Showroom DX - Compact Simulator
Discussion in 'DIY Motion Simulator Projects' started by noorbeast, Sep 29, 2014.
  1. h1dden_proc3ss
    h1dden_proc3ss New Member Gold Contributor
    Melbourne, Australia
    - 49Coins
    How about this side (the keyed tube/keyway)? Was this something machined?
    154,711Coins
    +11,212 / 57 / -2
  3. Raulmerlos
    Raulmerlos Member
    Mecanico maquinaria calzado
    Monóvar (Alicante) España
    138Coins
    3DOF, Arduino
    Very good work :thumbs:thumbs:thumbs:thumbs:thumbs:thumbs
  4. sci666
    sci666 Active Member Gold Contributor
    1,210Coins
    i had the similar problem, there is no shop for finished rings like this, they have to be individually ordered by some metal processing company .. but this will be relative expensive ...
    so i just ordered normal adjusting rings with grub screws and screw it into the axis groove.
  5. Kevinski
    Kevinski If it doesn't fit, hit it until it does. Gold Contributor
    Jack of many trades, mastering some.
    Australia
    85Coins
    @noorbeast how do you find your JRK's? Which ones do you use? Do they run with arduino's and an associated sketch for use with SMC3 utilities?. I have seen posts by guys like aero robby who swear by them. These could be an alternative to sabretooths. They don't seem quite as expensive.
    154,711Coins
    +11,212 / 57 / -2
    The old JRKs I used are still going, but have long since been superseded by other more robust JRK offerings, across four power variants: https://www.xsimulator.net/community/faq/new-higher-voltage-amperage-jrks.368/
    JRKs use their own interface configuration utility, similar to SMC3, and no Arduino is necessary.
