F1 2021 2021-09-08
SimTools plugin for Codemasters F1 2021
  1. VTD
    VTD New Member
    49Coins
    Is it posable to have this plugin work with the 2021 UDP telemetry data?
  2. Rongchen
    Rongchen New Member
    67Coins
    Tried all the tricks that I applied on F1 2019 & 2020 but just couldn’t get it work on F1 2021 to have simhub and simtools running at the same time. It appears simhub works only at UDP format “2021”, while simtools couldn’t. Simtools works at UDP format “2018” and “legacy” but shakes terribly at “2021”.
  3. Rongchen
    Rongchen New Member
    67Coins
    Both simhub and simtools are updated to the latest version. Still don’t work.
  4. Rongchen
    Rongchen New Member
    67Coins
    Like VTD mentioned above it seems the only way to get simtools and simhub working together at F1 2021 is to make simtools plug-in work under the 2021 UDP format or make simhub work under 2018 or legacy format. Please may I seek some help here as always? Many thanks.
  5. danone38
    danone38 New Member
    - 291Coins
    I have exactly the same problem, tremor on udp 2021
  6. yobuddy
    51,770Coins
    We can look into updating the plugins protocol after v3 is out.
  7. Rongchen
    Rongchen New Member
    67Coins
    Thanks so much yobuddy.
  8. Rongchen
    Rongchen New Member
    67Coins
    The November update for F1 2021 was already released and installed.
  9. Rongchen
    Rongchen New Member
    67Coins
    Hi @yobuddy, any chance to seek your help update the plugin with support to simhub (UDP 2021)? Tkx so much.
  10. Petemnz
    Petemnz Member
    Sparky by Trade
    Auckland, New Zealand
    60Coins
    Hi All,
    I have same problem with no motion in F1 2021 when simhub is running, if I stop simhub I get full motion . I believe this is because simtools and simhub use same udp port 20777.
    I tried port forwarding in simhub to 20778 but how do I edit simtools to look at udp port 20778?
    Or can I change F1 2021 to output telemetry to 20778 and port forward to 20777 for simtools to use?
    Cheers any help appreciated.
    Peter
    WORKING NOW , found how to change F1 2021 output UDP to 20778 and port forwarded in simhub to 20777 for simtools to use.
    Was jerky motion, so did a lap with Simtools tuning turned on to capture max min values and saved. Needs a bit more fine tuning but now useable.
    Update: After trying to tune found as above posts simhub doesn't work unless UDP format is 2021 and simtools only works on UDP format 2018 or less.
  11. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    UDP On
    UDP Broadcast mode On
    UDP IP address 127.0.0.1
    UDP port 20778
    UDP Send Rate 60Hz
    UDP Format 2021
    Your Telemetry Public
    I used 127.0.0.1 for same pc
    ignore title it is for F1 2021
  12. Rongchen
    Rongchen New Member
    67Coins
    The plugin for F1 2021 cannot run properly at UDP format 2021 for the time being while simhub for F1 2021 can only run at UDP format 2021, that’s the reason. Awaiting yobuddy to update the plugin.
  13. yobuddy
    51,770Coins
    I will look into updating the plugins protocol after v3 is out.
    Please note that it's going to take me a bit to get v3 out the door.
    I still have quite a bit to do with manuals, how-to(s), write-ups and all.
  14. Rongchen
    Rongchen New Member
    67Coins
    Thanks very much
  15. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Yes thanks I worked that out eventually. After a few shaky laps on 2021 format. Changed back format to 2018 and using without simhub for now. Cheers
  16. ivan jack
    ivan jack Member
    418Coins
    I made both simtools and simhub work using the 2018 simhub udp forwarding, In Solo mode works great, but the plugin doesn't work in My team. I tried legacy mode. no move.
  17. Rongchen
    Rongchen New Member
    67Coins
    could you please help post the snapshot of your simhub forwarding setup? Thanks
  18. ivan jack
    ivan jack Member
    418Coins
    I used Petemnz method posted above with all the details needed.
  19. Rongchen
    Rongchen New Member
    67Coins
    Finally managed to get simhub and simtools work together as they did in F1 2020. Most important thing is delete the whole line of “<add key=F1 2021 processes” value = “F1 2021; F1 2021_dx12”/> in simHubWFP.exe. The rest is just same as I did for F1 2020.
  20. ivan jack
    ivan jack Member
    418Coins
    Do you have any motion in My team? Did you used the 2020 plugin instead of this? Thx
