SilentChill
EVE Valkyrie Plugin CL1163233:LIVE
EVE Valkyrie
  1. L.Dörenberg
    L.Dörenberg beginner Gold Contributor
    car bodyrepair
    Netherlands
    - 65Coins
    Ye me too, i hope someone is prepared to make this plugin working:D
  2. 4apaev
    4apaev Member
    Media
    Moscow, Russia
    486Coins
    Same here :) Currently, no space sims are working with motion and my rig just stands there.
  3. yobuddy
    51,747Coins
  4. HASAN1453
    HASAN1453 Member
    Vr arcade owner
    VANCOUVER
    424Coins
    2DOF, 3DOF, Motion platform
    My rig doesn’t move. Does it need an update or is there any trick to make it move?
  5. Sarge
    Sarge Active Member Gold Contributor
    - 181Coins
    I tried mine yesterday too with this plugin, but it no longer works. Maybe due to the name change and/or the update.
  6. STEPHANIE
    STEPHANIE Member
    HOYMILLE
    414Coins
    EVE WALKYRIE is available on steam is OCULUS, the plugins works with which version?
    154,699Coins
    +11,210 / 57 / -2
    The plugin definitely works with the Steam version, I am not sure about the one from the Oculus store.
  8. Sarge
    - 181Coins
    That's good news, will install the steam version instead. I just took for granted that the oculus store version would be the one that worked from the two versions.
    154,699Coins
    +11,210 / 57 / -2
    There are some exceptions, like Ultrawings, but in general most games are actually tested against the Steam version. And if you think about it for a moment it does not really make a lot of sense to develop a plugin with a VR capable game against an Oculus Store version, as that only works natively against one VR HMD, the Rift, unless you use Revive.
    But you will find that where the Oculus version is identical to the Steam version a plugin will still work, it just has not been tested to know for sure. I have suggested to the dev team that it would be useful to have a classification of tested versions and be able to update that when members report a plugin works from both stores.
  10. HASAN1453
    HASAN1453 Member
    Vr arcade owner
    VANCOUVER
    424Coins
    So I bought the game for nothing from Oculus store? Won’t it work? Same as E.D and ultrawings. None of them work for me. Is there any trick to make them work?
    154,699Coins
    +11,210 / 57 / -2
    The Ultrawings plugin was recently broken by a game update, but you should be able to use that once the plugin is updated again: https://www.xsimulator.net/community/threads/ultrawings-plugin.11727/page-2#post-154154
    I don't know about ED from the Oculus store, perhaps someone else can comment. It should work if it has not had any game code changes from the Steam version, but it may not if there are game code changes. Your other option is to use the generic Joystick motion plugin with it: https://www.xsimulator.net/community/marketplace/joystick-plugin.127/
  12. Mu-KwangKim
    South, Korea
    - 689Coins
    @noorbeast
    Does the steam version work?
    I tried with Steam version now and it does not work.
    EVE: Valkyrie - Warzone ... Is this a different version? @_@;;;
  13. noorbeast
    154,699Coins
    +11,210 / 57 / -2
    My understanding is that the EVE: Valkyrie - Warzone was a game rebranding name change and game code revision, and the plugin needs an update post those game changes, but I don't use it so perhaps @SilentChill could confirm.
    I would suggest using the generic Joystick motion plugin with it for now: https://www.xsimulator.net/community/marketplace/joystick-plugin.127/
  14. Sarge
    - 181Coins
    Just tried the steam versions. The standard Eve Valkyrie game works in respect to the plugin, game manager turns blue when launched. However; the game itself no longer works. The first screen gives a login error.
    Unfortunately the 'warzone' update does not work, regardless of which version, I tried both.
    As noorbeast said above, the only option is to use the joystick plugin.
  15. runar totland
    runar totland Member
    392Coins
    would it be possible to make a tutorial on how to update/make these plugins so more of us can do the work. this way plugins will be easier to keep updated, an @SilentChill can chill better when on vacation, not having to worry about us poor guys and gals with sims down.;-)
  16. Ryuuken29
    Ryuuken29 New Member
    Oslo, Norway
    268Coins
    Are there no more patches?:(
  17. BJU
    BJU New Member Gold Contributor
    Germany, Kürten
    - 12Coins
    Hi there - is that plugin dead, as it only works for "Eve Valkyrie" and not "Eve Valkyrie - Warzone" ? That would be too bad. Does anyone knows, if it will be continued or if there is another trick to use it.
  18. noorbeast
    154,699Coins
    +11,210 / 57 / -2
    When game patches break plugins your best option is using the generic Joystick motion plugin: https://www.xsimulator.net/community/marketplace/joystick-plugin.127/
    It is a real chore to maintain a plugin for a game that does not output telemetry. One new approach is being tried with Elite Dangerous, and that is a separate file so changed pointers can be updated without updating the whole plugin, but it is still a lot of work.
  19. john2910
    john2910 New Member
    125Coins
    I realy hope somebody made EVE: Valkyrie - Warzone working with a good game plugin,the game will not be updated anymore..so the patch will stay alive then
  20. noorbeast
    154,699Coins
    +11,210 / 57 / -2
