Ferrari_man SimforceGT with SCN5 100mm
Discussion in 'DIY Motion Simulator Projects' started by Ferrari_Man, Jan 12, 2009.
  1. egoexpress
    422Coins
    You are right, I wasnt aware of that when I wrote my last post. So it has to be adjusted for every game....
    I think I will too, at least as long as I dont have SCN5 to test on my own :brows:
    Anyway, I think he should increase the accelleration to get rid of the lag...
  2. Ringorumble
    Ringorumble Active Member
    190Coins
    We should not stop discussing, these are no offenses or anything, maybe we get some more infos out !
  3. egoexpress
    422Coins
    Bernard agreed to check out an idea I had while thinking about output speeds. Perhaps we will be able to set a default output speed of 16ms, which is equal to 60Hz or 60fps. Sure, just in case that the movement quality would not suffer that much.
    As 60fps is a value that most of us should be able to achieve ingame, it would be way easier to exchange profiles, if the output speed is fixed to a default of 16ms.
    Let's see...
    But however, I think we should continue this issue in the SCN5 software thread.
    Regards
    Christian
  4. Ferrari_Man
    Ferrari_Man Member Gold Contributor
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    I will test some more later tonight but now I going out to get my car back. It got stolen yesterday and the police have just called. They have found it in a town not so far away...
    @egoexpress - Didn't you order 2 SCN5 100mm, back when you mailed me?
    Is there any guide or special way to find out your settings for your outputs.. right now I am just trying to change some numbers and see what happens... right before the police called I had the outputs around 90-100. Peaking at 127. Do you guys have a game running while or just the test plugin... I love to see a video of it.
    Maybe a good idea to continoue i the software thread.
    Ferrari_man
  5. Mr Burns
    Mr Burns New Member
    :eek: :eek: :eek:
  6. HAVOG
    HAVOG New Member
    High and Low voltage technician, production automa
    Denmark
    299Coins
    Hey Ferrari_Man :)
    Looks good... Maybe I will come and try your sim some day. I just got the controllers and noise filters for my OMRON step motors today and I also got 2 OMRON freq. inverters..
    Henrik
  7. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    Hey Henrik..
    thanks and you know your welcome :)...
    Remember to get some inverters for me... :)
    Ferrari_man
  8. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    I have just tried the lastest profile from bvillersjr and I really like it.
    Here is a video:
    http://www.youtube.com/watch?v=g7qd23Z6Hic
    Ferrari_man
  9. egoexpress
    422Coins
    @Ferrari_man
    The video is almost not viewable. But the motion seems to be good!
    I'd even suggest you to remove that video from youtube, and upload another one later...
    I hope you'll find a better cam somewhere arround...
    Or maybe adjust the cam settings to lower performance to get constant video fps...
    Regards
  10. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    Please do upload an improved video when you have a chance. I am unable to determine if the profile is working properly or not from this video.
  11. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    new video is online
  12. bvillersjr
    Ohio, USA
    438Coins
    That's much better. It appears to be an improvement over the last profile. Are your 25% limiters enabled?
  13. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    Yes it looks and feels much better now. I havn't uncheck the limiters so it should be on.. I will check tomorrow.
    Ferrari_man
  14. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    Hi all. After being away from using my setup for many years do to many reasons (work, moving, new house, wife, kids and so on :) ) I have now dusted off my old setup and ready to try it again (this time with the kids (atleast that is the excuse for the wife)).
    I can see it is now software which is available since i last was a part of the forum. Is there anything I should beware of coming from the old software? I have been reading the quick start guide and it seems quite straight forward. Can I install the software and test if the old SCN5 still work (without buying licence) ?
  15. noorbeast
    154,750Coins
    +11,196 / 57 / -2
