Question Extreme Axis Movement
Discussion in 'Ready, set, go - Start your engines' started by Brett Horton, Nov 23, 2017.
  1. noorbeast
    154,580Coins
    +11,190 / 57 / -2
    As a starting point set the motors according to @eaorobbie's guide: https://www.xsimulator.net/community/threads/playseat-to-2-dofseat.5401/page-2#post-56352
    If you user server PSUs and they trip out try slightly lower Max duty cycle and Max acceleration, with a slightly lower Main Level%, like 97%, in the Game Manager Profile Editor.
    All the JRK functionality and settings are explained in the manual: https://www.pololu.com/docs/pdf/0J38/jrk_motor_controller.pdf
    On the SimTools side here are the steps to creating and refining a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  2. GIB SimRacing
    GIB SimRacing Active Member
    Barossa Valley, SA
    983Coins
    Hey Brett, have you checked your potentiometers and made sure they are properly secured and can't slip in any way? The reason I'm saying this is that I have seen similar issues to what you are describing and it turned out that one of the pot's had a bit of play and would sometimes not provide the correct feedback to the jrk.
  3. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    Yes sir I have, but good thought.
  4. Brett Horton
    Tampa FL
    118Coins
    Thanks NorBeast for the tips, I will try these settings.
    The post from eaorobbie was the one I was thinking of thanks
