value1
Euro Truck Simulator 2 Plugin 2.0.2.2
SimTools game plugin for Euro Truck Simulator 2
  1. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    Damn... :(
    The only other thing I can think of is that I have everything running in Admin mode and my Windows 8.1 build has UAC switched off.
    Plus my Steam drive is not on C: drive, making it less likely to be affected by over-zealous Windows 8.1 protection layers etc...
  2. servili007
    servili007 New Member
    NY
    212Coins
    Do you have any comparison between the two? Currently on the x-sim and want to know more about this plugin.
  3. value1
    14,296Coins
  4. Radek vols
    Radek vols Member
    Czech Republic
    194Coins
    2DOF, DC motor
    Have you got it running? I have still have issues with this game ..
  5. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
    For me everything works fine. In the first moment I thought theres something wrong too, but after looking in tuningmanager and adjusting the values much higher (c.a 10-12) everything works well.
    I also use the Steam Version.
    Again thank you Value1 for this plugin. I have really much fun with this game :)
  6. Radek vols
    Radek vols Member
    Czech Republic
    194Coins
    2DOF, DC motor
    That is weird that it works to somebody and for sombody not..
  7. value1
    14,296Coins
    Yes, indeed. Apparently it works for some and doesn't for others...
    Have you tried to (re-)install Microsoft Visual C++ 2010 Redistributable Package as described here?
  8. Historiker
    Michigan USA
    9,212Coins
    Wasn't there something to do with the game itself where you have to "ok" use of telemetry when you first start it up? Sorry if this is not correct but it has been a long time since I got mine up and running.
  9. dJuL
    dJuL yes !
    None
    9,424Coins
    3DOF, SCN6
    Same problem here.
    I try everything, 64bits / 32 bits, as admin or not...
    Nothing in tuning center.
    I also use win8.1 maybe it is not a coincidence ?
    Also I try to reinstall vcredt x64 as you said value 1.
    But it's not possible : install says there is a version most recent of visualC+ 2010 already installed...
    Anybody here have motion under win8.1 ?
  10. value1
    14,296Coins
    I run successfully it under Win7, Win8.1 and Win10.
  11. dJuL
    dJuL yes !
    None
    9,424Coins
    3DOF, SCN6
    ok thanks @value1 so it's not due to win8.
    Very strange pb...
    I also tried to disabled all mods and it is the same...
  12. noorbeast
    154,711Coins
    +11,212 / 57 / -2
    • Old Old x 1
  13. Archie
    Wollongong, NSW, AU
    3,797Coins
    OMG! ETS2 with the Oculus?!!?!!
    I would seriously need an intravenous food source and a catheter fitted!!!! :grin
    • Funny Funny x 6
  14. noorbeast
    154,711Coins
    +11,212 / 57 / -2
    While it is nice that ETS2 has updated to cover the latest Oculus runtimes to take advantage of it you would need to use the multiple Rift runtime approach so you could still play other games like Assetto Corsa which are still using the earlier runtimes: http://www.xsimulator.net/community/threads/multiple-rift-runtimes.7531/
    Though ETS2 is covering all bases by also maintaining support for the older 0.6 Oculus runtime as well.
  15. Vladimir
    Vladimir New Member Gold Contributor
    Russia
    288Coins
    I also have not earned plugin (Win7 64 Rus). You need to change comma (,) to a point (.) in "Decimal symbol". Then plugin earned.
  16. spyderwash
    spyderwash genesy sim
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    can make a check on the parameters I got good movement and very fluid, I noticed that heave sway are invertiri, for vertical forces had to use sway, meter for lateral forces using heave movements are very abrupt and nonsensical, can I have conferms found I just this version steam?
    thank you
  17. noorbeast
    154,711Coins
    +11,212 / 57 / -2
  18. Historiker
    Michigan USA
    9,212Coins
    In an interview the CEO of SCS software (developers of ETS2) said that this was the first step in bringing mods to the Steam Workshop rather than mod makers requiring users to access dodgy spam/malware laden websites in order to download them. I am very much looking forward to this change.
  19. DaVinster
    DaVinster Active Member
    What does I.T. stand for?
    AB, Canaduh
    1,150Coins
    3DOF, SCN6, Motion platform
    Anyone able to get this working with the Oculus Dk2 version (beta) of the game?
  20. DaVinster
    AB, Canaduh
    1,150Coins
    I suppose this would be the wrong place to ask if this might work with ATS (American Truck Sumulator) which is releasing in just a few hours form now..? Same company and using the same engine I assume..
