F1 motion sim - upgrading 2DOF to 3DOF
Discussion in 'Commercial Simulators and Peripherie' started by early_m, Dec 31, 2023.
  1. cfischer
    Colorado
    2,837Coins
    Nice clean build!
    I really like the use of laser cut brackets.
    Can you share more about the swing arms you made that connect to the motor cranks?
    Are they welded at the bottom?
  2. early_m
    early_m Active Member
    Chelmsford
    899Coins
    No not welded, I designed them so welding was not required to keep simplicity and costs down
  3. cfischer
    Colorado
    2,837Coins
    Dang so how did you bend those plates so tight and clean?
  4. early_m
    Chelmsford
    899Coins
    They're in 2 parts ;)
  5. _cOdaC_
    _cOdaC_ Member
    348Coins
    How did you manage to get 3 motors running. Are you using 2 Arduinos with the SPS soft start 8.2 or did you manage to control two sabertooth with one Arduino? Can't really see that on your photos.
    Why did you switch to rubber straps on the pots and where did you get them?
    And last but not least: What is the sense behind the gasolifts?
  6. Michail
    748Coins
    How do you manage to compress the gas dampers to install them?
    I am not able, and does not have an idea…
  7. early_m
    Chelmsford
    899Coins
    They're only 100n, not very powerful so quite easy. Yours must be a lot stronger?
  8. Michail
    748Coins
    My are 300N I am confused. I have 4 motors wheelchair with 250w and 13,4 A at 75rpm. Unfortunately I don’t know how high the torque is.
  9. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    With 250 watt at 75 rpm you get a little under 33nm There goes the gearbox efficienty off Wormgear I 25 wetween 70 and 80% with I 50 between 50 and 60% Witha a spurgearbox its arround 80 and 90% Hope this helps Ad
  10. early_m
    Chelmsford
    899Coins
    My motors are 63nm so you will need higher rated gas struts to what I am using. As you are experiencing, much over 200n are difficult to depress. You may have to change your design, either by improving the mechanical leverage or shortening the CTC (centre to centre) of the levers
  11. Michail
    748Coins
    WOW thank you! My motor are wheelchair the same SCK gaming ist using may you can tell me how many kg 1 Motor is able to heave with an CTC of 6,67cm? Or how to calculate? When yes better as PM, because, I do not want to spam with offtopic this trhead here.
  12. Michail
    748Coins
    This is my design, to at the back for heave and traction loss 2 in the front for heave, pitch and roll und 1 for surge.
  13. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    Its a spurgear Between 41 and 48kg on your lever
  14. Michail
    748Coins
    So all 4 motor together can heave at least 164 Kg or I misunderstand?
  15. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    No to hold it you need more force to move it the force to move it goes in G gravety 0 to 10 meter second in 1 second with a load from 164kg you need 328kg force
  16. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    to move with 1 G
  17. Michail
    748Coins
    This is the reason I have 4x 300n Gas Dampers to install. May I can contact you over PM?
  18. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    yes
  19. plingboot
    plingboot New Member
    28Coins
    Do you think this rig could work with a monitor mounted to it?
    I don't have VR goggles at the moment (or any time soon).
    I've got an SFX100 based F1 rig, but I quite like the idea of converting to something like this which is far less space hungry.
  20. early_m
    Chelmsford
    899Coins
    I tried it, there's a video on the motionsimbuilders FB group. Worked ok but just don't like using monitors, VR is the way!
