Elite Dangerous Horizons Plugin (Non VR Version) [Deleted]
Discussion in 'SimTools Plugins' started by value1, Dec 22, 2014.
Thread Status:
Not open for further replies.
  1. noorbeast
    154,732Coins
    +11,195 / 57 / -2
  2. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    @SilentChill
    MOVEMENT!!! I'm using the steam version and I now get movement.... BUT.... (I know.. a BUT...)
    The movement is very random it would seem, however, I've not tuned my profile at all, so this might be expected before I tune it?
    When I roll pitch is also moving (in tuning centre) with values between -1 and +7)
    If I accelerate and then stop, the sim goes to centre quite violently.
    Again, I have no idea what to expect in terms of movement. We are in space dealing with inertia etc... I'm just over the moon (pun intended) that I have some movement.
    What is everyone else's experience using the Steam Version? (I ran it direct from the EDLaunch, not the Steam client)
    My version is reported as:
    V2016.06.29 112060 0.4.55370 [0.45499.0 SERVER] ND
  3. SilentChill
    20,604Coins
    I have no idea whats going on with the website I uploaded it with 3 updated plugins between 2nd and 5th July and obviously none were working people because as it was the same old bloody plugin not the updated one.
    @Historiker maybe you can help
    @value1 have you had this happen ?
  4. SilentChill
    20,604Coins
    Tuning centre should all be set at 1.1 apart from Roll which should be 1.8.
    You need to check every DOF in tuning centre just to see whats going on. If you reset the values in tuning centre and then go through the DOF's one by one and if you can use a keyboard for this because when you use a stick or joypad you get movement from roll and pitch together and posiibly some sway and heave thrown in too.
    Do each individually and let me know how it is please :)
  5. Archie
    Wollongong, NSW, AU
    3,797Coins
    Will do that right now... :)
  6. Wanegain
    Wanegain Active Member
    Bruxelles
    2,019Coins
    I tested yesterday and it was working fine for me. But if there is a new version I think I have to update the plugin...
    Thank you for the work ! :cheers
  7. Archie
    Wollongong, NSW, AU
    3,797Coins
    I've tested with a keyboard @SilentChill and still some mixing of the axis, but as I said I don't know what to look for so this might be expected.
    I'm uploading a video again so you can see.
    However, all the forces / axis are responding as they should. I can't thank you enough for persisting with this, it must be a right pain in the arse!
    Will post to link to video once it's uploaded.
    (EDIT: Upload will take about 1 hour! - Crap Antipodean Broadband speeds!)
  8. Historiker
    Michigan USA
    9,212Coins
  9. Archie
    Wollongong, NSW, AU
    3,797Coins
  10. SilentChill
    20,604Coins
    Yes the numbers you see going all over aren't actually doing anything I think they are called notation numbers or something @value1 probably knows hes the nerd :p
    I'm glad it works, probably could of saved a bit of time if I had listened to @mohammad about the plugin not actually updating on the website grrrrrr
    Hope it works for everyone now :D pleassssseeeeeeeeeeeeeeeeeeee......................
  11. mohammad
    mohammad Member
    iran
    159Coins
    Hi @SilentChill
    thank you for plugin
    I test
    one problem ,in the charging PITCH no move but in the uncharging very good
    I found good point and 8 hours test, you can test if ok please take plugin, thanks.
    "eliteDangerous64.exe"+02264478=x
    x+208=y
    y+3e8=z
    address=z
    this address for PITCH
  12. SilentChill
    20,604Coins
    Does Heave Sway Surge and Yaw work ??
  13. mohammad
    mohammad Member
    iran
    159Coins
    Yes good work but pitch in charge bad work
  14. SilentChill
    20,604Coins
    Pitch has to work as it is the next memory address next to Yaw
  15. mohammad
    mohammad Member
    iran
    159Coins
    PITCH work but in "frameshift charge" not work
  16. mohammad
    mohammad Member
    iran
    159Coins
    Hi @SilentChill
    x+208=y
    y+3e8=z
    address=z
    Are you check Address?
    True or false?
  17. SilentChill
    20,604Coins
    Try this @mohammad and anyone else NEW UPDATED PLUGIN AGAIN !!!!
  18. kermitkong
    kermitkong Active Member Gold Contributor
    Hardware Development
    1,240Coins
    at this place, i would like to thank you to @SilentChill for all the effort. thanks man !!!!!!!!!!!!!!hug:
  19. mohammad
    mohammad Member
    iran
    159Coins
  20. Archie
    Wollongong, NSW, AU
    3,797Coins
    We need a "That's Awesome!!" button. :)
Thread Status:
