Elite Dangerous Horizons Plugin (Non VR Version) [Deleted]
Discussion in 'SimTools Plugins' started by value1, Dec 22, 2014.
Thread Status:
Not open for further replies.
  1. SilentChill
    20,604Coins
    You need to install the patch to where EliteDangerous32.exe is located.
    If it's still not working maybe they have updated the game again and the plugin will need updating too
  2. kermitkong
    kermitkong Active Member Gold Contributor
    Hardware Development
    1,240Coins
    hi @SilentChill ,
    my installation path for elite dangerous is: C:\Users\me\AppData\Local\Frontier_Developments\Products\FORC-FDEV-D-1010
    i tried to patch several times but the message "patch installed" NEVER pop up.
    i double checked with the racing game LFS, here is everything fine and the message "patch installed" appear.
    now i'm lost...
    i'm using elite dangerous from the Elite-Launcher (frontier) not via steam, is this something to keep care about it which platform i use?
    how i can see whether the current version of elite is compatible to SimTools ?
  3. SilentChill
    20,604Coins
    Ermmm I'm not sure ? looks like correct install Dir. The game is still 2.0.0.8 which is what the plugin was for it is working fine here I just checked.
    Are your other games outputting values into the tuning settings in simtools game engine ?
  4. kermitkong
    1,240Coins
    let me try to install it to another mahine first.... then ill double check it with other games...
    THANKS FOR SUPPORT !!!
  5. kermitkong
    1,240Coins
    i've still probplems to setup SimTools.
    I already installed live for speed , patched the game, but cannot see any movement from the game to SimTools, also cannot see any movement/changes inside the TuningCenter.
    The virtual axis inside GameEngine Windows also does not show any movements :(
    quick question:
    in the quick installation guide of simtools, saw the following requirements
    Requirements
    a) Mandatory :
    • Windows XP, Windows 7, Windows 8
    does this mean, that windows 10 does not work ?
  6. kermitkong
    1,240Coins
    hi,
    here some additional information about the problem to run SimTools propertly
    i'm using Widows 10 btw.
    so i tried the "joystick plugin" to findout some more helpful relations between APP SimTools-Engine and SimTool-GameManager.
    1. if i started the SimTools-Engine and SimTool-GameManager, the SimTool-Game-Manager said "connected" :thumbs
    2. i patched the joystick-plugin into the \SimTools directory as discribed and i've got the Window "patch installed (in White color not in green color) , so i guess its fine :thumbs
    3. when i'm in the output testing menu and the Axis testing is started i can change the values in the Tuning-Center by using the sliders in the axis-testing menu of the SimTools-GameEngine. :thumbs
    4. when i check whether the joystick deliver data by using the SimTools_Joystick_Recorder.exe i can see in the generated texfile, that the parameter for all related sticks and switches were recorded:thumbs
    5. back to SimTool-gameEngine, in the output setting under virtual Axis (activated by turned on) i cannot see any changes when i'm using (moving) the joystick, so seems to be that the connection to the Engine does not work ?:(:(:(:(
    6. also cannot see any changes in the TuningCenter in the green upper area, also cannot see changes in the red lower area :(:(:(:(
    7. i'd tried several games,
    elite dangerous (no message of patch installed)
    LFS , here comes the right patch installed message, but also does not wor.
    seems to be the same issue , that the information cannot collect out of the application or cannot route to the SimTools application propertly.:(:(:(
    also double checked the firewall in windows10, theres no limitation regardings SimTools
    has anybody an idea whats going on with my setup ? :sos
    154,726Coins
    +11,194 / 57 / -2
    SimTools with Win10 works fine.
    A problem with installing SimTools does not belong in the ED thread. Nor is there enough information for members to assist, you need to tell us about your rig hardware and post pictures of things like your interface settings. Please start your own thread here: http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
  8. value1
    14,279Coins
    EliteDangerous 64bit needs fixing. Currently the only plugin that works is the 32bit version of @SilentChill , which can be found here. Are you aware, @kermitkong?
  9. SilentChill
    20,604Coins
    oooops didnt realise this wasn't my 32bit thread :eek:
  10. SilentChill
    20,604Coins
  11. jugnor
    jugnor Jugnor Gold Contributor
    Mechanical designer
    Nantes - FRANCE
    249Coins
    2DOF, SCN5
    Cant wait!!
  12. value1
    14,279Coins
    YESSS we are @SilentChill! Show us your Sim with motion and ED! :)
  13. SilentChill
    20,604Coins
    Its happening !!!!
    Had to find alternate memory addresses for Heave Sway and Surge they were going crazy inside stations
    • Winner Winner x 3
  14. SilentChill
    20,604Coins
    • Winner Winner x 4
  15. darkcrayon
    darkcrayon Member
    New York, NY
    305Coins
    3DOF, SCN5, 6DOF
    Man, you're a hero! Now I have to fire up all my gear I just turned it off, to try this!
    I understand why you (& value1 for that matter and the other plugin heroes) won't take donations, as you don't want this to be a "job" that puts you on the hook for these things, but i'd be clicking that button if it were here :D
    I need Frontier dev to fix Elite on the HTC Vive... I was hoping that comes soon, but now I hope it doesn't!
  16. Avenga76
    Avenga76 Well-Known Member
    Network Engineer
    Auckland, New Zealand
    3,262Coins
    You are a legend!! I will give it a try as soon as I finish upgrading my motion simulator.
  17. SilentChill
    20,604Coins
    Forgot to mention I don't have the steam version so I have no idea if it works on there.
  18. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    I was in the UK for a few weeks, mid March and I did think about calling on you to say "G'Day" - Glad you posted this video now... I'd be BANGING DOWN YOUR DOOR for a go on that!! Man, it looks Epic!!!
    Well done!!!
  19. Wanegain
    Wanegain Active Member
    Bruxelles
    2,019Coins
    Tonight I'll try for the Steam Version. I think it will work because steam version is just launching the ED launcher :p
    Thank you @SilentChill and @value1 for this plugin hug:!!
  20. Imeleon
    Imeleon Member
    Construction Engineer
    Chippenham UK
    - 44Coins
    2DOF, SCN5
    @SilentChill you sir are a steeley eyed missile man.
    I have my motion back in space. Yippee.
    Even just on my 2dof it feels awesome.
    Great work. You and @value1 and all others involved in getting motion for all these games.
Thread Status:
