SilentChill
EliteDangerous Horizons Plugin (OLD Archive Thread) Version 3.3.0.2
EliteDangerous Horizons Plugin (VR Version)
Thread Status:
Not open for further replies.
  1. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,383Coins
  2. George Dobransky
    Hungary
    - 37Coins
    Hi Guys,
    xml is a good thing to customize our own setup - I mean I had to reverse pitch and sway in the srv, as well the
    amounts of forces in the srv has to be far not the same as in the ship at me.
    Craig,
    with the extra1,2 version how can we use all forces with a 6DOF system?
    I mean if I set up roll,pitch,sway,surge,heave,yaw in the ship, how can I add the extra forces
    if all of 6 forces are reserved?
  3. SilentChill
    20,659Coins
    6DOF do not use the Extras , I have increased the values for pitch and roll in the SRV so it should kinda feel ok
    ALso all the forces are the same way as they were before in the new plugin so hopefully they should all be ok as I have not changed any directions
  4. Wagnard
    Wagnardsoft
    5,383Coins
    Just out of curiosity, how much time it take for you to get all the new pointers? I can some of yours are different so I wonder How much time and why you started to find them all since I had already them available.
  5. SilentChill
    20,659Coins
    How do you know they are different to yours ?
  6. Wagnard
    Wagnardsoft
    5,383Coins
    I know because it doesn't work on SRV for me. (unless it's a plugin issue). I wanted to check but I think you obfuscated your code. :oops: I was able to find the base address that was different. Didn't wanted to check further as it is time consuming.
    I personally thing we should share our work / pointers for time saving for both of us. So I'll be happy if you use my pointers located in the XML and I wouldn't mind to me sharing some portion of code to yours. Still thinking that only 1 plugin with an external configurable file for the pointer is the best idea. But we could still keep the 2 if that is what you prefer.
    The exact issue I have with your current plugin:
    -I start a SVR training. Spaceship work ok.
    -I landed and put out SRV, no data.
    - I enter back the ship and no data for the ship either now.
    Edit: For the SRV Pitch you use 3589C48+550+610+ xxxxx (If I checked correctly) but when I check theses on CheatEngine, this address is invalid (point to nothingness)
    On mine I used a lvl6 pointer (doesn't return random values /address after boarding the ship or returning to the menu):
    Pitch:0364A308+20+90+130+18+290+300
    Roll: 0364A308+20+90+130+18+290+2FC
    You can have a look on your end if it's logic or not.
    For the rest of the SRV we are almost the same;
    I use same level offset3 as you. My Base address :0364CD58, yours seems : 364CDB0
    Only think I would have wanted to do with my pointers is getting an higher level offset for the other SRV value so they can be like their Pitch & Roll when we board the ship or quit to menu. But lacked time/motivation at the end when everyone said it was working already...
  7. yobuddy
    51,739Coins
    Maybe share the code for XML file loading so both plugin can use the same pointer file?
    Then all the real time is spent experimenting new ideas and fine tuning the plugins rater than both people doing the same work.
  8. Wagnard
    Wagnardsoft
    5,383Coins
    Already gave my source code to SilentChill via PM.
  9. yobuddy
    51,739Coins
    I rearranged the xml file like this so a user could name Extra 1-3 in the file.
    If the plugin sees a name for extra 1 thru 3 it will then collect data for it.
    This way the user can turn them on and off.
    Just an idea more than anything else.
    (the plugin would have to be able to load something like this for it to work obviously)
    @Wagnard, Nice buddy! :thumbs
    Take care!
  10. Wagnard
    Wagnardsoft
    5,383Coins
    Your idea is already in action in my last plugin. There is a value that we can change to true or false that will make uses of the Extras or not.
  11. yobuddy
    51,739Coins
  12. kev b
    kev b Active Member
    Swindon, UK
    923Coins
    sheesh! - another ED update results in a dead rig again. The never-ending battle without api
  13. Benji85
    Benji85 Member Gold Contributor
    851Coins
    Yep doesn't work here either now :(
  14. Wagnard
    Wagnardsoft
    5,383Coins
    Posting the update on the XML thread in a minute, I already got the new pointers.
    Edit: The update is posted. Keep me inform on my thread if possible if it work or not.
  15. Benji85
    851Coins
    Hi, where can I find the updated pointers please? Many thanks
  16. Wagnard
    Wagnardsoft
    5,383Coins
  17. Benji85
    851Coins
    Awesome many thanks for the link .I update it with the add-on updater like normal? Not seen "XML" mentioned before. Sorry for being a noob ha
  18. Wagnard
    Wagnardsoft
    5,383Coins
    Simply follow the instruction , but yeah it like a normal plugin. XML is a configuration file were you can tweak some stuff and help when updating the pointers.
  19. Benji85
    851Coins
    cool, got her updated but still no movement sadly :(
  20. Wagnard
    Wagnardsoft
    5,383Coins
    you have to unpatch and patch with gamemanager
Thread Status:
