value1
Euro Truck Simulator 2 Plugin 2.0.2.2
SimTools game plugin for Euro Truck Simulator 2
  1. nguyennam09
    nguyennam09 New Member
    Hcm
    48Coins
    Just intall VC Redist 2015 x32 and x64
    Restart PC, Unpatch and repatch game
    It's work :)
  2. Historiker
    Michigan USA
    9,212Coins
    @value1 hug: quick feedback on the latest plugin with Game Dash. Works perfectly with @SilentChill s simulated wind interface. Lots of telemetry output with this game for those who want to build a dash with gauges as well. Anyone building a simulated wind system for this game; you want S<Dash11> as the speed comes out in position 11 rather than the usual position 1.
    Now...if the plugin also had vibe support I would be very happy to test that out as well... :grin
  3. value1
    14,306Coins
  4. patoch
    patoch l'AUvergnat de france Gold Contributor
    63000 clermont ferrand
    1Coins
    3DOF, SCN6
    help le plugin 2.0.0.4 ne marche pas de Eurotrucks simulateur2 comment me procurer le bon plugin merci a vous
  5. value1
    14,306Coins
    Oui, le plugin 2.0.0.4 fonctionne bien avec ETS2. Il mangue seulement le support pour GameVibe.
    Yes, plugin 2.0.0.4 works fine with ETS2, it only lacks GameVibe support.
  6. patoch
    1Coins
    3DOF, SCN6
  7. patoch
    1Coins
    3DOF, SCN6
    I need help, the eurotruck2 and american truck plugins are well patched and game engine and game manager in blue !! my cylinders do not move! how to process thank you
  8. sim2go
    sim2go Member
    Operator
    Lithuania
    343Coins
    2DOF, Motion platform
    I'll bump this - simtools seems connect to game, but can't get any movement at all.
    154,849Coins
    +11,229 / 57 / -2
  10. Bernardini
    Bernardini New Member
    - 64Coins
    Hi, I tried to play with my 2 motion but it's doesnt work... Please help me.
    Thank you
  11. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Ciao,
    Sorry, but can you be more specific about the kind of problem you have ??
  12. noorbeast
    154,849Coins
    +11,229 / 57 / -2
    You need to provide a lot more information, including posting pictures of all of your settings.
  13. Toren454
    Toren454 New Member
    139Coins
    Hello everybody.
    I have a dofreality P3 motion sim and I like it.I ask if it is possible to update the plugin to include tracking loss too?
    Happy Trucking!
    Tor
  14. noorbeast
    154,849Coins
    +11,229 / 57 / -2
    I think you mean add traction loss ;)
  15. Toren454
    Toren454 New Member
    139Coins
    I meant traction loss :)
  16. patoch
    1Coins
    3DOF, SCN6
    hello jai le méme probléme je suis passer du 2 dof ( de chez prosimu ) au 3 dof et la traction arriere ne marche pas comment procédé merci
  17. noorbeast
    154,849Coins
    +11,229 / 57 / -2
  18. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    Hello guys. Is there any pics of the settings? i have 2 scn5 doing just surge and sway and movements are terrible... many thanks!
  19. paulopsx2
    paulopsx2 Active Member
    brasil
    649Coins
    hi ! is it possible to put your line codes for wind dash11 ? i try regular lines like other games, but wind reactions are weird. on low rpm, winds stoped. At only 15mph, blowers runs like a 200mph. codes: MATH * 1 ( OR NO MATHS ) ROUND 0 and PAD 3 0
  20. dhrto
    dhrto New Member Gold Contributor
    Netherlands
    - 45Coins
    3DOF, SCN6, Motion platform
    Hi Hideki,
    I had some trouble setting up my rig for ETS2 and ATS too. I'm quite new to this software, just got/built my rig in december 2018. I have the T1000 3DOF from ProSimu, which uses SCN6 actuators.
    After a lot of fiddling, I discovered the default min/max values in Tuning Center were much to low. I suspect there is some kind of 'error' which the decimal symbol in the plugin of maybe the devs of ETS2/ATS changed something, because for me to make it work I need to use values multiplied by 1000. It almost seems the game outputs it's values in millidegrees and G's.
    Anyway here are my settings in the Tuning Center
    Roll: max/min = 5000/-5000
    Pitch: max/min = 5000/-5000
    Heave: max/min = 2000/-2000
    Yaw: max/min = 180000/-180000
    Sway: max/min = 2000/-2000
    Surge: max/min = 2000/-2000
    Then in Axis Assignments
    Surge 30%, smoothing 5, deadzone 1 (axes in same direction)
    Sway 15%, smoothing 5, deadzone 1 (axes in opposite direction)
    Pitch 60%, no filters (axes in same direction)
    Roll 30%, no filters (axes in opposite direction)
    Heave 15%, smoothing 5, deadzone 1 (axes in same direction)
    Yaw, not used
    Hopefully this helps. Please report back for others to know.
    Good luck!
