SilentChill
EliteDangerous Horizons Plugin (OLD Archive Thread) Version 3.3.0.2
EliteDangerous Horizons Plugin (VR Version)
Thread Status:
Not open for further replies.
  1. SilentChill
    20,659Coins
    Good job @Wagnard :D
    I'm in new york so cant do anything until i get home at the weekend
  2. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,383Coins
    Everything seems under control.:cool: Have a nice trip man.
  3. George Dobransky
    Hungary
    - 37Coins
    Wagnard,
    The latest plugin package doesn't include the xml at me.
    After updated the plugin, with the latest xml file (533 bytes) In the srv has no movements.
    With the previous xml (the surge seems to be reversed and the sway
    has strange movements.)
    If I load the game directly in srv, no movement till I board to the ship. After once boarded and deploy, there is
    movements in the srv.
    At you guys? is that different?
    George
  4. Wagnard
    Wagnardsoft
    5,383Coins
    You need to unpatch and patch with latest plugin with GameManager launched with Admin priviledge for the XML to be extracted to the right place.
    Can you allow me to check with CheatEngine directly on your computer the Values of the pointers via TeamViewer? If you agree, give me the ID and Password that teamViewer will give you in Private Message.
    Edit: got a repro. Will try to fix this,
  5. George Dobransky
    Hungary
    - 37Coins
    I have tried to unpatch, repatch, but the same issue. The surge is reversed.
  6. George Dobransky
    Hungary
    - 37Coins
    Wagnard,
    After a few more tests at me in the srv the surge directions are changing as I turn with the srv.
    I mean if I go for example heading 0 - the surge dirs are ok, if I turn 180 degree, to heading
    180 with the srv - the surge dirs are reversed. The same strange thing I experienced with sway.
    The heave, roll, pitch seems to be OK.
    Cheers,
    George
  7. Wagnard
    Wagnardsoft
    5,383Coins
    Yep I can confirm. Trying to sort this out.
    Edit: here is the updated pointer for SRV.
    It should fix the surge ( you may have to adjust your max/min).
    It should fix when starting directly on the SRV.
    As I don't have a 6DOF (yet) , It's hard to test the Sway for me. From what I see on screen with trial and error, it seems fine. Tell me if this at least fix some of the issues you had.
    Time for a break for me, spent all day on theses pointers.
  8. DOFreality
    DOFreality Member
    Montreal
    344Coins
    2DOF, 3DOF, DC motor, Arduino, Motion platform, 6DOF
    File inside plugin has a double "__" and it should only be one
    please change the file name from "__MinMax.cfg" to "_MinMax.cfg"
  9. Wagnard
    Wagnardsoft
    5,383Coins
    It doesn't have a double __ in my latest release.o_O
  10. SilentChill
    20,659Coins
    All day ? Thought you had it going to easy :grin
  11. Wagnard
    Wagnardsoft
    5,383Coins
    Haha lol ok a few hours. especially the SRV
  12. George Dobransky
    Hungary
    - 37Coins
    Wagnard,
    Getting better and better... SRV: now surge, heave, roll, pitch are OK, sway also working right, but the opposite direction as in the ship.
    The other problem I recognised for 6DOF users:
    I'm using 6DOF platform, in this way if I'm using roll, pitch, heave, surge, sway forces I only have one more free DOF for extra1 or extra2.
    That means If I want to get roll and pitch together in the srv, I has to kick off one of the other forces, or I can only use one of the extra's.
    I have also tried to assignthe same com ports to (b) Axis Assignments also, but the same com port can only be directed to a, or b Axis Assignments,
    not working parallerly in a and b in the current Simtools version.
    Any ideas?
    George
  13. Benji85
    Benji85 Member Gold Contributor
    851Coins
    Hey, finally had a chance to test this out again this morning and all is working well! Many thanks for your efforts :)
  14. Wagnard
    Wagnardsoft
    5,383Coins
    Plugin update:
    -Yaw and Sway had he same value:eek: . Now fixed !
    -Added the possibility to reverse the direction of a DOF via the XML file.
    -Latest XML included in the plugin, don't forget to re-patch with GameManager with admin privilege.
  15. fusednova
    fusednova Member SimAxe Beta Tester Gold Contributor
    769Coins
    I stepped away for over a year but really nice to come to a working plugin. Thank you!
  16. Wagnard
    Wagnardsoft
    5,383Coins
    -Possibility to change via XML the option to use the SRV with the Roll / Pitch instead of Extra (seems needed for some 6dof motion platform.).
    -Small fix to the SRV pointers I forgot to modify in a previous update that generate no data if we enter the game directly into SRV.
    -Possibility to change via XML the forces of the SRV.
    (Note: The forces are in %, valid from -32768 to +32767 no decimal) default 100 of course.
    If you select to not use the Extras, usually a 3% is not bad.
  17. SilentChill
    20,659Coins
  18. SilentChill
    20,659Coins
    This resource has been removed and is no longer available for download.
  19. SilentChill
    20,659Coins
    Sorry guys accidentally deleted the entire Plugin page , not just the file like I was suppose to DOH !!
  20. Wagnard
    Wagnardsoft
    5,383Coins
    Lol, you can repost a new one with mine if you want. Or maybe a forum mod can do something.
Thread Status:
