Elite Dangerous Horizons Plugin (Non VR Version) [Deleted]
Discussion in 'SimTools Plugins' started by value1, Dec 22, 2014.
Thread Status:
Not open for further replies.
  1. yobuddy
    51,753Coins
  2. WhiteGoblin
    WhiteGoblin Member
    California
    549Coins
    Have a good vacation. Just my luck a patch ruined motion the exact day I was ready to test. Fortunately the training mode still works great for testing.
  3. Lars
    Lars New Member SimAxe Beta Tester Gold Contributor
    381Coins
    ..can t wait until you come back...counting the day´s.
  4. Corporatezombie
    Corporatezombie Member SimAxe Beta Tester Gold Contributor
    Leicestershire
    148Coins
    3DOF, SCN5
    Have you had a lovely holiday? Chances are, you'll re-patch this, and they'll bring out 1.4 cqc!
  5. value1
    14,298Coins
    Oh, yes, I enjoyed the holidays very much.
    Now i'm struggling to collect the accelerations for Elite :(
  6. WhiteGoblin
    WhiteGoblin Member
    California
    549Coins
    Good luck. I'm patiently waiting to try out elite.
  7. value1
    14,298Coins
    • Winner Winner x 7
  8. Corporatezombie
    Leicestershire
    148Coins
    3DOF, SCN5
    Thank you very much!
    Three words.
    Best Thing Ever.
    I'm using these settings with a Simexperience + traction loss setup. And it seems great to me!
    But others may have better settings that they might like to share!
    Axis 1 (SCN Packet rate 8, Speed 2197 Accel 500)
    DOF2 inverted, surge 15% smoothing 3%.
    DOF4 inverted Roll 15% washout 5%
    DOF 5 Pitch 10% washout 5%
    DOF 6 Heave 5%
    Axis 2 (SCN Packet rate 8, Speed 2197 Accel 500)
    DOF 4 Roll, 15% washout 5%
    DOF 6 Heave 5%
    Axis 3 (SCN Packet rate 8, Speed 2197 Accel 500)
    DOF1 inverted, Sway 10% washout 10%
    DOF 3 inverted Yaw 20% washout 5%
  9. WhiteGoblin
    WhiteGoblin Member
    California
    549Coins
    It works! Thanks!
  10. Lars
    381Coins
    You are my Hero .. will check it today...
  11. leaedman
    leaedman Active Member
    Valenciennes, France
    470Coins
    Thank you for your work value1 :thumbs ...
  12. Atlas974
    Atlas974 old school
    Physics chemestry
    Reunion island
    358Coins
    Thank you Value1! :thumbs
  13. WhiteGoblin
    WhiteGoblin Member
    California
    549Coins
    Hmm after playing for a while the plugin no longer functions properly. It starts to alternate between no movement at all, completely random movement, and partially functioning.
  14. value1
    14,298Coins
    Thanks for the feedback.
    Does this happen with pitch, roll and yaw or with surge, sway and heave or with all movements?
  15. Lars
    381Coins
    Hello, I can confirm this.
    If I hyperjump to another system my movement is always gone. .then from time to time there is some movement but this seams to be random.
  16. Lars
    381Coins
    so tested again...at this run Roll and Yaw are the first without data in tuningcenter (but roll was not set to 0 but there was a static value)
    Then in hyperspace there is no movement - all input is set to 0
    Then there is coming movement back from time to time but absolutely uncontrolled..
  17. WhiteGoblin
    WhiteGoblin Member
    California
    549Coins
    I'll test further this evening, but I believe the (buggy) movement tends to come back when I approach other ships and stops when I move far enough away. This was in solo, so NPCs in this case.
  18. Scratch
    Scratch Active Member
    281Coins
    Loving this so far! Thank you very much @value1 for your work and keeping this up to date! Starting my first full haul now, will see if that no movement bug catches me also.
  19. Scratch
    281Coins
    Yup, same here. At first I had no movement at all, I started from docking bay, Open mode. Then I exited to menu, tried training mode, also no movement there. Restarted the game and started Open mode, everything works! But after hyperjump, no any kind of movement.
    Edit. And like others, I also experience short random periods of some crazy movements if I continue to play after movement first disappears.
  20. noorbeast
    154,729Coins
    +11,213 / 57 / -2
Thread Status:
