F1 Like Wheels
Discussion in 'DIY peripherals' started by splendiddd, Jun 17, 2010.
  1. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    811Coins
    Ok, but where is the connector? For this kind of money you may be better of with the frex. However the sparco looks very professional.
  2. danr
    danr New Member
    Please ,LEDFOOT
    Reply to this post. In detail as I want this wheel F-1 ROSO as an add on to my G-25,what does it take for assy to G-25 and software,drivers etc.
    What documentation is supplied.
    What wheel did you order ??
    Thanks for your help.
    Danr
  3. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Hi Danr,
    Roso only makes one F1 wheel that I'm aware of. The wheel comes with a quick release that connects directly to the G25 without any adapters. The wheel has an integrated SLI Pro interface so you will need to download drivers for the SLI Pro to have the display working with sims that support it. The buttons will work without any additional drivers in all games.
    ...Mike
  4. danr
    danr New Member
    Hi Ledfoot,
    Thanks for the reply.
    One more question on how this wheel is attached to G-25 and what needs to be removed,wheel and existing paddle shifters how diffucult to do this as I have never taken mine apart.
    I will purchase when I know how all is done.
    Thanks.
    Dan R
  5. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Very simple to install. Remove the existing wheel, unplug the buttons, remove the existing paddles with two easy to get to screws and then attach new quick release to the same mounting holes for the old wheel.
  6. danr
    danr New Member
    Ledfoot,
    I understand after further looking at your photos.Thanks
  7. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Zelkjo has very good customer service and has always gotten back to me in a timely manner when I asked a question. I see no reason why you will need to send in your G25 unless you plan to get the Sparco quick release and even that should be pretty easy to install yourself.
    He is also doing a mod for my GT wheel as well with SLI Pro and paddles.
    ....Mike
  8. julian.bernard
    julian.bernard New Member
    22Coins
    Spendiddd, What projector are running there? Resolution looks good but the scale seems to be 'larger than life'
    Cheers
    Julian
