sabertooth can be used for a fourth engine.
    If our choice is to stop on this type of H-bridge it is because in our eyes it was the most suitable for the expected performance in relation to the engines to be used.
    Then it is necessary that the chosen card is in correlation with the intensities required by the motors.
    However, there is nothing mandatory to use anything else, but I don't know of an equivalent product for a lower cost...
