Showroom Driving simulator building tutorial 3DOF heave axis
Discussion in 'Commercial Simulators and Peripherie' started by momoclic, Oct 31, 2016.
  1. luu trung
    luu trung Member
    172Coins
    hi. do you have 2 arduino and 4 IBT2 schematics? i plan to make 1 more traction loss motor
    154,729Coins
    +11,213 / 57 / -2
    The schematics will be the same for each Arduino, they will just be on different ports and configured accordingly in SimTools Interface Settings, which is where you designate the assigned axis for each:
  3. Kenshiro27
    Kenshiro27 Active Member
    253Coins
    2DOF, 3DOF, Arduino
    A very big thank you for this quality work and so well documented.
    The three dof bible:thumbs
  4. Kenshiro27
    253Coins
    2DOF, 3DOF, Arduino
    Have you ever thought of adding traction loss to your simulator?
  5. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,773Coins
    DC motor, Arduino
    thank you
    Simukit did it you can see it on their website.
    No particular constraints. No need for two cranks, one is enough.
    It is important to respect the positioning of the crank to ensure the symetry of the movements.
  6. Kenshiro27
    253Coins
    2DOF, 3DOF, Arduino
    Yes, I took a good look at your document, the crank angles and lengths to respect. I will try to make the model. Yes, I know simukit, which was A LOT inspired by it
    You also gave me advice for my 2DOF on the PCSHM site it seems to me
  7. Michail
    748Coins
    With a rotatable joint at the bottom, it tends to wiggle too much.
    https://youtube.com/shorts/jKzlTrDgzaQ?si=LWuLRW8FDvp-ICER
    I've decided to install it at the old position of the U-joint base due to the limited movement from my U-joint. I think it cannot lower as much at the front.
    At this point, I'm running out of ideas. Maybe I should just install the new base without the rotation and rotational joint, but then I would lose the ability to simulate traction loss.
    The old base is there only to provide temporary stabilization.
  8. skitradr
    skitradr New Member
    - 136Coins
    Been a member here lurking in the “shadows” for some time now, but yes i agree, very nice heave design, Great job
  9. momoclic
    Retraité
    Nantes - France
    2,773Coins
    DC motor, Arduino
    Thank you so much.
  10. skitradr
    skitradr New Member
    - 136Coins
    Im sorry, I meant I myself have been “hiding”,
    I want to personally thank you for your post, its absolutely beautiful, Thank You very much.
  11. X.STTONER
    X.STTONER Sttoner
    business manager
    lima
    237Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, Motion platform, 4DOF
    Excellent work and a very good, detailed guide; it cleared up several doubts for me. Thank you.
