Ferrari_man's simulator project
Discussion in 'DIY Motion Simulator Projects' started by Ferrari_Man, Jul 25, 2007.
  1. egoexpress
    Hi
    Your frame looks great! Let's try to get it into movement.
    I dont have a ready to use profile. We have to config it together, when you have connected your valves to the interface and the cylinders.
    You should attach some pots anyway. I think it wont work well without positioning.
    ego
  2. Ferrari_Man
    Ferrari_Man Member Gold Contributor
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    Hey
    I will get the pots on monday so I will continune with them there. But if I should use the pots it should be closed valves, right? (I have both)
    And I should connect the valves, cylinders and pots like this, right?
  3. egoexpress
    valves middle open work as well. Its just because of, when you dont have pots, the software doesnt know when your cylinders do reach the end positions.
  4. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    Okay. Does that mean that I latter on can make a 3 speed system with 4 valves(with the 4 valves I already have 2 with open middle and 2 with closed)???
    Ferrari_Man
  5. egoexpress
    No, either middle closed or open.
    If I was you, I'd try to swap the middle open ones.
  6. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    Iam trying the beta software (while waiting for my chair :x ) do the 3D SimforceGT simulator work for you guys... mine just keep turning around, its like the cylinders arent mounted to the chair? The RnR simulator works fine?
    Ferrari
  7. egoexpress
    I dont understand you
  8. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    when I start 3D simulator SimforceGT with the profiler the seat just turns around and around and so on. Its the same with the the 2 cylinders behind the seat they just go round. If I move the joystick I can chance the direcktion.
    and the 2 cylinders are not mounted on the bag of the seat. They just rotate in difference direktions..
    Hope thats better..
    Ferrari
  9. egoexpress
    Yes, it needs a lot of work, still ;)
    Have you wired your setup already?
    ego
  10. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    I am wiring it now but still waiting for my seat..
    If I mount a 75mm 10K sliderpot and only use maybe 60mm of it, will that work. Can I adjust that in the software.
  11. egoexpress
    while making a calibration run, the coils drive to both end positions. Then, the according pot values will be saved as calibrated values.
    So there should be no bigger problem with unsing longer pots. Though it would be more precise, if the whole distance would be used (higher resolution). Theoretically. Dont know if it is noticalble at all.
    Afaik, until now, nobody used 10K pots. Good luck ;)
  12. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    We had the 10k pots at work so they where free... I will try them...
    On the wiring picture it says 10k for the valves and the vellenman
  13. egoexpress
  14. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    okay.. if I understand it right you have to remove the IC3 and solded the x and y connections on istead. ( and not mount the IC3 again)
    Is that right?
  15. egoexpress
    You have to remove the op-amp (IC1) permanently.
    Besides that, the x and y connections have to be soldered to the PIC (IC3). For safety purposes it is recommended, to take out the IC3 as well, while soldering. But the IC3 has to be remounted after the solder job (watch out for the right mounting direction).
    If you are afraid of soldering, you have to find another way, to connect the pot wires ;)
    But do not solder the wires to the socket. Solder them to the backside of the PCB directly on the solder spots. You could fix them after with some (just a little) hot glue. And you should use a very small soldering iron!
  16. egoexpress
    please note that I edited the pot wiring picture...
  17. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    Hey
    I should be ready to test the chair tomorrow, but I am not totaly sure about how to setup the ventil matrix.. and how to make sure the pots are working fine..
    Can I use the matrix sample 4 Festo single speed ?
    I will be using 2 valves (5/3 Closed) and 2 10k pots.
    (but I have ordered 2 more valves for the 3 speed system, but thats in the future)
    And shall I use the logitech Momo Race joystick for calibration or a normal joystick. (I have both)
  18. egoexpress
    Hi
    With this additional information I can give you an answer.
    Yes, with 2x Festo middle closed you should use the Festo excample Setup in the valve matrix.
    It does not make a difference with input device you use, because I think you dont want to use the jostick mode anyway.
    I propose you to use LFS with the outgauge plugin for your first attempts, instead of using Yoda.
    ego
  19. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    Okay with the matrix setup. It is festo with middel closed
    Where do a get LFS. It need to be full version, right?
  20. egoexpress
    Hmm, I had not in mind, that you are going to use a frex style setup. Therfor the festo setup in the valve matrix cannot be used, as it is for RnRs. Sorry.
    You need a new movement profile. Perhaps illi could help you. I'll ask him...
    The LFS demo works as well ;)
    BTW, you could post some latest pics of your sim. Have you already mounted the racing seat?
    ego
