F1 style 2 DOF | Mantis Simulators FS2
Discussion in 'Commercial Simulators and Peripherie' started by early_m, Apr 25, 2021.
  1. Imran
    Imran New Member
    56Coins
    I did not find such motors here in India. can you please give the motor purchase link. I need brief details about the motors
  2. early_m
    early_m Active Member
    Chelmsford
    899Coins
    Search for simukit and their 400w motors
  3. Rodrigo Antonio Zotto
    Rodrigo Antonio Zotto New Member
    - 75Coins
    2DOF, 3DOF, 6DOF
    Do you have the dimensions of the wooden frame?
  4. early_m
    Chelmsford
    899Coins
    No sorry, wooden frame is long gone
  5. Billel
    Billel Member
    195Coins
    Could you share dimensions of the Alu rig you have now, you inspired many of us to build the same
  6. Billel
    Billel Member
    195Coins
    And may i ask why did you change the motor's position from the front (in the wooden frame) to the back (in the Alu frame), what mechanical adventages did that achieve (isn't less distance means less torque for the motors ?)
  7. Radje748
    Radje748 Member
    287Coins
    Another question I have, why did you use this motor instead of the 24v wheelchair motor?
  8. Michail
    748Coins
    May you can share how you can adjust the position of the Wheel with the 8020 Alu rig? what kind of gliders, or fast screw fix do you use?
  9. early_m
    Chelmsford
    899Coins
    More power and torque, plus easier mounting is a bonus
  10. early_m
    Chelmsford
    899Coins
    I just loosen the bolts and slide the frame around, then re tighten
  11. Michail
    748Coins
    Is it possible to connect a quick loosen/tighten system?
    May you can share your axis and tuning center settings?
    Your Rig was and still is a big inspiration.
  12. early_m
    Chelmsford
    899Coins
    My sim can now be purchased at mantis-simulators.co.uk
    Mods please move this thread to the commercial section :thumbs
  13. early_m
    Chelmsford
    899Coins
    Latest picture:
  14. early_m
    Chelmsford
    899Coins
    Latest vid of the sim in action
  15. early_m
    Chelmsford
    899Coins
    It's race week!
  16. noorbeast
    154,750Coins
    +11,196 / 57 / -2
    The audio driven LEDs are a nice touch.
    From the video there did not seem to be heave dialed in to the motion profile, for fine movement.
  17. early_m
    Chelmsford
    899Coins
    Just to clarify, the rpm LEDs are not audio driven and are achieved using Dash and a new sketch from @yobuddy
    https://www.xsimulator.net/communit...xample-with-arduino-sketch.17871/#post-238673
    The sim does have heave but it depends on the track model. I think this particular Baku track is hand modelled and subsequently is very smooth. In my Oz gp video the heave is more evident. Same car, same settings. But the track is perhaps laser scanned so contains more detail.
  18. noorbeast
    154,750Coins
    +11,196 / 57 / -2
    Not tried the Baku track, but it is notoriously bumpy, very evident when the new gen F1 cars were first introduced: https://www.espn.com/f1/story/_/id/34095155/why-was-mercedes-bouncing-bad-baku-there-solution
  19. early_m
    Chelmsford
    899Coins
    I believe that was due to the 'porpoising' issue the teams were facing and not down to the condition of the track. It was more of a problem there due to the downfirce achieved on its long straight.
    I'm curious, so Ill try the F1 22 version to see how it compares
  20. noorbeast
    154,750Coins
    +11,196 / 57 / -2
    The 'porpoising' was an inherent design issue but was exacerbated by the Baku track, which is notoriously bumpy, the likes of Nords is even worse and not fit for the likes of real F1, but even pretty flat F1 tracks have fine track detail, evident in head movement of onboard F1 footage.
